maybe UAT team lost interest of fixing there product LOL because they already earn from us lol |
Earning does not matter, and It is not true that we have no interest in fixing it, yes we are working on it .. will give bug free update .. soon within one week best updates will be started for UAT Main Module. |
To everyone complaining about 19.01 not working.. Do you not read? U.A.T. Team said to go back to 18.02 and use it until they release the new bug free build. I know it is frustrating but sometimes it takes a while to work out bugs. We are their primary source for this kind of information so that they can fix it. Without our feedback they cannot find every bug themselves. Coding completely bug free application on this level = impossible. Always going to have to fix something. I have ran 3 programming companies years past so I can tell you it is always an uphill battle. Once you reach the top and every module is tuned etc then you've an application that needs little attention when it comes to bugs. It will be almost perfect then! |
After following all steps I still have same problem access violation. How to solve this? |
Useful info So here is some info that may help solve the "Access Violation" problem. This is my personal opinion and hypotheses, with no experience in coding or software building : the Memory page is dedicated too large and triggers a memory access violation. How I came to this conclusion: If i clear my RAM using 3rd party software (IObit) I have better success in opening the program. I believe it's the login screen, not the tool. I sometimes have to keep opening uat almost layering the splash screen and the admin Permission screen. Then timing just right : closing the residual app splash screen and starting the app again. Over and over till it overlaps just right.. Other times it will work first try. Sometimes I get it to work, but it has no functionality, nothing works, can't see ports. Hope this helps. |
Will be fixed this issue once for all soon in upcoming update. |
same problem same problem since 19.01, where from to download 18.02 to continue using it until next release? |
link to diownload 18.02? so the link to download 18.02? Quote:
UAT_Setup_18.02.exe |
Too good night I have problems with the tools tool for the dice ID is wrong you do not change me and you do not change anything I need help thanks |
Post email id + Tool ID and let me check the issue. |
both are now "Access violation" what i will do now? i followed the settings you have made unfortunately same status pls help...:confused::confused: regards, |
We are fixing this once for all and will be soon releases a stable versions. |
tnx to your immediate concern Mehmood... meaning for the meantime i wont be able to use my Tool? i did every possible ways given from the supporters regarding this issue, unfortunately unsuccessful.:confused::confused::confused: |
hie your description doesnt solve both the UAT and FRP i cant access any of the two .. |
