06-26-2020, 21:20 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Apple Watch S2 ipsw firmware - MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm.ipsw MFC_Watch2,4_117T530_6.2.1_n75ap_Restore_42mm.ipsw Required:
Firmware download link : https://www.mfcbox.com/Watch-ipsw-fi...-restore-42mm/ Product page: https://www.mfcbox.com/shop https://www.eoem.org/sellers-store-91-MFC-TEAM.html |
06-27-2020, 12:18 | #2 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | Unable to place device into recovery mode from Normal mode. the iwatch is now in red exclamation point what should i do. [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\clovi\Downloads\MFC_Watch2,4_17T530_6.2.1 _n75ap_Restore_42mm.ipsw [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 7609308077056806 [info] Getting ApNonce in normal mode... [data] FF37D4621301AEAB972152739FBD1C526A3FC7A8DE1B39E261 2E64BEE342E573 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 9B89F27FE35BADDE5E895FF94EFA8AD91D86162F [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm/048-63671-311.dmg' [info] Entering recovery mode... [erro] Unable to connect to device in recovery mode [erro] Unable to enter recovery mode [erro] Unable to place device into recovery mode from Normal mode [info] Failed Report Post |
06-27-2020, 12:30 | #3 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | This was before i started updating the driver that was install https://imgur.com/i1zGALE And affter i get error https://imgur.com/nTe91Ov |
06-27-2020, 12:33 | #4 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\clovi\Downloads\MFC_Watch2,4_17T530_6.2.1 _n75ap_Restore_42mm.ipsw [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 7609308077056806 [info] Getting ApNonce in normal mode... [data] FF37D4621301AEAB972152739FBD1C526A3FC7A8DE1B39E261 2E64BEE342E573 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 9B89F27FE35BADDE5E895FF94EFA8AD91D86162F [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm/048-63671-311.dmg' [info] Entering recovery mode... [erro] Unable to connect to device in recovery mode [erro] Unable to enter recovery mode [erro] Unable to place device into recovery mode from Normal mode [info] Failed [data] UniqueChipID:418079526 [data] ProductType:Apple Watch S2 [info] Starting ... [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LOCAL IPSW C:\Users\clovi\Downloads\MFC_Watch2,4_17T530_6.2.1 _n75ap_Restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [info] device serial number is FHLTK046HJLJ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 7609308077056806 [info] Getting ApNonce in recovery mode... [data] FF37D4621301AEAB972152739FBD1C526A3FC7A8DE1B39E261 2E64BEE342E573 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] DE2A32CE27CF10203C6373794483424F1BBBE756 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm/048-63671-311.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (752073 bytes)... [erro] Unable to connect to device in recovery mode [erro] Unable to place device into restore mode [info] Failed Last edited by FON-TECNO; 06-27-2020 at 12:38. |
06-27-2020, 17:05 | #6 (permalink) |
Major Poster Join Date: Sep 2014 Location: Chi Town
Member: 2252444 Status: Offline Thanks Meter: 11 | SAME PROBLEM DRIVERS PROPPERLY INSTALLED [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\user\Desktop\Series 1\MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm.ip sw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S1, n27dap, Watch2,6 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [info] device serial number is FHLS7AK9HF1C [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 5741142996526374 [info] Getting ApNonce in recovery mode... [data] EB827E5CAB84FB3F3B3154EAFEA3EBFC00885E60590FB56E2A E8341D691AB4E2 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 453576A4AB6745BFD088DFB84A9C8837DCEB32CF [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm/048-63942-310.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n27d.RELEASE.im4p... [info] Sending iBEC (747977 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.100.194 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Sending AppleLogo (8178 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-63605-329.dmg... [info] Sending RestoreRamDisk (68001029 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n27dap.im4p... [info] Sending RestoreDeviceTree (98335 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2d... [info] Sending RestoreKernelCache (11109897 bytes)... [info] Restoring device... [info] Waiting for device... [erro] Unable to connect to device in restore mode [erro] Unable to open device in restore mode [erro] Unable to restore device [info] Failed |
06-27-2020, 17:17 | #7 (permalink) |
Member: 2252444 Status: Offline Thanks Meter: 11 | IN DFU SAME THING ERROR [info] Starting ... [info] Using LOCAL IPSW C:\Users\user\Desktop\Series 1\MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm.ip sw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S1, n27dap, Watch2,6 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 5741142996526374 [info] Getting ApNonce in dfu mode... [data] 1D7D1863AEFF9BE32EF70E669060593F690E78D468CF97590F 109D0C3BA1748E [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 9334C37A6C8856CF927B27E43472EF2026E73FA9 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm/048-63942-310.dmg' [info] Extracting iBSS.n27d.RELEASE.im4p... [info] Sending iBSS (747977 bytes)... [info] Noce: 1d 7d 18 63 ae ff 9b e3 2e f7 0e 66 90 60 59 3f 69 0e 78 d4 68 cf 97 59 0f 10 9d 0c 3b a1 74 8e [info] Extracting iBEC.n27d.RELEASE.im4p... [info] Sending iBEC (747977 bytes)... [info] device serial number is FHLS7AK9HF1C [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.100.194 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Sending AppleLogo (8178 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-63605-329.dmg... [info] Sending RestoreRamDisk (68001029 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n27dap.im4p... [info] Sending RestoreDeviceTree (98335 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2d... [info] Sending RestoreKernelCache (11109897 bytes)... [info] Restoring device... [info] Waiting for device... [erro] Unable to connect to device in restore mode [erro] Unable to open device in restore mode [erro] Unable to restore device [info] Failed |
