11-03-2021, 14:17 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 488385 Status: Offline Thanks Meter: 12 | xiaomi frp - Booting device : FAIL (S_BROM_CMD_STARTCMD_FAIL) [SOLVED] -FAIL (S_BROM_CMD_STARTCMD_FAIL) 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : Auto detect - Process : Reset FRP ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek USB Port (COM61) Mode : BootRom Port : COM61 Handshaking ... DONE Hw code: 0x0707 - [MT6768] - Helio P65/G85 Hw sub code: 0x8A00 Hw version: 0xCA00 Sw version: 0x0000 Secured boot: TRUE Sl auth: Yes Da auth: Yes Watchdog disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Handshaking : DONE Booting device : FAIL (S_BROM_CMD_STARTCMD_FAIL) |
11-03-2021, 14:29 | #3 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,531 | Quote:
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
11-03-2021, 14:42 | #4 (permalink) |
Member: 488385 Status: Offline Thanks Meter: 12 | i select redmi note 9 and tick reset frp and do selected and not working Dump preloader: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Process : DUMP PRELOADER ==================================== Waiting for device... Device found MediaTek USB Port (COM2) Mode : BootRom Port : COM2 Handshaking ... DONE Initializing : DONE Hw code: MT6768 - Helio P65/G85 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Protection disable ... FAILED Please Filter port by LibUSB or Install LibUSB drivers Last edited by soniq6; 11-03-2021 at 14:50. |
11-04-2021, 14:27 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Santa Fe, Argentina
Member: 600068 Status: Offline Thanks Meter: 15 | hello i am trying to delete the MI account of a note 8 pro and the boot does not pass. I leave the log for some help 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : By Model - Brand : Xiaomi - Model : Redmi Note 8 Pro (Begonia) - Process : Reset MI Account | Xiaomi ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MTK USB Port (COM32) Mode : BootRom Port : COM32 Handshaking ... DONE Hw code: 0x0813 - [MT6785] - Helio G90 Hw sub code: 0x8A00 Hw version: 0xCA00 Sw version: 0x0000 Secured boot: TRUE Sl auth: Yes Da auth: Yes Watchdog disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.12/30/2020.11:23_545866 Handshaking : DONE Loading Preloader : DONE Booting device : |
