Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 11-15-2021, 11:59   #1 (permalink)
Member: 2294526
Apple Watch S3 42mm same error Restore on 8.1
Prehistory. I had a restore error. You upgraded the program to 3.7.1 and I recovered successfully. But after that the clock hung on the logo. Then I tried to flash them again and there was the same error as now. Then 8.0.1 came out, I try to flash it again and I see the error again.
I just flashed for 8.1 and again the error.
[info] Using LOCAL IPSW C:\Downloads\MFC_Watch3,4_8.1_19R570_n121bAP_GPS_R estore_42mm.ipsw
[info] Updated version data.
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n121bap, Watch3,4
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.1
[data] Product Build: 19R570 Major: 19
[info] device serial number is GJ9X25LXJ5X6
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 00151a6911d80026
[info] Getting ApNonce in recovery mode... [data] 9C3C28FD7E9CD791C5A0F73824393DCEDF8E5BA245F096CD67 425238AC19A8C7
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 94A8F7637100C4D4C0EA27D5BFAB861D9BCC909C
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
Filesystem file not found!
We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_8.1_19R570_n121bAP_GPS_Restore_42mm/018-59188-082.dmg
[info] Extracting filesystem
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (769060 bytes)...
[info] Device ecid 00151a6911d80026 disconnect detected!
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7429.40.94
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@132~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (9311 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 018-59001-088.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15580 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 018-59001-088.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (84181346 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n121bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (32393 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2480706 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (14362922 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device c2877b528f41a40301664643e72e16240fe80bc6 has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 26
[info] ChipID: 32772
[info] UniqueChipID: 5940013084180518
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n121b.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting recoverymode@132~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1697 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Checkpoint 1562 complete with code 0
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[erro] Unable to send data to ASR.Sent 0 of 20 bytes.
[erro] Unable to send chunk checksum
[erro] Unable to send payload to ASR
[erro] Unable to send filesystem
[erro] Unable to successfully restore device
[info] Checkpoint 1627 complete with code 1100
[erro] Unable to restore device
[done] Operation finished!
[info] device disconnect...
Old 11-15-2021, 12:03   #2 (permalink)
Member: 2294526
UnhandledStatusMessage1.plist
ErrorLog1.plist
in RAR
Old 11-15-2021, 13:27   #3 (permalink)
Member: 2277861
Thanks Meter: 210
firmware from 8.0 start changed , so you have related error is normal , but we can try to help you out !
So Can you please post more details about the device situation ?
Old 11-16-2021, 09:06   #4 (permalink)
Member: 2294526
Initially, the watch hung on the apple, due to the failure of the update via the iPhone. Then I started flashing them through the ibus with firmware 8.0. They were flashed (but not immediately, but only with version 3.7.1), rebooted and hung on the apple after a while. Then I tried to flash them and all the time I get the same error, which is at 8.0.1, which is at 8.1
Old 11-16-2021, 14:47   #5 (permalink)
Member: 2277861
Thanks Meter: 210
try click error 14 option and do restore !
it will keep retry multi times when done !
if can not , you need check the watch hardware
Old 11-17-2021, 08:21   #6 (permalink)
Member: 2294526
what does it mean? Can be more?
Old 11-17-2021, 08:33   #7 (permalink)
Member: 2294526
Log with error 14
[info] Getting ApNonce in recovery mode... [data] 95DD07E3EA782A3A3B79DF49776626B49834D9BE791B647F38 1159A8E50BA778
[info] Getting SepNonce in recovery mode... [data] 0E014D58A34D2A0BCE56575A883A77159A02E431
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_8.1_19R570_n121bAP_GPS_Restore_42mm/018-59188-082.dmg'
[info] BoardID: 26
[done] Ctrl handshake done (ConnPort = 49161)
[info] Restarting flash procedure!
[erro] can't connect to restored on device with UDID c2877b528f41a40301664643e72e16240fe80bc6
[info] using cached version data
[info] Found device in Normal mode
[info] Gettting normal mode device ...
[erro] Unable to connect to device!
[info] Waiting for device arrival (timeout 10.000000 seconds)
[erro] Unable to discover device mode. Please make sure a device is attached.
Old 11-17-2021, 12:04   #8 (permalink)
Member: 2294526
Full log after repeat restore with error 14
Old 11-17-2021, 12:07   #9 (permalink)
Member: 2294526
and errors appeared at different times of the firmware.
Old 11-17-2021, 15:42   #10 (permalink)
Member: 2277861
Thanks Meter: 210
The last steps watch will working itself , so confirm this is hardware issue , possible arm
Page generated in 0.27607 seconds with 9 queries
