Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 12-10-2021, 15:43   #1 (permalink)
Member: 2642070
Thanks Meter: 15
apple watch s1
[info] Device present connection uses normal backend
[info] Connecting...
[info] Device present in DFU mode using normal backend
[info] Current thread priority is 0x0
[info] stage 1, heap grooming ...
[info] stage 2, aquired
[info] stage 3, exploit
[info] Uploading payload
[erro] Exploit failed!
[done] Operation finished!
[erro] libusb_claim_interface error -5 Entity not found
[erro] Could not find device with ECID:18146024EA8F26 in DFU mode!
[erro] Exploit failed! end
[info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227).
[info] Device is allready expoited!
[info] Allready installed usb driver.
[info] Sending FirstStage
[info] Sending commands ...
[info] Sending DiagsStage
Device not found but should be allready in Diag Mode if you use a DSCD cable.
Please check driver and manually update the driver if required or try again!
whats problem? plz help me....
diags mode error.
Old 12-10-2021, 22:09   #2 (permalink)
Member: 181674
Well , 1st Disabled your Pc Driver Signature , and try again ,
after Diag Mode Done , and after you saw this msg
Your iwatch should appear in Device manager, once it detected , change the driver to Serial Usb Driver , i think that way you will be able to read your iwatch SysCfg.
i wish you try and send here feedback
Regards,
BAYOO
Old 12-11-2021, 00:12   #3 (permalink)
Member: 2277861
Thanks Meter: 210
it's not a issue if you read this
https://forum.gsmhosting.com/vbb/f93...ftware-2974487
Page generated in 0.14373 seconds with 8 queries
