06-25-2018, 22:33 | #32 (permalink) |
Junior Member Join Date: Feb 2005 Age: 50
Member: 120913 Status: Offline Thanks Meter: 5 | alcatel 9024w frp Failed to start programmer. Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM60 ] Analyzing Please wait ... CPU_ID : [MSM 8909] MEM_TYPE : EMMC BLOCK_ID_S : 11B6F762 BLOCK_ID_L : 00000000 BLOCK_ID_H : FC9B6BE6CBBEC404241772BB08B2F97E BLOCK_ID_H : BF86933BF4EBA39EDD46361C79F4C718 Starting Qualcomm Frp Removal Method Reading Data .. Please wait Sending loader Please wait ... Failed to start programmer. |
The Following User Says Thank You to lalito For This Useful Post: |
06-25-2018, 23:40 | #34 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Turkey Age: 39
Member: 311347 Status: Offline Sonork: 100.1672192 Thanks Meter: 486 | You can see at XiaoMi Tab TestPoint Button Quote:
06-26-2018, 03:12 | #39 (permalink) |
Freak Poster Join Date: May 2011 Location: caracas venezuela
Member: 1575111 Status: Offline Sonork: chris259 Thanks Meter: 35 | NOT TRUE Modified and Improved ZTE FTM & Qualcomm IMEI Repair Method SAME PROBLEMS EVEN WORST THEN BEFORE ERROS LIKE SYSTEM56.DLL AND OTHER THE PART ON ZTE DOSENT WORK |
06-26-2018, 04:52 | #41 (permalink) | |
Freak Poster Join Date: Jun 2018 Location: Internetz Age: 40
Member: 2843734 Status: Offline Thanks Meter: 148 | Quote:
----- Good to see new version!! I hope the HTC bug is fixed. Looking forward to taking advantage of that section. | |
06-26-2018, 05:18 | #42 (permalink) | |
No Life Poster Join Date: Aug 2010
Member: 1372118 Status: Offline Thanks Meter: 139 | Quote:
run as windows 7 and run as administrator that fix my problems | |
06-26-2018, 05:47 | #43 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Kemaman,Terengganu,Malaysia
Member: 2420663 Status: Offline Thanks Meter: 22 | after install new version i got this problem. what happen here??? |
The Following User Says Thank You to dummytest97 For This Useful Post: |
06-26-2018, 07:12 | #44 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Poland Pruszków-Warszawa-Warka
Member: 290272 Status: Offline Thanks Meter: 431 | I have such a mistake after installing the new version. I installed it on a previous version and after uninstalling the program for deep uninstallation, nothing helps. Running without and with administrator rights does not help either. |
The Following User Says Thank You to marcin7904 For This Useful Post: |
06-26-2018, 07:32 | #45 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,531 | Will you please Follow this Method and Post the Result. 1. Right Click On Uni-Android ShortCut on Desktop > Select Properties > Open File Location. Now you are in Uni-Android Folder. 2. Right click on Uni-Android.exe, Select Properties , Select Compatibility Tab 3. Click on Change setting for all users Button 4. Tick Run this Program in Compatibility mode for : 5. if you are using Win 7 Select Win 7 6. If you are using win 10 Select win8 7. Select Run this Program as Administrator and Apply |
The Following 5 Users Say Thank You to Mehmood Riaz 1 For This Useful Post: |
