Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 10-12-2022, 22:55   #1 (permalink)
papu3090's Avatar
Member: 852566
Thanks Meter: 464
Error restore S5 with 8.7, running latest 4.0.1b1
[info] Using local file C:\MFC_Watch\MFC_Watch5,1_19U66_8.7_n144sap_GPS_Re store_40mm.ipsw
[info] using cached version data
[info] Found device in DFU mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S5, n144sap, Watch5,1
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.7
[data] Product Build: 19U66 Major: 19
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 000e61811400802e
[info] Getting ApNonce in dfu mode... [data] E435E138330E039E0A7601FF0AC8160424DD816A286DFB801E 34442B664F2DC0
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in dfu mode... [data] 3D726F9D25B805C5F1EE1281F9684F233202B2F7
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch5,1_19U66_8.7_n14/078-33277-073.dmg'
[info] Extracting iBSS.n144s.RELEASE.im4p...
[info] Personalizing IMG4 component iBSS...
[warn] Tag not processed for iBSS!
[info] Sending iBSS (1165221 bytes)...
[warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable!
[info] Device ecid 000e61811400802e disconnect detected!
[info] Waiting for device arrival (timeout 20.000000 seconds)
[info] Found device in Recovery mode
[info] Noce:
[info] Getting SepNonce in recovery mode... [info] device serial number is FHLZW4Hxxxxxxx
[erro] Unable to find required ApNonce in parameters
[erro] tts>Unable to add img4 tags to TSS request
[erro] Unable to get SHSH blobs for this device
[erro] Unable to place device into recovery mode from Recovery mode
[done] Operation finished!
Page generated in 0.12721 seconds with 8 queries
