09-13-2021, 15:24 | #1 (permalink) |
Insane Poster Join Date: Mar 2014 Location: phagwara Age: 31
Member: 2145940 Status: Offline Sonork: 1001653706 Thanks Meter: 12 | apple watch s3 flashing error [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [erro] Device is in an invalid state [data] Device supports Image4: false [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [erro] Device is in an invalid state [erro] Unable to find device ECID [done] Operation finished! [info] Using LOCAL IPSW C:\Users\shopp\Downloads\MFC_Watch3,4_7.6.1_18U70_ n121bAP_GPS_Restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [info] device serial number is GJ9Z84W2J5X4 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000a32ce1a0b0026 [info] Getting ApNonce in recovery mode... [data] FAEC1ED223A08353CFEE4F7DE2EDE16BD97017B197747B7637 D9466C3A766377 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] B1884E11ACFC6B6A730BAF98B427199A214703B2 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42mm/018-33222-073.dmg [info] Extracting filesystem [info] Found ECID 000a32ce1a0b0026 [info] Getting ApNonce in recovery mode... [data] FAEC1ED223A08353CFEE4F7DE2EDE16BD97017B197747B7637 D9466C3A766377 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] B1884E11ACFC6B6A730BAF98B427199A214703B2 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 000a32ce1a0b0026 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32229 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 000a32ce1a0b0026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device ffffffffffffffffffffffffffffffff0000000b has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 2870610548686886 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49162) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [info] device disconnect... [done] Operation finished! |
09-13-2021, 16:28 | #2 (permalink) |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 205 | hello, very interesting the logs Device ffffffffffffffffffffffffffffffff0000000b has successfully entered restore mode Are you sure you are using software 3.7 ? |
The Following User Says Thank You to mfcsupport For This Useful Post: |
09-14-2021, 07:15 | #3 (permalink) | |
Member: 2145940 Status: Offline Sonork: 1001653706 Thanks Meter: 12 | i have flashed in v3.7 i got same error Quote:
[info] Using LOCAL IPSW C:\Users\shopp\Downloads\MFC_Watch3,4_7.6.1_18U70_ n121bAP_GPS_Restore_42mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000a32ce1a0b0026 [info] Getting ApNonce in dfu mode... [data] 07F5A4064F2D73966551FD3FD2A1229D9304853A743CE40EAE 88609C56B32490 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 5C0B4A31666361C4614C3955B63B4B6133D11CBC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42mm/018-33222-073.dmg' [info] Found ECID 000a32ce1a0b0026 [info] Getting ApNonce in dfu mode... [data] 07F5A4064F2D73966551FD3FD2A1229D9304853A743CE40EAE 88609C56B32490 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 5C0B4A31666361C4614C3955B63B4B6133D11CBC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000a32ce1a0b0026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 07 f5 a4 06 4f 2d 73 96 65 51 fd 3f d2 a1 22 9d 93 04 85 3a 74 3c e4 0e ae 88 60 9c 56 b3 24 90 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 000a32ce1a0b0026 disconnect detected! [info] device serial number is GJ9Z84W2J5X4 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32229 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 000a32ce1a0b0026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 2b3adc1023dfcae4f1874b68665bf0ec5ec154d7 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 2870610548686886 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49162) [warn] Requesting NOT TO Update Baseband [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] device disconnect... [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [done] Operation finished! | |
