[info] Using LATEST available IPSW.
[info] Device ecid (271622310) added!
[info] using cached version data
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n121sap, Watch3,3
[erro] Can't find major version?!
[erro] can't get URL for latest firmware
[done] Operation finished!
[info] Using LOCAL IPSW C:\Users\admin\Downloads\MFC_Watch3,3_7.2_18S563_n 121sAP_GPS_Restore_38mm.ipsw
[info] Extracting BuildManifest from ipsw
[data] Product Version: 7.2
[data] Product Build: 18S563 Major: 18
[info] device serial number is FHLVVLESJ5X1
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 2596677369241766
[info] Getting ApNonce in recovery mode... [data] 2E9AB83292A82189387E3D5926458FB5BB354C1CA825AB0ECF F947E8D5C78762
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] BAD26A3228FFB0B9945CA468E190E2B038C0A412
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to
https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,3_7.2_18S563_n121sAP_GPS_Restore_38mm/038-82372-072.dmg'
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n121s.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (760868 bytes)...
[info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:18_ECID:000939AA1030A0A6_IBFL:3 C_SRNM:[FHLVVLESJ5X1]
[info] Device ecid 2596677369241766 disconnect detected!
[info] Device ecid (271622310) removed!
[info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:18_ECID:000939AA1030A0A6_IBFL:3 C_SRNM:[FHLVVLESJ5X1]
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-6723.60.62
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting
applelogo@115~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (8783 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 038-82340-072.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15184 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 038-82340-072.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (77555042 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n121sap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (32220 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (13244106 bytes)...
[info] Adding USB\VID_05AC&PID_12AF\E9E899758B5F34B1ED5DA2EEA342 9EAEEB25F196
[info] device arrival...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device e9e899758b5f34b1ed5da2eea3429eaeeb25f196 has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 24
[info] ChipID: 32772
[info] UniqueChipID: 2596677369241766
[info] ProductionMode: true
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] Sending RootTicket...
[done] sending RootTicket
[info] Waiting for NAND (28)
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n121s.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting
[info] Extracting dali-ui.n121s.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting
recoverymode@115~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n121s.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Extracting sep-firmware.n121s.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Unmounting filesystems (29)
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checking for uncollected logs (44)
[info] Connecting to FDR client at port 49158
[erro] FDR 0B6CD728 Unable to receive message (-4). 0/2 bytes
[erro] FDR 0C5FC800 Unable to receive message (-4). 0/2 bytes
[info] [ERROR] received partial data 0/2 (Resource temporarily unavailable)[ERROR] received partial data 0/2 (Resource temporarily unavailable)[ERROR] received partial data 0/2 (Resource temporarily unavailable)
[info] Creating partition map (11)
[info] Creating filesystem (12)
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Sending IsEarlyAccessFirmware image list
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component StaticTrustCache
[info] Sending IsFUDFirmware image list
[info] Extracting BT_FW.im4p...
[info] Personalizing IMG4 component ACIBT...
[info] Sending IsFUDFirmware for ACIBT...
[info] Extracting wifi_armv7r_m8p_rtkit_image.im4p...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Extracting aopfw-m8paop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending IsFUDFirmware for AOP...
[info] Extracting N121s_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Extracting 038-82372-072.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Updating gas gauge software (47)
[info] Updating Stockholm (55)
[info] Status message: Verification Error
[sett] Log is available in ErrorLog.plist
[erro] Unable to successfully restore device
[erro] Unable to restore device
