07-17-2019, 15:14 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Ukraine
Member: 2425619 Status: Offline Thanks Meter: 24 | INE-lx1 Unbrick help Build number: :INE-LX1 9.0.1.162(SP54C432E2R1P1) Model: INE-LX1 Battery state: 8006mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked not turning on ,can only flash fastboot via testpoint. how to flash rescue recovery? where to find preload file ? PLEASE give me guide how to unbrick it . |
07-18-2019, 16:26 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Now KIRIN 710 is Full Supported, read carefully the NEW Update. Not find one easy PRELOADER + base + custom? cannot belive. For work with Huawei must have BASIC KNOWLEDGE not only with attempt |
07-26-2019, 19:57 | #4 (permalink) | |
Member: 2425619 Status: Offline Thanks Meter: 24 | Quote:
It is too hard for you to write little guide how to rescue this phone or give a link for firmware??? As I see Not only one user of hde or hcu have quaestion about unbrick phones with new cpu and with android 9,how to use rescue recovery option ,where to find preload file ,for what is that file needed,and how to use it. Please spent a little more time and try to explain it. | |
07-26-2019, 20:11 | #5 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: KATHMANDU,NEPAL
Member: 2438408 Status: Offline Thanks Meter: 380 | Quote:
i have same problem FLA-LX2 write wrong board software .1 week ago i post on hua support but no answer | |
07-31-2019, 09:56 | #6 (permalink) |
Member: 2425619 Status: Offline Thanks Meter: 24 | SUPPORT??? i try this versions Sydney-L21D 9.0.1.162(SP54C432E2R1P1T8)_Firmware_05015GFH Sydney-L21D 9.0.1.164(SP53C432E2R1P1T8)_Firmware_9.0.0_r3_EMUI 9.0.1_05015GFH every time this error HDE Flasher 0.0.0.105 user:HDETOOL5121 Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 5MG4C18A11001512 Detecting recovery partition Current version(CURVER): INEC432B000 ERECOVERY_KERNEL partition found ERECOVERY_VENDOR partition found ERECOVERY_RAMDISK partition found 31.07.2019 11:51:52 Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: 5MG4C18A11001512 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:5MG4C18A11001512 IMEI:864085043560297 IMEI1:864085043580303 MEID:00000000000000 Build number: :INE-LX1 9.0.1.162(SP54C432E2R1P1) Model: INE-LX1 Battery state: 7826mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Process identifier:17297323 Getting build number... Getting base version... Getting cust version... Getting preload version... Erasing ver .. . Current version(CURVER): INEC432B000 Writing rescue_recovery_kernel partition rescue_recovery_kernel partition UPDATE :FAIL image verification error Cannot enter in Recovey mode Update fastboot mode failed but when i try install android 8 version recocery writing succes and phone reboots but cant enter recovery or fastboot ,so after that need do testpoint again.. please help maybe need RIGHT firmware |
