![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: izmir
Member: 1210902 Status: Online Thanks Meter: 430 | ![]() 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== Waiting for QDLoader port... COM21 Connecting to device... OK Port : COM21 : Qualcomm HS-USB QDLoader 9008 USB : PCI\VEN_8086&DEV_27B8&SUBSYS_0DF2105B&REV_01\3&241 1E6FE&0&F8 Drivers Info. : Qualcomm Incorporated, qcusbser.sys Drivers : Qualcomm Technologies, Inc. Driver Date : 10/08/2015 Driver Version : 2.1.2.1 Waiting for response... OK Identifying device Mode... OK Sahara Mode detected Handshaking... OK Init Handshake Sequence... OK Initializing Protocol... OK Serial : 107DF153 SoC : [Snapdragon 680 4G] Target : [SM6225] HWID : [0X001B80E1] PKhash [0] : 1BEBE3863A6781DB4B01086063007334 PKhash [1] : DE9E5CA14971C7C4F4358EC9D79CDA46 Configuring boot... OK Version [6] Code Size [816] Signature Size [256] Header Type [NEW] Connecting to flash programmer...OK Chipset Type... 64 bit Initializing connection... OK Device requires authorization... Authorizing device for operations... OK Configuring device... OK Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576] Reading partition map... OK - LUN Count : 6 Reading partition table... OK [100] Factory Reset Format [Safe Method]... OK Resetting FRP [Erase Method]... OK UAT PRO : 181.01 | 11 - Şubat - 2025 [ 08:32:47 ] TURKEY Elapsed Time : 11 seconds |
The Following User Says Thank You to master353535 For This Useful Post: |
