08-08-2021, 13:15 | #1 (permalink) |
Junior Member Join Date: Oct 2016 Location: india
Member: 2639287 Status: Offline Sonork: 100.1678441 Thanks Meter: 2 | can u plz help sir for watch 3 diag mode i many try diag mode but alwasy eroor so can u plz fix for me any desk when u free plz fix driver issu i all try u give but not put dig mode so can help me plz |
08-08-2021, 18:33 | #3 (permalink) |
Member: 2639287 Status: Offline Sonork: 100.1678441 Thanks Meter: 2 | Ok sir plz Device name LAPTOP-E6M46OM9 Processor 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz 2.42 GHz Installed RAM 8.00 GB (7.73 GB usable) Device ID 4F020AF7-940B-43A4-A6BE-064A48B8A263 Product ID 00327-35907-88134-AAOEM System type 64-bit operating system, x64-based processor Pen and touch No pen or touch input is available for this display DEVICE USERNAME CHIKUMY serial no 0x3E9B1D0F |
08-08-2021, 21:53 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | this should be working good, what exactly issue you have while you use ? Maybe this can help you https://www.mfcbox.com/tutorials/how...y-mfc-software |
08-12-2021, 12:11 | #7 (permalink) |
Member: 2639287 Status: Offline Sonork: 100.1678441 Thanks Meter: 2 | This error always Connecting... Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Uploading payload Exploit failed! Operation finished! Starting ... Device present connection uses normal backend Connecting... Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Uploading payload Exploit failed! Operation finished! Starting ... Device present connection uses normal backend Connecting... Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Uploading payload Exploit failed! Operation finished! Please select an valid communication port first! Starting ... Use alternative connection method selected Connection uses alternative backend Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Failed to overwrite task. Uploading payload Exploit failed! Operation finished! Starting ... Device present connection uses normal backend Connecting... Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Uploading payload Exploit failed! Operation finished! Starting ... Device present connection uses normal backend Connecting... Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Uploading payload Exploit failed! Operation finished! Starting ... Device present connection uses normal backend Connecting... Current thread priority is 0x0 stage 1, heap grooming ... stage 2, aquired Failed to push forward overwrite offset. stage 3, exploit Uploading payload Exploit failed! Operation finished! Waiting for program to exit ... |
08-17-2021, 18:35 | #11 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Planet Earth
Member: 79937 Status: Offline Sonork: 100.84313 Thanks Meter: 4,718 | Quote:
if you check your system Hidden devices there will be hundreds of them The simple application for this issue is "Device Cleanup Tool". Use it and you will be amazed. | |
