Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 04-08-2022, 08:54   #1 (permalink)
Registered User
Member: 632005
HELP file 8.5 close s4
not restore file lock shsh help pls...
[warn] The specified firmware version is either unsigned or nonexistent. Signing might be stopped!
[erro] tts>Unable to send TSS request
[erro] Unable to get SHSH blobs for this device
[done] Operation finished!
[info] Using LOCAL IPSW D:\file apw\s4\Watch4,2_8.5_19T242_Restore.ipsw
[info] using cached version data
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S4, n131bap, Watch4,2
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.5
[data] Product Build: 19T242 Major: 19
[info] device serial number is D92XH3P5KDH0
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 000a5d823ea2002e
[info] Getting ApNonce in recovery mode... [data] B7DBA9348CD6A8751488A78B6571EC6632AD06D9CEC2795F26 7B5FA3D20B8C1F
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 3CBB83963888A15243B1E5BE081B8CA18F02B4F7
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.)
Old 04-09-2022, 17:37   #2 (permalink)
Member: 2277861
Thanks Meter: 210
Waiting new firmware then
Page generated in 0.11847 seconds with 8 queries
