08-16-2021, 17:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2011 Location: gori, georgia
Member: 1549859 Status: Offline Thanks Meter: 13 | APPLE WATCH S5 40 mm ASR was unable to open the filesystem file Unable to send filesystem Unable to successfully restore device : please see last log can anyone help? I am new user Starting ... Using LOCAL IPSW E:\AW\apple watch 5 40mm\MFC_Watch5,1_7.6.1_18U70_n144sap_GPS_Restore_ 40mm.ipsw using cached version data Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S5, n144sap, Watch5,1 Extracting BuildManifest from ipsw Product Version: 7.6.1 Product Build: 18U70 Major: 18 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 001414443a53002e Getting ApNonce in dfu mode... 3D875E3B002FC3DE391F5EF378A4E4398B00080C7102186062 B6F243FCB0482C tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 6EF40EEC865353A0B3D314A9C99107AE53826CF2 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch5,1_7.6.1_18U70_n144sap_GPS_Restore_40mm/018-33016-073.dmg Waiting for other party to process iDeviceTools/MFC_Watch5,1_7.6.1_18U70_n144sap_GPS_Restore_40mm/018-33016-073.dmg ! Processing completed, resuming now ... Waiting for other party to process iDeviceTools/MFC_Watch5,1_7.6.1_18U70_n144sap_GPS_Restore_40mm/018-33016-073.dmg ! Processing completed, resuming now ... Extracting filesystem Found ECID 001414443a53002e Getting ApNonce in dfu mode... 3D875E3B002FC3DE391F5EF378A4E4398B00080C7102186062 B6F243FCB0482C tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 6EF40EEC865353A0B3D314A9C99107AE53826CF2 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Extracting iBSS.n144s.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (1134820 bytes)... If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 001414443a53002e disconnect detected! Waiting for device arrival (timeout 20.000000 seconds) Found device in Recovery mode Noce: 3d 87 5e 3b 00 2f c3 de 39 1f 5e f3 78 a4 e4 39 8b 00 08 0c 71 02 18 60 62 b6 f2 43 fc b0 48 2c Extracting iBEC.n144s.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (1134820 bytes)... Device ecid 001414443a53002e disconnect detected! device serial number is FHLCD2NPMLTH Recovery Mode Environment: iBoot build-version=iBoot-6723.140.2 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@394~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (10137 bytes)... No path for component ACIBT in TSS, will fetch from build_identity Extracting BT_FW_m9.im4p... Personalizing IMG4 component ACIBT... Sending ACIBT (1786649 bytes)... No path for component ACIWIFI in TSS, will fetch from build_identity Extracting wifi_armv7r_m9_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending ACIWIFI (1861405 bytes)... No path for component ANE in TSS, will fetch from build_identity Extracting h11_ane_fw_mercury.im4p... Personalizing IMG4 component ANE... Sending ANE (1730909 bytes)... No path for component AOP in TSS, will fetch from build_identity Extracting aopfw-watch5aop.im4p... Personalizing IMG4 component AOP... Sending AOP (1870997 bytes)... No path for component GFX in TSS, will fetch from build_identity Extracting armfw_g11m.im4p... Personalizing IMG4 component GFX... Sending GFX (848101 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 018-33330-074.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (16358 bytes)... No path for component SCE in TSS, will fetch from build_identity Extracting scefw.im4p... Personalizing IMG4 component SCE... Sending SCE (20341 bytes)... No path for component SIO in TSS, will fetch from build_identity Extracting SmartIOFirmware_ASCv2.im4p... Personalizing IMG4 component SIO... Sending SIO (1160145 bytes)... No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Sending WCHFirmwareUpdater (31700 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 018-33330-074.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (82728088 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n144sap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (42516 bytes)... No path for component RestoreSEP in TSS, will fetch from build_identity Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Sending RestoreSEP (5283198 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch5... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (12124925 bytes)... Device ecid 001414443a53002e disconnect detected! About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device 00008006-001414443A53002E has successfully entered restore mode Hardware Information: BoardID: 16 ChipID: 32774 UniqueChipID: 5651782803062830 ProductionMode: true Previous restore exit status: 0x100 Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49158) Requesting Update Baseband About to send RootTicket... Sending RootTicket now... Done sending RootTicket Waiting for NAND (28) Updating NAND Firmware (58) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n144s.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@394~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n144s.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n144sap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@394~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Extracting iBoot.n144s.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Unmounting filesystems (29) About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Checking for uncollected logs (44) Unmounting filesystems (29) Creating partition map (11) Creating filesystem (12) About to send filesystem... Connected to ASR ASR was unable to open the filesystem file Unable to send filesystem Unable to successfully restore device Status message: Unhandled status message (1100). Saving to UnhandledStatusMessage.plist Unhandled status message Log is available in ErrorLog.plist Waiting for program to exit ... |
08-17-2021, 09:55 | #4 (permalink) |
