Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 02-16-2022, 11:04   #1 (permalink)
Member: 2642070
Thanks Meter: 15
apple watch s2 diags problem
[info] Device present connection uses normal backend
[info] Connecting...
[info] Device present in DFU mode using normal backend
[info] Device is allready expoited!
[info] Allready installed usb driver.
[info] Sending FirstStage
[info] Sending commands ...
[info] Sending DiagsStage
[info] Installing USB driver for device: "Diags CDC Serial" (05AC:1222) ...
[warn] Failed to install usb driver! Error:Requested resource busy or similar call already in progress
Device is allready in Diag Mode but could not determine COM port. Maybe a DCSD cable is required!
Please check driver and manually update the driver if required!
[done] Operation finished!
WHATSA PROBLEM PLZ HELP ME.
DIAG MODE PROBLEM
MFC 3.9
Old 02-16-2022, 13:35   #2 (permalink)
Member: 2277861
Thanks Meter: 210
Check this :
https://www.mfcbox.com/tutorials/how...y-mfc-software
And this :
https://www.mfcbox.com/blog/about-ol...s2-dfu-by-ibus
Old 02-19-2022, 10:17   #3 (permalink)
Member: 2642070
Thanks Meter: 15
watch s2 cdc driver
i found and installed problems on the internet google cdc driver
Old 03-03-2022, 07:06   #4 (permalink)
Member: 2442957
Thanks Meter: 5
Hi. I have problem with Watch S1 diag connection:
[info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227).
[erro] Current DFU device (ChipId: 0x7002 BoardId: 4) does not exist in our database or data is incomplete!
And have problem with flashing too
[info] Selected port: COM1
[info] Using LOCAL IPSW C:\MFC\Watch Firmware\MFC_Watch2,6_n27dap_38mm_Watch2,3_n74ap_3 8mm_6.3_17U208_restore.ipsw
Thanks for help
System: Amd PhenomII / windows 7 x64
Old 03-03-2022, 09:42   #5 (permalink)
Member: 2442957
Thanks Meter: 5
Thanks for help
With S3 have same flash problem, diag mode do this:
[info] Current thread priority is 0x0
[info] stage 1, heap grooming ...
[info] stage 2, aquired
[erro] Failed to push forward overwrite offset.
[info] stage 3, exploit
[info] Uploading payload
[erro] Exploit failed!
Please help
Old 03-03-2022, 10:36   #6 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,027
0x7002 is 1st version, do some search before you post ! thanks
i don't think S3 have any issue until now ! So u have to check the cable , computer and retry !
Old 03-04-2022, 14:52   #7 (permalink)
Member: 2442957
Thanks Meter: 5
Okay buddy sorry. Now i see.
About S3, i made a fresh install win10 x64, changed cable, but same diag error message. No other computer, just macbook.
Old 03-04-2022, 17:38   #8 (permalink)
Member: 2277861
Thanks Meter: 210
hello,
Please read all details from this page https://www.mfcbox.com/tutorials/how...y-mfc-software
We have listed all possible cases here !
Br.,
Old 03-07-2022, 07:49   #9 (permalink)
Member: 2442957
Thanks Meter: 5
Originally Posted by mfcsupport View Post
hello,
Br.,
Sure, all checked, now i use DCSD (HWTE) cable, sometimes is stuck at Uploading Payload, sometimes exploit failed end. All drivers installed successfully, before every process i make device reboot to dfu mode, checked all com port, i use the diag usb adapter too. Very disappointed
System: AMD, Win 10 Pro, all other iDevice diag software running smoothly, except this...
Old 03-07-2022, 08:55   #10 (permalink)
Member: 79315
Thanks Meter: 6,027
AMD CPU for diag is very bad !
and you need this while you doing Diag for watch
https://eoem.org/product-10667-DFU-D...ple-Watch.html
Old 03-17-2022, 13:17   #11 (permalink)
Member: 2442957
Thanks Meter: 5
Yes i try use with / without that, now im tryin use diag with macbook intel cpu and win10 x64, followed all descriptions, modified all drivers, same issue like amd machine. Ridiculous. Wasted money and time.
Old 03-17-2022, 13:24   #12 (permalink)
Member: 2277861
Thanks Meter: 210
Without the diag cable will never working ! if software not function , all the people should come and complain the situation , seems only 1~ 3 user facing the case !
Anyway if you think its complicate , better don't use !
Old 03-17-2022, 14:01   #13 (permalink)
Member: 2442957
Thanks Meter: 5
Well, please explain this:
[info] Selected port: COM3
[info] Use DCSD cable selected
[erro] Exploit failed! end
[erro] libusb_claim_interface error -5 Entity not found
[erro] Could not find device with ECID:634D0040610A6 in DFU mode!
DCSD Cable, Diag cable, Windows 10 X64 on Macbook with Intel Core 2 duo CPU. Second try i set device DFU mode again.
Old 03-17-2022, 14:19   #14 (permalink)
Member: 2277861
Thanks Meter: 210
Your computer driver is mixed ( libusb_claim_interface error -5 ), if you thinking you are professional enough
(Seems you are)
Yes i try use with / without that, modified all drivers
then you can use https://zadig.akeo.ie/ to detect out the case
Old 03-18-2022, 04:54   #15 (permalink)
Member: 2442957
Thanks Meter: 5
(Seems you are)
Thanks. I solved it. It was not easy and need update drivers every time.
1. Use DCSD and Diag usb cable and make diag without pipe use DCSD cable and without port, changed apple dfu driver to usb serial driver. Of course libusbk driver want install too.
2. Have driver install timeout error messages, but operation finished. Second load diag get libusb -5 error, quit the mfc software and open again.
3.After that it see already driver installed and device exploited, cdc driver install failed, need install manually (automatic driver install disabled). Pull out the diag cable, system can see the dcsd cable, driver installed successfully and can select port. Connect to device and voila.
Page generated in 0.24685 seconds with 8 queries
