Apple Watch series 5 after restore firmware 7.2 erroc not show charging Apple Watch series 5 after restore firmware 7.2 erroc not show charging I had restore everything ok,but have problem ,not show charging when charging,how fix it sir? |
Series 4 44 same same, again after restore not show charging,touch not working when turnoff power cant silde |
You should check your hardware , This type of hardware issue has nothing to do with restore ! You may check charger, battery and so on |
i checked your 2 videos, there is really nothing can do with firmware ! and i did tested for my S5 (3 pieces), no such issue at all ! |
Seems you tell me here also error but as you see ? https://forum.gsmhosting.com/vbb/f10...-error-2938728 anyway , try to post all your restore logs, let's check |
this topic diffenret,can not show charging after restore,remove charge still report chảging....do you understand my problem sir? |
After removing the charger, it still shows the signal is charging, the% of battery does not decrease, and the% of battery increase will still indicate |
I can also confirm that this is an issue with the S4 and S5 firmware. Once applied the device will show charging even when disconnected from the charger if booted up from charge and wont allow you to power down the device. I have tried this on 5 different i watches all did not have the issue before the firmware change, also replaced hardware and same issue still. This is 100% down to the firmware please address the issue. S3 watches seem too be working fine after the update. |
@KHANHBINH_GSM Warning you ! If you don't want your post delete, don't post same issue in other topic ! |
and one more things, you may try to pair with iPhone to see if the issue still there ! |
After restoring with V7.2, you should start trying to pair, which means starting to set the language, and the location then becomes the pairing screen. When you connect the charger, you will see that the charging is normal. Then press the button and the power will be able turn off ! Otherwise , that's hardware issue ! |