Member: 1549859 Status: Offline Thanks Meter: 13 | 3.4.0 iPOWER X - Searching ... Unable to login, please check your username, password and be sure device is conencted! Server init state unknown Login failed with no other informations provided! Server init state unknown Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - No connection could be made because the target machine actively refused it. No connection could be made because the target machine actively refused it. Server init state connect failed Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - No connection could be made because the target machine actively refused it. No connection could be made because the target machine actively refused it. Server init state connect failed Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - No connection could be made because the target machine actively refused it. No connection could be made because the target machine actively refused it. Server init state connect failed Waiting for program to exit ... Could not stop operation ! No current device selected! iPOWER X - Searching ... News: Welcome to our Online Server Server init state success Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] Arrival USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] ECID:5651782803062830 ProductType:Apple Watch S5 ECID:5651782803062830 ProductType:Apple Watch S5 Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] Arrival USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] Arrival USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] Starting ... Using LOCAL IPSW E:\AW\apple watch 5 40mm\MFC_Watch5,1_7.6.1_18U70_n144sap_GPS_Restore_ 40mm.ipsw Loading version data from Apple Server Updated version data. Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Found device in DFU mode Gettting dfu mode device ... Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Identified device as Apple Watch S5, n144sap, Watch5,1 Extracting BuildManifest from ipsw Product Version: 7.6.1 Product Build: 18U70 Major: 18 Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 001414443a53002e Getting ApNonce in dfu mode... B7E5C39C0B415C6799F6790F9B43DD8B49F87DF239AFA15894 5AD3FC0074E0D6 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 917A43D3F3ADE74F0D0ADCCBC5AFB105B2F27319 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch5,1_7.6.1_18U70_n144sap_GPS_Restore_40mm/018-33016-073.dmg Extracting filesystem Found ECID 001414443a53002e Getting ApNonce in dfu mode... B7E5C39C0B415C6799F6790F9B43DD8B49F87DF239AFA15894 5AD3FC0074E0D6 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 917A43D3F3ADE74F0D0ADCCBC5AFB105B2F27319 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Extracting iBSS.n144s.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (1134820 bytes)... Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:001414443A53002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 001414443a53002e disconnect detected! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Waiting for device arrival (timeout 20.000000 seconds) Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:001414443A53002E_IBFL:3 C_SRNM:[FHLCD2NPMLTH] Found device in Recovery mode Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Noce: b7 e5 c3 9c 0b 41 5c 67 99 f6 79 0f 9b 43 dd 8b 49 f8 7d f2 39 af a1 58 94 5a d3 fc 00 74 e0 d6 Extracting iBEC.n144s.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (1134820 bytes)... Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Device ecid 001414443a53002e disconnect detected! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! Incorrect driver detected! Please wait to update the drivers! Alternative driver is not installed! Please install it first and reboot your computer! device serial number is FHLCD2NPMLTH Recovery Mode Environment: iBoot build-version=iBoot-6723.140.2 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@394~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (10137 bytes)... No path for component ACIBT in TSS, will fetch from build_identity Extracting BT_FW_m9.im4p... Personalizing IMG4 component ACIBT... Sending ACIBT (1786649 bytes)... Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:001414443A53002E_IBFL:3 C_SRNM:[FHLCD2NPMLTH] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:001414443A53002E_IBFL:3 C_SRNM:[FHLCD2NPMLTH] No path for component ACIWIFI in TSS, will fetch from build_identity Extracting wifi_armv7r_m9_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending ACIWIFI (1861405 bytes)... No path for component ANE in TSS, will fetch from build_identity Extracting h11_ane_fw_mercury.im4p... Personalizing IMG4 component ANE... Sending ANE (1730909 bytes)... No path for component AOP in TSS, will fetch from build_identity Extracting aopfw-watch5aop.im4p... Personalizing IMG4 component AOP... Sending AOP (1870997 bytes)... No path for component GFX in TSS, will fetch from build_identity Extracting armfw_g11m.im4p... Personalizing IMG4 component GFX... Sending GFX (848101 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 018-33330-074.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (16358 bytes)... No path for component SCE in TSS, will fetch from build_identity Extracting scefw.im4p... Personalizing IMG4 component SCE... Sending SCE (20341 bytes)... No path for component SIO in TSS, will fetch from build_identity Extracting SmartIOFirmware_ASCv2.im4p... Personalizing IMG4 component SIO... Sending SIO (1160145 bytes)... No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Sending WCHFirmwareUpdater (31700 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 018-33330-074.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (82728088 bytes)... Unable to send RestoreRamDisk component: Unable to find device Unable to send RestoreRamDisk to device. Unable to send Ramdisk Unable to place device into restore mode Failed Operation finished! Waiting for program to exit ... |
08-18-2021, 15:51 | #7 (permalink) |
Member: 1549859 Status: Offline Thanks Meter: 13 | can you explain what means this error? this error when marked skip verify etting ApNonce in dfu mode... tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Unable to find required ApSepNonce in parameters tts>Unable to add img4 tags to TSS request Unable to get SHSH blobs for this device Failed Operation finished! Waiting for program to exit ... |
08-19-2021, 18:01 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Go device manager uninstall driver | |
