01-18-2022, 12:10 | #1 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2485783 Status: Offline Thanks Meter: 8 | Apple watch giving unknow erros [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! Sent from my iPhone using Tapatalk |
01-18-2022, 12:48 | #2 (permalink) |
Member: 2485783 Status: Offline Thanks Meter: 8 | Diag load have zip open issue [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] zip_fopen_index: device_map.plist [erro] Could not open database file [erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete! [done] Operation finished! Sent from my iPhone using Tapatalk |
01-18-2022, 13:16 | #3 (permalink) | |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | Reinstall v3.9 , that's it ! as i test S3: Quote:
01-18-2022, 23:38 | #10 (permalink) |
Junior Member Join Date: Jun 2008 Location: Costa Rica
Member: 785495 Status: Offline Thanks Meter: 6 | I have had some issues with at least 3 Series 3 devices...and the problem was the SERIAL+BT+Wifi address... When you have those issues and the hardware is OK, just try another serial combination and works just great! Just give it a try and let us know. |
The Following User Says Thank You to vinhidalgo For This Useful Post: |
