08-13-2018, 22:47 | #1 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2663920 Status: Offline Thanks Meter: 0 | *FIX* no touch after screen replacement |
08-15-2018, 16:35 | #6 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2516243 Status: Offline Thanks Meter: 0 | [QUOTE=echow2001;13268695]no i didnt but for s2 it is not need right?[/QUOTE Nfc on screen aw seri 2 , seri 3 is important. When you are reset aw . You are need nfc of screen old is active AW with iphone |
08-15-2018, 17:15 | #7 (permalink) |
Crazy Poster Join Date: Oct 2015
Member: 2466640 Status: Offline Thanks Meter: 18 | Use a chisel-type blade (like Xacto #17) to remove the module. Then you can reattach it with Z-tape. If Z-tape is not available (you can get it from e.g. Adafruit) use conductive ink on the two bumps and then superglue for strength. The second method is more fiddly. The two solder points underneath the module are NFC antenna connections. |
