03-10-2021, 16:27 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | Xiaomi 9A connection error 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Xiaomi Model : Redmi 9A (Dandelion) Process : List Partitions ==================================== Searching for device... Device found MTK USB Port (COM3) Mode : BROM Port Port : COM3 Preparing Download Agent.. DA : MTK_DOWNLOAD_AGENT - UAT DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Drivers : MediaTek Inc. Driver Version : 11/06/2014,2.0.1136.0 Handshaking... done Loading Preloader... done Connecting to Brom... Failed |
03-10-2021, 16:59 | #2 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,465 | Quote:
Select Bypass Authorization and Try again . | |
03-10-2021, 17:03 | #3 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | when Bypass Authorization checked no connection at all and phone goes in fastboot mode 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Xiaomi Model : Redmi 9A (Dandelion) Process : Read Info. ==================================== Searching for device... |
03-10-2021, 17:24 | #4 (permalink) | |
Please close Tool and try again and what version of windows with which service pack is Installed on your system. | |
