GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iBUS Tools For Apple Watch (https://forum.gsmhosting.com/vbb/f1023/)
-   -   disconnect during flashing watchOS 8.0 on S3 (https://forum.gsmhosting.com/vbb/f1023/disconnect-during-flashing-watchos-8-0-s3-2990813/)
pion 10-14-2021 02:33
2 Attachment(s)
first time using imfc with ibus2, i keep getting disconnecting.
i've tried 3utools, itunes, two original apple cable same problem.
any idea, do i have a defective ibus2? thanks
[warn] Another operation already in progress! Please wait...
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n121bap, Watch3,4
[info] changing mode from Recovery to Normal
[info] device serial number is FHLWD0QBJ8MT
[warn] operation not defined!
[done] Operation finished!
[info] Waiting for device arrival (timeout 10.000000 seconds)
[info] Setting the time on iOS 6 and later is only supported in the setup wizard screens before device activation.
[erro] No device found, is it plugged in ?
[info] Using LOCAL IPSW E:\Downloads\MFC_Watch3,4_8.0_19R346_n121bAP_GPS_R estore_42mm.ipsw
[info] using cached version data
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.0
[data] Product Build: 19R346 Major: 19
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 001a6bc230fb00a6
[info] Getting ApNonce in recovery mode... [data] 7E4C303FE3BC2012D710C0229904131619F2AF9FEC6F721D14 1FC1B87E67D4CE
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 07E16D09298DF8FEDD4898D391D52CA8F5F91F4C
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_8.0_19R346_n121bAP_GPS_Restore_42mm/018-78513-002.dmg'
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (769064 bytes)...
[info] Device ecid 001a6bc230fb00a6 disconnect detected!
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-7429.10.23.0.2
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting [email protected]~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (9311 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 018-78664-002.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15580 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 018-78664-002.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (83344226 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n121bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (32399 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2476610 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (14323011 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 65845ebc0498a77a46249b394c1a4c8a3c9f0b4b has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 26
[info] ChipID: 32772
[info] UniqueChipID: 7436831184060582
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[warn] Unknown message type received. Saving to UnknownMessageType.plist
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Waiting for NAND (28)
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n121b.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Unmounting filesystems (29)
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checking for uncollected logs (44)
[info] Creating partition map (11)
[info] Creating filesystem (12)
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[erro] Unable to send data to ASR.Sent 0 of 20 bytes.
[erro] Unable to send chunk checksum
[erro] Unable to send payload to ASR
[erro] Unable to send filesystem
[erro] Unable to successfully restore device
[info] device disconnect...
[erro] Could not read data (-256). Aborting.
[erro] Unable to restore device
[info] device arrival... new
[info] Arrival USB\VID_05AC&PID_12AF\65845EBC0498A77A46249B394C1A 4C8A3C9F0B4B
pion 10-14-2021 02:53
1 Attachment(s)
more picture with error.
i bought my ibus from mfcbox.com.
pion 10-14-2021 03:17
1 Attachment(s)
i almost had a sucessful flash..then disconnected.
1 Attachment(s)
i almost had a successful flash..then disconnected.
pion 10-14-2021 03:18
1 Attachment(s)
pion 10-14-2021 03:19
1 Attachment(s)
pion 10-14-2021 03:20
1 Attachment(s)
pion 10-14-2021 03:22
1 Attachment(s)
pion 10-14-2021 03:26
1 Attachment(s)
pion 10-14-2021 03:28
1 Attachment(s)
mfcsupport 10-14-2021 04:28
A software bug, will try to publish a new version those days !
pion 10-14-2021 09:12
can you remove the duplicate posts?? i think gsmhost had some issues eariler.
pion 10-14-2021 09:14
are you sure? it make no reason why itunes and 3utools also disconnect ??
.::Gsmdenis::. 10-16-2021 05:50
i did not check with other tools, but MFC new version 3.7.1 working fine
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.14286 seconds with 6 queries
