11-21-2021, 12:30 | #1 (permalink) |
Insane Poster Join Date: Jul 2020 Location: Warszawa Age: 45
Member: 2962418 Status: Offline Thanks Meter: 7 | aw4 44MM FLASH error [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.1 [data] Product Build: 19R570 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001b425a1a06002e [info] Getting ApNonce in dfu mode... [data] ABE7A4F7C7650990F5F83B9390FC177C0FDC976B3CCF90D76C AECD3BB29949A6 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 04907EE3B7274A764B09B0627D69CF4333D28CEE [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch4,2_8.1_19R570_n131bap_GPS_Restore_44mm/018-59320-081.dmg' [info] Found ECID 001b425a1a06002e [info] Getting ApNonce in dfu mode... [data] ABE7A4F7C7650990F5F83B9390FC177C0FDC976B3CCF90D76C AECD3BB29949A6 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 04907EE3B7274A764B09B0627D69CF4333D28CEE [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1110484 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001b425a1a06002e disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: ab e7 a4 f7 c7 65 09 90 f5 f8 3b 93 90 fc 17 7c 0f dc 97 6b 3c cf 90 d7 6c ae cd 3b b2 99 49 a6 [info] Extracting iBEC.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1110484 bytes)... [info] Device ecid 001b425a1a06002e disconnect detected! [info] device serial number is FH7Y585AKDH1 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7429.40.94 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10947 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1845621 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1905197 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1731589 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1866901 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (881085 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-59313-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16710 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20345 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1176673 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31828 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-59313-088.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (88321176 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39895 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5463422 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (12782453 bytes)... [info] Device ecid 001b425a1a06002e disconnect detected! [info] Waiting for device to reconnect in Restore mode... [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-001B425A1A06002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 10 [info] ChipID: 32774 [info] UniqueChipID: 7672779122278446 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49157) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Updating NAND Firmware (58) [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1697 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checkpoint 1562 complete with code 0 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Connecting to FDR client at port 49157 [info] FDR 17FCE4F0 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49157 [info] FDR 17FCE490 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49157 [info] FDR 1F48EC70 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49157 [info] FDR 1F48ED18 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49157 [info] FDR 1F48ECA0 Proxy connect request to skl.apple.com:443 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Updating AppleTCON (81) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Updating AppleTCON (81) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting 018-59320-081.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N131B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N131b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-59313-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 018-59320-081.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Extracting 018-59320-081.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting 018-59320-081.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting 018-59313-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-59320-081.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting 018-59320-081.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting 018-59313-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-59320-081.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting 018-59320-081.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting 018-59313-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-59320-081.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 18446744073709551615 [info] Checkpoint 1589 complete with code 18446744073709551615 [info] Checkpoint 1659 complete with code 18446744073709551615 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [info] Checkpoint 1608 complete with code 0 [erro] Unable to restore device [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\00008006-001B425A1A06002E any ideas whats wrong ? thx in advance |
