Error Apple Watch S2, n74ap, Watch2,3 nfo] [info] Starting ... [info] Using LATEST available IPSW. [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n74ap, Watch2,3 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LOCAL IPSW C:\Users\clovi\Downloads\MFC_Watch2,4_17T530_6.2.1 _n75ap_Restore_42mm.ipsw [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n74ap, Watch2,3 [info] Extracting BuildManifest from ipsw [erro] Could not make sure this firmware is suitable for the current device. Refusing to continue. [info] Failed |
The firmware is for "Watch 2,4" and your's is "watch 2,3". |
try to check this one https://www.mfcbox.com/Watch-ipsw-fi...-restore-38mm/ |
Why waiting for the solution Unable to connect to device in restore mode. I will be waiting for you put the firmware to the S2 section because u have put it in the S1 firmware section I just believe is a mistake thanks for ur understanding Regards Fon Enviado desde mi ONEPLUS A5000 mediante Tapatalk |
The firmware in same package ! eg, MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm.ipsw this for n27dap n74ap 2 models and MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm.ipsw this for n28dap n75ap 2 models |
