01-15-2021, 11:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 998040 Status: Offline Sonork: 100.151982 Thanks Meter: 33 | Watch 3 again eeror HERE IS LOG [info] Using LOCAL IPSW E:\apple\WATCH firmware\MFC_Watch3,4_7.2_18S563_n121bAP_GPS_Resto re_42mm.ipsw [info] Applying user custom flags ! [info] using cached version data [info] Device ecid (180420646) added! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.2 [data] Product Build: 18S563 Major: 18 [info] device serial number is GJ9YPAE0J5X4 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 3996076407324710 [info] Getting ApNonce in recovery mode... [data] E4E5EDD0C70D432BB8DBE0BB3324FAF3EA12B314C2CE43CACF 3453EE74E83110 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] DB3DAE466B912183947B8B3802636830BA51444B [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.2_18S563_n121bAP_GPS_Restore_42mm/038-82537-072.dmg' [info] Found ECID 3996076407324710 [info] Getting ApNonce in recovery mode... [data] E4E5EDD0C70D432BB8DBE0BB3324FAF3EA12B314C2CE43CACF 3453EE74E83110 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] DB3DAE466B912183947B8B3802636830BA51444B [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 D_SRNM:[GJ9YPAE0J5X4] [info] Device ecid 3996076407324710 disconnect detected! [info] Device ecid (180420646) removed! [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 C_SRNM:[GJ9YPAE0J5X4] [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.60.62 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-82710-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15360 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-82710-072.dmg... [info] Device ecid (180420646) added! [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (87597410 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32228 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13244106 bytes)... [warn] Device ecid 3996076407324710 disconnect not detected! It might be possible to continue! [erro] Device failed to enter Restore mode [erro] Device did not reconnect in recovery mode. Possibly invalid iBEC. Reset device and try again. [erro] Unable to place device into restore mode [done] Operation finished! [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 C_SRNM:[GJ9YPAE0J5X4] [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 D_SRNM:[GJ9YPAE0J5X4] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 D_SRNM:[GJ9YPAE0J5X4] [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 D_SRNM:[GJ9YPAE0J5X4] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 D_SRNM:[GJ9YPAE0J5X4] [info] Adding USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SC EP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3] [info] Using LATEST available IPSW. [info] Applying user custom flags ! [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Device ecid (180420646) added! [done] Operation finished! [info] Using LOCAL IPSW E:\apple\WATCH firmware\MFC_Watch3,4_7.2_18S563_n121bAP_GPS_Resto re_42mm.ipsw [info] Applying user custom flags ! [info] Device ecid (180420646) added! [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.2 [data] Product Build: 18S563 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 3996076407324710 [info] Getting ApNonce in dfu mode... [data] D803A7EC010BCF7C878FB7E944707B52766FCA46E52BA5B5B0 66B42FA5F477EE [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 81304C2C1E855A0ECF50605982CA4E66D0527D68 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.2_18S563_n121bAP_GPS_Restore_42mm/038-82537-072.dmg' [info] Found ECID 3996076407324710 [info] Getting ApNonce in dfu mode... [data] D803A7EC010BCF7C878FB7E944707B52766FCA46E52BA5B5B0 66B42FA5F477EE [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 81304C2C1E855A0ECF50605982CA4E66D0527D68 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (760868 bytes)... [info] Removing USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SC EP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3] [info] Device ecid (180420646) removed! [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 3996076407324710 disconnect detected! [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 C_SRNM:[GJ9YPAE0J5X4] [info] Found device in Recovery mode [info] Noce: d8 03 a7 ec 01 0b cf 7c 87 8f b7 e9 44 70 7b 52 76 6f ca 46 e5 2b a5 b5 b0 66 b4 2f a5 f4 77 ee [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 C_SRNM:[GJ9YPAE0J5X4] [info] Device ecid 3996076407324710 disconnect detected! [info] Device ecid (180420646) added! [info] Device ecid (180420646) removed! [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 C_SRNM:[GJ9YPAE0J5X4] [info] device serial number is GJ9YPAE0J5X4 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.60.62 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [info] Device ecid (180420646) added! [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-82340-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15184 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-82340-072.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (77555042 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32228 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13244106 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1A_ECID:000E32690AC10026_IBFL:3 C_SRNM:[GJ9YPAE0J5X4] [info] Device ecid 3996076407324710 disconnect detected! [info] Device ecid (180420646) removed! [info] Adding USB\VID_05AC&PID_12AF\5F6E112BED6A6311AC2835693645 AF88BB56583F [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 5f6e112bed6a6311ac2835693645af88bb56583f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 3996076407324710 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49162) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [info] device arrival... found. [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-82340-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-82537-072.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://17.111.103.65/TSS/controller?action=2 [info] Sending TSS request attempt 2... [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://17.111.103.15/TSS/controller?action=2 [info] Sending TSS request attempt 3... [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to http://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 4... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to http://17.111.103.65/TSS/controller?action=2 [info] Sending TSS request attempt 5... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to http://17.111.103.15/TSS/controller?action=2 [info] Sending TSS request attempt 6... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 7... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://17.111.103.65/TSS/controller?action=2 [info] Sending TSS request attempt 8... [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://17.111.103.15/TSS/controller?action=2 [info] Sending TSS request attempt 9... [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to http://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 10... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to http://17.111.103.65/TSS/controller?action=2 [info] Sending TSS request attempt 11... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to http://17.111.103.15/TSS/controller?action=2 [info] Sending TSS request attempt 12... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 13... [erro] TSS server returned: STATUS=168&MESSAGE=An internal error occurred. [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://17.111.103.65/TSS/controller?action=2 [info] Sending TSS request attempt 14... [erro] tss_send_request: Unhandled status code 168 [info] Request URL set to https://17.111.103.15/TSS/controller?action=2 [info] Sending TSS request attempt 15... [erro] tss_send_request: Unhandled status code 168 [erro] TSS request failed: SSL: no alternative certificate subject name matches target host name '17.111.103.15' (status=168) [erro] Unable to fetch SE ticket [erro] Couldn't get SE firmware data [erro] Unable to send FirmwareUpdater data [erro] Unable to successfully restore device [erro] Unable to restore device [done] Operation finished! |
