03-19-2021, 12:03 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | Apple Watch S3 42mm GPS with broken NFC antena. [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.3 [data] Product Build: 18S801 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000c5c9e387880a6 [info] Getting ApNonce in dfu mode... [data] 906E4D7F8AE4CB8F4604C06957F5A0D8BA4CBD3C60A8E5D718 314030C359BD9D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 303DD4B0A515B109F2BCCF38A4349C2CD3FE391A [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_7.3_18S801_n121bAP_GPS_Restore_42mm/038-95436-059.dmg [info] Extracting filesystem [info] Found ECID 000c5c9e387880a6 [info] Getting ApNonce in dfu mode... [data] 906E4D7F8AE4CB8F4604C06957F5A0D8BA4CBD3C60A8E5D718 314030C359BD9D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 303DD4B0A515B109F2BCCF38A4349C2CD3FE391A [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (760868 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000c5c9e387880a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 90 6e 4d 7f 8a e4 cb 8f 46 04 c0 69 57 f5 a0 d8 ba 4c bd 3c 60 a8 e5 d7 18 31 40 30 c3 59 bd 9d [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Device ecid 000c5c9e387880a6 disconnect detected! [info] device serial number is FHLVN4KTJ5X6 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.80.19 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-95880-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15184 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-95880-059.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (77575522 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32226 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2304542 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13255286 bytes)... [info] Device ecid 000c5c9e387880a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 3ead75e428a67a41c8cf177921f99764ec382422 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 3479534342537382 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-95880-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-95436-059.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Status message: Ramrod firmware update failed. Hint: The display of this model is not compatible, or you can replace the NFC module [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [done] Operation finished! [info] device disconnect... |
03-24-2021, 15:12 | #3 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | After replace LCD flex watches is flased. [info] Using LOCAL IPSW C:\MFC_Watch3,4_7.3_18S801_n121bAP_GPS_Restore_42m m.ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.3 [data] Product Build: 18S801 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000c5c9e387880a6 [info] Getting ApNonce in dfu mode... [data] 47C21586D55282652930CBDFB5C8BC4B4FF12E3BF79184CAA8 ED987E0D0CDFC0 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 7CB3ECE5677CA5AAA2364708EE0C0C0D1D295828 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.3_18S801_n121bAP_GPS_Restore_42mm/038-95436-059.dmg' [info] Found ECID 000c5c9e387880a6 [info] Getting ApNonce in dfu mode... [data] 47C21586D55282652930CBDFB5C8BC4B4FF12E3BF79184CAA8 ED987E0D0CDFC0 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 7CB3ECE5677CA5AAA2364708EE0C0C0D1D295828 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (760868 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000c5c9e387880a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 47 c2 15 86 d5 52 82 65 29 30 cb df b5 c8 bc 4b 4f f1 2e 3b f7 91 84 ca a8 ed 98 7e 0d 0c df c0 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Device ecid 000c5c9e387880a6 disconnect detected! [info] device serial number is FHLVN4KTJ5X6 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.80.19 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-95880-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15184 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-95880-059.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (77575522 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32226 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2304542 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13255286 bytes)... [info] Device ecid 000c5c9e387880a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 3ead75e428a67a41c8cf177921f99764ec382422 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 3479534342537382 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-95880-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-95436-059.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [info] device arrival... found. |
The Following User Says Thank You to oljack For This Useful Post: |
