04-17-2021, 16:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | TA-1080 nokia 2.1 unable to select firmware [SOLVED] If I try to select xml file, UAT does not see the file in the folder If I try to select the folder with the firmware in it I receive this error : Incorrect Image Directory Selected But I can Factory reset / FRP ...info all ok Waiting for QDLoader port ... Port found Device on Port : [ COM42 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E065000 | Snapdragon 425 BLOCK_ID_S : 54B4FD0A BLOCK_ID_H : S0S9647N88O7385429O955664ONO273P BLOCK_ID_H : P4SR466566S473170P7NRQ5QN996NP42 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 7.28 GB Userdata : 5.21 GB Partition Count : 63 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8917] Userdata : Encrypted Reading Device Information... Model : E2M Android Ver. : 9 CPU : armeabi-v7a Android OS : Pie Display id : 00WW_1_13C Build Date : Tue May 7 17:40:45 CST 2019 Build id : PKQ1.181105.001 Security Patch : 2019-05-01 Brand : FIH Manufacturer : FIH Product : E2M Emmc Size : 16GB Local lang. : en-US Searching FRP Data.... Frp data found Resetting frp.... Reset frp success --------------------------------------------------- Waiting for QDLoader port ... Port found Device on Port : [ COM42 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E065000 | Snapdragon 425 BLOCK_ID_S : 54B4FD0A BLOCK_ID_H : S0S9647N88O7385429O955664ONO273P BLOCK_ID_H : P4SR466566S473170P7NRQ5QN996NP42 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 7.28 GB Userdata : 5.21 GB Partition Count : 63 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8917] Userdata : Encrypted Reading Device Information... Model : E2M Android Ver. : 9 CPU : armeabi-v7a Android OS : Pie Display id : 00WW_1_13C Build Date : Tue May 7 17:40:45 CST 2019 Build id : PKQ1.181105.001 Security Patch : 2019-05-01 Brand : FIH Manufacturer : FIH Product : E2M Emmc Size : 16GB Local lang. : en-US Formating device Safe, please wait... Formating device success |
04-17-2021, 17:21 | #2 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,530 | Open firmware Folder Rename EVW-0-044-raprogram0.xml to raprogram0.xml and Rename EVW-0-044-patch0.xml to patch0.xml Then Open UAT Qualcomm and select firmware Actually your firmware is Extracted from NB0 firmware By the way You can Directly Flash even Nb0 firmware without extraction |
04-17-2021, 17:55 | #5 (permalink) | |
Member: 120579 Status: Offline Thanks Meter: 182 | Quote:
Thank you ! It worked Waiting for QDLoader port ... Port found Device on Port : [ COM42 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E065000 | Snapdragon 425 BLOCK_ID_S : 54B4FD0A BLOCK_ID_H : S0S9647N88O7385429O955664ONO273P BLOCK_ID_H : P4SR466566S473170P7NRQ5QN996NP42 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 7.28 GB Userdata : 5.21 GB Partition Count : 63 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8917] Userdata : Encrypted Reading Device Information... Model : E2M Android Ver. : 9 CPU : armeabi-v7a Android OS : Pie Display id : 00WW_1_13C Build Date : Tue May 7 17:40:45 CST 2019 Build id : PKQ1.181105.001 Security Patch : 2019-05-01 Brand : FIH Manufacturer : FIH Product : E2M Emmc Size : 16GB Local lang. : en-US Writing : [modem] ... EVW-0-0440-NON-HLOS.bin ... Done Writing : [aboot] ... EVW-0-0440-00WW-1-2-emmc_appsboot.mbn ... Done Writing : [abootbak] ... EVW-0-0440-00WW-1-2-emmc_appsboot.mbn ... Done Writing : [boot] ... EVW-0-0440-00WW-1-2-boot.img ... Done Writing : [recovery] ... EVW-0-0440-00WW-1-2-recovery.img ... Done Writing : [system] ... EVW-0-0440-00WW-1-2-system.img ... Done Writing : [vendor] ... EVW-0-0440-00WW-1-2-vendor.img ... Done Writing : [cmnlib] ... EVW-0-0440-cmnlib_30.mbn ... Done Writing : [cmnlibbak] ... EVW-0-0440-cmnlib_30.mbn ... Done Writing : [cmnlib64] ... EVW-0-0440-cmnlib64_30.mbn ... Done Writing : [cmnlib64bak] ... EVW-0-0440-cmnlib64_30.mbn ... Done Writing : [keymaster] ... EVW-0-0440-keymaster64.mbn ... Done Writing : [keymasterbak] ... EVW-0-0440-keymaster64.mbn ... Done Writing : [splash] ... EVW-00WW-002-splash.img ... Done Writing : [sbl1] ... EVW-0-0440-sbl1.mbn ... Done Writing : [sbl1bak] ... EVW-0-0440-sbl1.mbn ... Done Writing : [rpm] ... EVW-0-0440-rpm.mbn ... Done Writing : [rpmbak] ... EVW-0-0440-rpm.mbn ... Done Writing : [tz] ... EVW-0-0440-tz.mbn ... Done Writing : [tzbak] ... EVW-0-0440-tz.mbn ... Done Writing : [devcfg] ... EVW-0-0440-devcfg.mbn ... Done Writing : [devcfgbak] ... EVW-0-0440-devcfg.mbn ... Done Writing : [dsp] ... EVW-0-0440-adspso.bin ... Done Writing : [ftmboot] ... EVW-0-0440-ftm.img ... Done Writing : [default_nv] ... EVW-0-0440-NV-default.mbn ... Done Writing : [hwcfg] ... EVW-0-0440-hwcfg.img ... Done Writing : [sutinfo] ... EVW-00WW-002-sutinfo.img ... Done Writing : [systeminfo] ... systeminfo.img ... Done Writing : [hidden] ... EVW-0-0440-00WW-1-2-hidden.img ... Done Writing : [cda] ... EVW-00WW-006-cda.img ... Done Writing : [cache] ... EVW-0-0440-00WW-1-2-cache.img ... Done Writing : [mdtp] ... EVW-0-0440-00WW-1-2-mdtp.img ... Done Writing : [PrimaryGPT] ... EVW-0-0440-gpt_main0.bin ... Done Writing : [BackupGPT] ... EVW-0-0440-gpt_backup0.bin ... Done Searching frp data.... FRP data found Resetting FRP.... Reset FRP success Formatting userdata Formatting userdata done Writing patch0 : Done Write firmware successfully done. All process done... | |
The Following 2 Users Say Thank You to tintome For This Useful Post: |
