01-26-2021, 15:14 | #1 (permalink) |
Crazy Poster Join Date: Aug 2018
Member: 2859050 Status: Offline Thanks Meter: 4 | flash s4 first [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131sap, Watch4,1 [erro] Can't find major version?! [erro] can't get URL for latest firmware [done] Operation finished! [info] Using LOCAL IPSW C:\Users\admin\Downloads\MFC_Watch4,1_18S563_7.2_n 131sap_GPS_Restore_40mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131sap, Watch4,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.2 [data] Product Build: 18S563 Major: 18 [info] device serial number is FHLXD7V6KDH4 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001f223a26a2002e [info] Getting ApNonce in recovery mode... [data] 9ED0483CA3DA81AC5568E03BDFF84231F62B5E07AB951722C4 F6F82A6BAD9C53 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] FD62C11E346508B3B9DCFA4409189F4003F94ACF [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch4,1_18S563_7.2_n131sap_GPS_Restore_40mm/038-82911-072.dmg' [info] Found ECID 001f223a26a2002e [info] Getting ApNonce in recovery mode... [data] 9ED0483CA3DA81AC5568E03BDFF84231F62B5E07AB951722C4 F6F82A6BAD9C53 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] FD62C11E346508B3B9DCFA4409189F4003F94ACF [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n131s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1116532 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:08_ECID:001F223A26A2002E_IBFL:3 D_SRNM:[FHLXD7V6KDH4] [info] Device ecid 001f223a26a2002e disconnect detected! [info] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:08_ECID:001F223A26A2002E_IBFL:3 C_SRNM:[FHLXD7V6KDH4] [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.60.62 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@394~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10136 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1722669 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1857125 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h1 1_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1535125 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-82285-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16314 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20257 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31956 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-82285-072.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (81531544 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39598 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5201278 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11730704 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:08_ECID:001F223A26A2002E_IBFL:3 C_SRNM:[FHLXD7V6KDH4] silent [info] Device ecid 001f223a26a2002e disconnect detected! [info] Arrival USB\VID_05AC&PID_12AF\00008006-001F223A26A2002E silent [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-001F223A26A2002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 8 [info] ChipID: 32774 [info] UniqueChipID: 8763357429628974 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@394~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@394~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [ info] Extracting iBoot.n131s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [erro] Unable to receive data from ASR [erro] Unable to receive validation packet [erro] Please delete filesystem file name 'iDeviceTools/MFC_Watch4,1_18S563_7.2_n131sap_GPS_Restore_40mm/038-82911-072.dmg' from disk and try again! [erro] ASR was unable to validate the filesystem [erro] Unable to send filesystem [erro] Unable to successfully restore device [info] Status message: Fail. Hint: Please check connection or charge device battery [sett] Log is available in ErrorLog.plist [erro] Unable to restore device [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\00008006-001F223A26A2002E [info] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:08_ECID:001F223A26A2002E_IBFL:3 D_SRNM:[FHLXD7V6KDH4] |
