Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 01-12-2021, 04:58   #1 (permalink)
Member: 1067406
Thanks Meter: 5
Apple Watch series 5 after restore firmware 7.2 erroc not show charging
I had restore everything ok,but have problem ,not show charging when charging,how fix it sir?
Old 01-12-2021, 05:15   #2 (permalink)
Member: 1067406
Thanks Meter: 5
Series 4 44 same same, again after restore not show charging,touch not working when turnoff power cant silde
Old 01-12-2021, 07:09   #3 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
You should check your hardware , This type of hardware issue has nothing to do with restore !
You may check charger, battery and so on
Old 01-12-2021, 08:19   #4 (permalink)
Member: 1067406
Thanks Meter: 5
No sir,100% software,i tested 10 more device series 4,5,and all like 1 pan,i had send messeger your main have video clip,check mail please sir,i think you need fix firmware
Old 01-12-2021, 11:31   #5 (permalink)
Member: 79315
Thanks Meter: 6,024
i checked your 2 videos, there is really nothing can do with firmware ! and i did tested for my S5 (3 pieces), no such issue at all !
Old 01-12-2021, 11:39   #6 (permalink)
Member: 1067406
Thanks Meter: 5
I restore on series 4,5 40mm and 44mm all not show charging and can not power off,i call Teo Dubai ,reseller your service VietNam,his test and chat with you,im sure firmware error 100%
Old 01-12-2021, 13:55   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
Seems you tell me here also error but as you see ?
https://forum.gsmhosting.com/vbb/f10...-error-2938728
anyway , try to post all your restore logs, let's check
Old 01-12-2021, 15:48   #8 (permalink)
Member: 1067406
Thanks Meter: 5
but that problem is my fault,nfc error so can't restore,now I fix ok after change nfc and every ok!
this topic diffenret,can not show charging after restore,remove charge still report chảging....do you understand my problem sir?
Old 01-13-2021, 04:27   #9 (permalink)
Member: 1067406
Thanks Meter: 5
After removing the charger, it still shows the signal is charging, the% of battery does not decrease, and the% of battery increase will still indicate
Last edited by .::Gsmdenis::.; 01-13-2021 at 04:52. Reason: DON"T double post, i will not reply until you post logs
Old 01-13-2021, 14:07   #10 (permalink)
Member: 2791147
I can also confirm that this is an issue with the S4 and S5 firmware. Once applied the device will show charging even when disconnected from the charger if booted up from charge and wont allow you to power down the device.
I have tried this on 5 different i watches all did not have the issue before the firmware change, also replaced hardware and same issue still. This is 100% down to the firmware please address the issue.
S3 watches seem too be working fine after the update.
The Following User Says Thank You to SithLT For This Useful Post:
Old 01-14-2021, 03:19   #11 (permalink)
Member: 1067406
Thanks Meter: 5
I told him, but he didn't believe it and kept blaming the hardware, then asked me to post log, while I just tested and told him the error to fix
Old 01-14-2021, 07:29   #12 (permalink)
Member: 79315
Thanks Meter: 6,024
@KHANHBINH_GSM
Warning you ! If you don't want your post delete, don't post same issue in other topic !
Old 01-14-2021, 07:31   #13 (permalink)
Member: 79315
Thanks Meter: 6,024
and one more things, you may try to pair with iPhone to see if the issue still there !
Old 01-14-2021, 07:39   #14 (permalink)
Member: 79315
Thanks Meter: 6,024
After restoring with V7.2, you should start trying to pair, which means starting to set the language, and the location then becomes the pairing screen. When you connect the charger, you will see that the charging is normal. Then press the button and the power will be able turn off !
Otherwise , that's hardware issue !
Old 01-14-2021, 07:55   #15 (permalink)
Member: 1067406
Thanks Meter: 5
He has the same problem as me, and it's not just me
Page generated in 0.19767 seconds with 8 queries
