Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 11-15-2022, 07:28   #1 (permalink)
Member: 2078221
Sonork: 100.1603929
Have problem when flash S3
Hi MFC Team!!!
I have problem...
[info] Using local file F:\GSM\Apple\Firmware\WIOS8.7.1\MFC_Watch3,3_19U67_8.7.1_n121sAP_GPS_Restore_38mm.ipsw
[info] using cached version data
[info] Found device in DFU mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n121sap, Watch3,3
[info] Extracting BuildManifest from ipsw
File F:\GSM\Apple\Firmware\WIOS8.7.1\MFC_Watch3,3_19U67_8.7.1_n121sAP_GPS_Restore_38mm.ipsw not recognized by server!
 File size: 2773770098
 Please check if the file you downloaded is complete! Aborting operation!
Firmware file might be corrupt.
  Unable to extract BuildManifest from F:\GSM\Apple\Firmware\WIOS8.7.1\MFC_Watch3,3_19U67_8.7.1_n121sAP_GPS_Restore_38mm.ipsw.
[done] Operation finished!
But i check my iBus and stiil valid
Can You check this problem?
Old 11-15-2022, 15:04   #2 (permalink)
Member: 2382052
Thanks Meter: 1,511
Originally Posted by kihmetran View Post
Hi MFC Team!!!
I have problem...
i have same problem from friday i cant flash any serie 3
Old 11-15-2022, 16:32   #3 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,027
Check ibus S2 activation if expired
Old 11-16-2022, 07:18   #4 (permalink)
Member: 2078221
Sonork: 100.1603929
Hi GSMDenis!
I check it
Valid to
4. May 07, 2023 12:02 PM
Old 11-16-2022, 09:02   #5 (permalink)
Member: 79315
Thanks Meter: 6,027
post all activation if you can
Old 11-16-2022, 10:34   #6 (permalink)
Member: 2078221
Sonork: 100.1603929
1. June 01, 2023 09:48 PM
2. February 21, 2023 05:20 PM
3. May 07, 2023 12:02 PM
5. March 26, 2024 08:42 PM
Old 11-16-2022, 16:18   #7 (permalink)
Member: 79315
Thanks Meter: 6,027
Go software settings and choose main server, apply and restart then try again
Old 11-17-2022, 11:52   #8 (permalink)
Member: 713044
same problem here ... what can i do ?
why is the account expired although it is activated until end of december 2023 ?
p.s.: switching vice-versa to main / backup server doesn't help
iBUS S2
1. MFC Customer
Activated List
1. December 23, 2023 05:27 PM
Valid Until
iBUS S2 Customer
Your account was expired, Related permissions no longer valid until you renew it again.
MFC Dongle
1. MFC Customer
Activated List
Valid Until
MFC Customer
Your MFC was activated, Please don't share account to others otherwise once detected will be blocked.
Old 11-17-2022, 15:43   #9 (permalink)
Member: 79315
Thanks Meter: 6,027
iBUS S2
1. MFC Customer
Activated List
Valid Until
iBUS S2 Customer
MFC Dongle
1. MFC Customer
Activated List
Valid Until
MFC Customer
in your post , as i can see , this 2 user accounts
if the activation in same account, will no such kindly issue
Old 11-17-2022, 16:37   #10 (permalink)
Member: 713044
no it is the same user account ... "trkcr"
can you have a look at it - what's the problem - espacially under ibus s2 ?
Old 11-17-2022, 17:47   #11 (permalink)
Member: 79315
Thanks Meter: 6,027
this account ibus s1 and s2 both are expired , if you want use you can directly renew on mfcbox.com
br.,
Denis
Page generated in 0.20719 seconds with 8 queries
