Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT
Old 11-05-2020, 07:40   #1 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 998
Arrow ZTE NUBIA RED MAGIC 5G ( NX659J ) Dead Boot Repair Done
Searching Device ...
Device on Port : [COM25]
Analyzing Please wait ...
SNAP_ID :
HW_ID : 0001E03C000
BLOCK_ID_S : B6F031D1
BLOCK_ID_H : QSS2QQN74P3P94O6796S1775N937370R
BLOCK_ID_H : 97R027OP369O8698SRN38P656RO2S462
Executing boot : Done
Configuring : Done
Reading Parts : Done
Capacity : 29.52 GB
Userdata : 28.6 GB
Partition Count : 100
MEM_TYPE : UFS
Max_Payload_Size_InBytes : 1048576
Max_Payload_Size_Supp. : 1048576
Max_Bytes : F-8
Max_XML_Size : 4096
Version : 1
Target_Name : [MSM on=]
Userdata : Encrypted
Writing : [misc] ... misc.img ... Done
Writing : [parameter] ... parameter.img ... Done
Writing : [recovery] ... recovery.img ... Done
Writing : [recovery2] ... recovery.img ... Done
Writing : [cache] ... cache.img ... Done
Writing : [vbmeta_system] ... vbmeta_system.img ... Done
Writing : [metadata] ... metadata.img ... Done
Writing : [PrimaryGPT] ... gpt_main0.bin ... Done
Writing : [BackupGPT] ... gpt_backup0.bin ... Done
Writing : [xbl] ... xbl.elf ... Done
Writing : [xbl_config] ... xbl_config.elf ... Done
Writing : [PrimaryGPT] ... gpt_main1.bin ... Done
Writing : [BackupGPT] ... gpt_backup1.bin ... Done
Writing : [PrimaryGPT] ... gpt_main2.bin ... Done
Writing : [BackupGPT] ... gpt_backup2.bin ... Done
Writing : [ddr] ... zeros_5sectors.bin ... Done
Writing : [PrimaryGPT] ... gpt_main3.bin ... Done
Writing : [BackupGPT] ... gpt_backup3.bin ... Done
Writing : [aop] ... aop.mbn ... Done
Writing : [tz] ... tz.mbn ... Done
Writing : [hyp] ... hyp.mbn ... Done
Writing : [bluetooth] ... BTFM.bin ... Done
Writing : [abl] ... abl.elf ... Done
Writing : [dsp] ... dspso.bin ... Done
Writing : [keymaster] ... km4.mbn ... Done
Writing : [boot] ... boot.img ... Done
Writing : [cmnlib] ... cmnlib.mbn ... Done
Writing : [cmnlib64] ... cmnlib64.mbn ... Done
Writing : [devcfg] ... devcfg.mbn ... Done
Writing : [qupfw] ... qupv3fw.elf ... Done
Writing : [vbmeta] ... vbmeta.img ... Done
Writing : [dtbo] ... dtbo.img ... Done
Writing : [uefisecapp] ... uefi_sec.mbn ... Done
Writing : [multiimgoem] ... multi_image.mbn ... Done
Writing : [featenabler] ... featenabler.mbn ... Done
Writing : [imagefv] ... imagefv.elf ... Done
Writing : [uefisecappbak] ... uefi_sec.mbn ... Done
Writing : [imagefvbak] ... imagefv.elf ... Done
Writing : [apdp] ... apdp.mbn ... Done
Writing : [spunvm] ... spunvm.bin ... Done
Writing : [splash] ... splash.img ... Done
Writing : [logfs] ... logfs_ufs_8mb.bin ... Done
Writing : [secdata] ... sec.elf ... Done
Writing : [PrimaryGPT] ... gpt_main4.bin ... Done
Writing : [BackupGPT] ... gpt_backup4.bin ... Done
Writing : [PrimaryGPT] ... gpt_main5.bin ... Done
Writing : [BackupGPT] ... gpt_backup5.bin ... Done
Writing patch0 : Done
Writing patch1 : Done
Writing patch2 : Done
Writing patch3 : Done
Writing patch4 : Done
Writing patch5 : Done
Write Firmware successfully done.
All done...
The Following 4 Users Say Thank You to reset12345 For This Useful Post:
Old 11-23-2020, 09:13   #2 (permalink)
Member: 1434348
Thanks Meter: 3
good work but my thone not work unbric
Hardware ID : E1300C00 [SD8250] 00000400
OPK_DATA : 8F7C1A63A23CE98FD673BFFBB5B17904A489379275DCB5B8C4 80977E796C0E86
Initializing Protocol...OK
Sending Loader [prog_ufs_firehose_sdm8250_ddr.elf]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : SD8250, UFS, 256 GB
LU Count : 6 [0x03B04800] [0x00000800] [0x00000800] [0x00008000] [0x00080000] [0x00008000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [65536], Out: 262144, Sector Size: 4096
Processing [rawprogram0.xml]
Writing [misc.img] -> [misc] ...Failed
Operation Failed.
QcFire Ver. 6.0
The Following User Says Thank You to ali-wew For This Useful Post:
Old 11-23-2020, 09:18   #3 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 10,112
Operation Failed.
QcFire Ver. 6.0
Wrong section these are not UAT logs.
Old 12-23-2020, 13:03   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,086
stuck here
Device on Port : [COM182]
SNAP_ID :
HW_ID : 0001E03C000
BLOCK_ID_S : 8B4D31D0
Configuring : Done
Capacity : 14.62 GB
Userdata : 13.7 GB
MEM_TYPE : UFS
Max_Bytes : F-8
Max_XML_Size : 4096
Version : 1
Old 12-23-2020, 15:56   #5 (permalink)
Member: 1737175
Sonork: 100.1667675
Originally Posted by Mr.3. View Post
stuck here
SNAP_ID :
HW_ID : 0001E03C000
Configuring : Done
Capacity : 14.62 GB
Userdata : 13.7 GB
MEM_TYPE : UFS
Max_Bytes : F-8
Max_XML_Size : 4096
Version : 1
Untick misc partition and repeat the process, and please use Qualcomm Module
Old 12-23-2020, 17:19   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,086
I tried that untick misc but it’s stuck with next partition , same result with Qualcomm module
Old 12-23-2020, 17:19   #7 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,086
Delete pls , forum bug
Page generated in 0.16034 seconds with 8 queries
