06-28-2020, 22:30 | #1 (permalink) |
Freak Poster Join Date: Dec 2017 Location: ()
Member: 2794635 Status: Offline Thanks Meter: 43 | IBUS S2 - 38mm Series 2 Firmware?? |
06-30-2020, 12:04 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | The firmware in same package ! eg, MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm.ipsw this for n27dap n74ap 2 models and MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm.ipsw this for n28dap n75ap 2 models |
07-01-2020, 03:38 | #3 (permalink) | |
Member: 2794635 Status: Offline Thanks Meter: 43 | Quote:
[info] Using LOCAL IPSW C:\Users\j4\Documents\MEGAsync Downloads\MFC_Watch2,6_17T530_6.2.1_n27dap_restore _38mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n74ap, Watch2,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [info] device serial number is FH7S80QSHDX5 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Found ECID 889406205044006 [info] Getting ApNonce in recovery mode... [data] 5E6EC9857A112908B48C7D77C1E0422838E134ABA9323484D9 19BA6C6F1B0519 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 8302216F1CA3D8A0544EB53CDB27FB126483EFB3 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm/048-63942-310.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n64.RELEASE.im4p... [info] Sending iBEC (752073 bytes)... [erro] Unable to connect to device in recovery mode [erro] Unable to place device into restore mode [info] Failed Still Not Working!!!! | |
07-01-2020, 03:43 | #4 (permalink) | |
