Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 07-20-2022, 15:19   #1 (permalink)
Member: 2642070
Thanks Meter: 15
apple watch s3 error -256
[info] Using local file F:\02.APPLE WATCH 8.0\Watch3,4_8.6_19T572_Restore.ipsw
[info] using cached version data
[warn] Incorrect driver detected! Please wait to update the drivers!
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n121bap, Watch3,4
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.6
[data] Product Build: 19T572 Major: 19
[info] device serial number is FHLWH8LRJ5X5
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 000911d438f8e0a6
[info] Getting ApNonce in recovery mode... [data] 0B85E8BAD4C2C00EB955063EACA0E56D2D427CC38C716EB2AD B2EDEEB8B1E12C
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 0D11099B656E91A739AD716D52F8D1F836D49B41
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/Watch3,4_8.6_19T/078-12001-086.dmg'
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[warn] Tag not processed for iBEC!
[info] Sending iBEC (773161 bytes)...
[info] Device ecid 000911d438f8e0a6 disconnect detected!
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7459.120.62.0.3
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@132~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[warn] Tag not processed for AppleLogo!
[info] Sending AppleLogo (9313 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 078-11777-090.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15624 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 078-11777-090.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[warn] Tag not processed for RestoreRamDisk!
[info] Sending RestoreRamDisk (84818786 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n121bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (32392 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2337346 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (14630140 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 72f4177f0936000db8b6db76dbb6f8b0880c4dbe has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 26
[info] ChipID: 32772
[info] UniqueChipID: 2552877976969382
[info] ProductionMode: true
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49162)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[warn] Tag not processed for LLB!
[info] Extracting dali-ui.n121b.release.im4p...
[info] Personalizing IMG4 component Dali...
[warn] Tag not processed for Dali!
[info] Personalizing IMG4 component DeviceTree...
[warn] Tag not processed for DeviceTree!
[info] Extracting recoverymode@132~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[warn] Tag not processed for RecoveryMode!
[info] Extracting iBoot.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[warn] Tag not processed for iBoot!
[info] Personalizing IMG4 component SEP...
[warn] Tag not processed for SEP!
[info] Sending NORData now...
[info] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Unmounting filesystems (29)
[erro] Could not read data (-256). Aborting.
[erro] Unable to restore device
[info] device disconnect...
[done] Operation finished!
what is this problem and how will they slove it?
Old 07-20-2022, 18:37   #2 (permalink)
Member: 2277861
Thanks Meter: 210
Check hardware that related with screen
Page generated in 0.13022 seconds with 8 queries
