06-21-2018, 09:50 | #1 (permalink) |
Freak Poster Join Date: Nov 2000 Age: 46
Member: 2564 Status: Offline Thanks Meter: 1 | Apple Watch Series 3 restore error [info] [info] Starting ... [info] Using LOCAL IPSW C:\MFC.bak\MFC_Watch3.3_15T212_4.3_n121sAP_GPS_Res tore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3 [data] Product Build: 15T212 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 7324320003530918 [info] Getting ApNonce in dfu mode... [data] 6BE2411A39784EAF6E93F387C6CB432EB8A654A0FD154C7206 4E21DFCA0F0484 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] CD551ABB063F4F66792C32B137F950F01022E4E0 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3.3_15T212_4.3_n121sAP_GPS_Restore_38mm/048-01751-096.dmg' [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Sending iBSS (711055 bytes)... [info] Noce: 6b e2 41 1a 39 78 4e af 6e 93 f3 87 c6 cb 43 2e b8 a6 54 a0 fd 15 4c 72 06 4e 21 df ca 0f 04 84 [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Sending iBEC (711055 bytes)... [info] device serial number is FHLVRKPUJ5X1 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.50.126 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Sending AppleLogo (8117 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-01761-096.dmg... [info] Sending RestoreRamDisk (83305676 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121sap.im4p... [info] Sending RestoreDeviceTree (103647 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Sending RestoreKernelCache (13929264 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 394dadf5cc3a1823d9e9d329d94de9227389ce17 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 24 [info] ChipID: 32772 [info] UniqueChipID: 7324320003530918 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49166) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Extracting applelogo@115~watch.im4p... [info] Extracting dali-ui.n121s.release.im4p... [info] Extracting DeviceTree.n121sap.im4p... [info] Extracting recoverymode@115~watch.im4p... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 085BBA30 got sync message [info] Connecting to FDR client at port 49166 [warn] FDR 0AE81720 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [erro] Unable to send data to ASR.Sent 0 of 1450 bytes. [erro] Unable to send filesystem payload [erro] Unable to send payload to ASR [erro] Unable to send filesystem [erro] Unable to successfully restore device [info] Fail [erro] Unable to restore device [info] Failed [info] Apple device disconnected! |
