07-22-2017, 18:42 | #1 (permalink) |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | GUIDE - How to Repair IMEI of Qualcomm Devices [Look Here] - Root the Device - Enable USB Debug 1 - Backup Security (Against any possibility) 2 - Wipe Security 3 - Enable Diag 4 - Select Any Method for Write IMEI |
The Following 14 Users Say Thank You to namyelus For This Useful Post: |
07-23-2017, 06:42 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Is there any require of security backup if a device need to Repair IMEI ? Yes its require when one want to change IMEI . Br - srinibas |
The Following 3 Users Say Thank You to srinibas For This Useful Post: |
03-25-2018, 13:58 | #12 (permalink) |
Junior Member Join Date: May 2017
Member: 2721278 Status: Offline Thanks Meter: 1 | -- Searching Device -- Found -- MODAL : moto x4 -- MANUFUCTURER : motorola -- ANDROID VERSION : 8.0.0 -- CPU : arm64-v8a -- HARDWARE : qcom -- BUILD DATE : Wed Jan 31 05:20:12 CST 2018 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Permission denied -- No Rooted Device found !! I am rooted and granting all access, root checker even says I am rooted. Moto X4 Diag mode say same |
03-25-2018, 14:07 | #13 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,545 | Quote:
What procedure you are trying if any issue we will solve it. | |
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
03-25-2018, 22:28 | #14 (permalink) | |
Member: 2721278 Status: Offline Thanks Meter: 1 | Quote:
-- Found -- MODAL : moto x4 -- MANUFUCTURER : motorola -- ANDROID VERSION : 8.0.0 -- CPU : arm64-v8a -- HARDWARE : qcom -- BUILD DATE : Wed Jan 31 05:20:12 CST 2018 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Permission denied -- No Rooted Device found !! | |
04-04-2018, 23:21 | #15 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1019053 Status: Offline Thanks Meter: 6 | problem repair xiaomi max 2 I have a problem with UAT, I want to write imei of a xiaomi mi max 2, qcom msm8953, but when I want to do the wipe security it gives error, it says to unlock the bootloader first, but the bootloader is unlocked, and it does not do the wipe security, the cellular is rooted and port open diag ,,, already try with tab xiaomi and with qualcomm tab and I can not, any solution? the cell phone has 2 imeis I want to repair the number 1 ,,, I hope response thanks |
The Following 2 Users Say Thank You to darknees92 For This Useful Post: |
