Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT
Old 01-29-2019, 14:08   #46 (permalink)
Member: 322417
Thanks Meter: 939
Originally Posted by allumts View Post
Remove Other Qualcomm Drivers reboot pc then Install this version from here:
QDLoader HS-USB Driver X86/X64
allumts
I try with uninstalling and reinstalling before,but didn't reboot PC
Will try and post results as well
Old 01-29-2019, 14:15   #47 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,329
You know very well if install NEW DRIVERS must reboot pc for to have effect
The Following User Says Thank You to allumts For This Useful Post:
Old 01-29-2019, 15:08   #48 (permalink)
Member: 322417
Thanks Meter: 939
Yep its true.
I Try Uninstall - restarting - install your provided drivers
Plus i do clean boot of windows just in case (disable all non microsoft services and startup software) same thing , very annoying...
http://www.youtube.com/watch?v=Y846e92XR4Q
You can check video too. I Will have 1 more day this set in hand and if developers want to try to solve this bug i can help with testing only today.
Thanks for replay
Old 01-29-2019, 15:25   #49 (permalink)
Member: 322417
Thanks Meter: 939
Originally Posted by soft360 View Post
Anti-relock for xiaomi device works only in a rooted devices ? Thanks for replay, good tool ˇˇˇ
Anti Relock not need for root it will use exploit
Remove iCloud.apk need root
Old 01-29-2019, 15:28   #50 (permalink)
namyelus's Avatar
Member: 2709688
Thanks Meter: 2,187
Yep its true.
Thanks for replay
Hello,
Your issue still related with Drivers, Please contact with me on skype for check issue remotly.
The Following User Says Thank You to namyelus For This Useful Post:
Old 01-29-2019, 15:39   #51 (permalink)
allumts's Avatar
Member: 1564612
Yep its true.
Thanks for replay
Friend you have used New drivers w/o rebotting other time the pc, can be i forgot of write you, but think you know that if Install NEW drivers must reboot pc first then repeat procedure, what you haven't done.
Anyway now P.Manager helping you, later tell me if issue was in restart pc first of use New drivers.
Old 01-29-2019, 17:17   #52 (permalink)
jrbravo's Avatar
Member: 2545468
Thanks Meter: 224
in my case, I never managed to register the new mail at 2 years. I had to buy gsmserver for 52.99 per year because the server keeps adding new emails and generates errors in the new subscriptions. Nor does anyone answer me, sir. Mukesh raj asked me for the id to leave it on skype, he does not answer, I wrote him whatsapp does not answer either leave a message on the facebook page nobody responds then who do I have to write to respond?
Old 01-29-2019, 17:45   #53 (permalink)
jrbravo's Avatar
Member: 2545468
Thanks Meter: 224
another error in the update 20.02 to be flashing software to a j2 prime when it starts to pass system closes the uni-android program is a danger to work as well because if a computer dies for the bad tool touches out of my pocket to replace the mobile !!
The Following User Says Thank You to jrbravo For This Useful Post:
Old 01-29-2019, 18:54   #54 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 414
The same error with J730F when loading the software at 95%, the program has turned off. It's good that the phone was saved.
Correct it.
The Following 2 Users Say Thank You to marcin7904 For This Useful Post:
Old 01-29-2019, 20:59   #55 (permalink)
Member: 427174
Thanks Meter: 17
It still have bugs, I cant flash Qualcomm devices, when I select rawprogram0.xml it opens again tje window to select the same file
Old 01-29-2019, 21:09   #56 (permalink)
Member: 322417
Thanks Meter: 939
Forgot to Mention , i have restarted PC and try but same
The just reinstalled drivers on video and shows hows looks.
I Restarted again now but still same, thanks for Replay friend
Old 01-29-2019, 21:10   #57 (permalink)
Member: 322417
Thanks Meter: 939
Originally Posted by namyelus View Post
Hello,
I Write to Riaz on Skype and hi didnt get answer.
Sending you request on skype too, i sent you PM either
Tomorrow customer will take his phone, if you guys help me tonight OK , otherwise i will not have set in ine hand
Regards
Old 01-29-2019, 21:34   #58 (permalink)
Member: 2876575
Fail in exe download,
Old 01-29-2019, 22:04   #59 (permalink)
Member: 2890841
Can I just request a refund? Unsatisfied, disappointed, annoyed, and feeling hoodwinked. Would rather try and settle issues with you instead of opening pay-pal claim. I will wait a reasonable amount of time for a response before taking alternative options. Waiting patiently for your response.
Old 01-29-2019, 22:16   #60 (permalink)
allumts's Avatar
Member: 1564612
Regards
It's very Bad thing....him have write in Marked characters of contact him for help to solve this issue.
Friend, at this point, 6 mounths PAYED w/o a Update, No help you also writed, from my side i not waste more money with this tool.
I conseje you, if have other Dongle, (cannot mention), try with other dongle, i'm sure you solve you problem.
Page generated in 0.22312 seconds with 9 queries
