01-29-2021, 17:10 | #1 (permalink) |
Junior Member Join Date: May 2015
Member: 2390454 Status: Offline Thanks Meter: 0 | FDR error restoring demo iWatch 2, 42mm I can't restore some iwatches. I receive the same error: can someone help me? thanks a lot. Loading history ... Finished loading settings! iPOWER X - Searching ... Finished loading settings! iDevice module is ready! Please make sure MFC dongle is still connected! MFC server init state success Adding USB\VID_05AC&PID_1227\CPID:8002_CPRV:10_CPFM:03_SC EP:01_BDID:0E_ECID:000509D91099A526_IBFL:3C_SRTG:[IBOOT-2651.0.0.1.31] ECID:1418202774611238 ProductType:Apple Watch S2 Removing USB\VID_05AC&PID_024F\5&395C2527&0&1 Removing USB\VID_046D&PID_C517\5&395C2527&0&10 Adding USB\VID_046D&PID_C517\5&395C2527&0&3 Adding USB\VID_16D0&PID_0753\5&395C2527&0&9 > Device has firmware version 2.1 > Serial number: 0x749A73B3 Removing USB\VID_16D0&PID_0753\5&395C2527&0&9 Adding USB\VID_05AC&PID_024F\5&395C2527&0&9 Removing USB\VID_05AC&PID_024F\5&395C2527&0&9 Adding USB\VID_04D9&PID_1702\5&395C2527&0&9 Starting ... Using LOCAL IPSW D:\ipsw iWatch\MFC_Watch2,7_n28dap_42mm_Watch2,4_n75ap_42m m_6.3_17U208_restore.ipsw Loading version data from Apple Server Device ecid (278504742) added! Updated version data. Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S2, n75ap, Watch2,4 Extracting BuildManifest from ipsw Product Version: 6.3 Product Build: 17U208 Major: 17 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 1418202774611238 Getting ApNonce in dfu mode... CCD2220303A9160209529BFF0CC0C58E76D492E24FFA9B0944 AA4A9FC0EBD14B tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... E1FE541E7FEBC6D5F37C704D8553324A90331B4D Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_1 7U208_restore/038-87845-009.dmg' Found ECID 1418202774611238 Getting ApNonce in dfu mode... CCD2220303A9160209529BFF0CC0C58E76D492E24FFA9B0944 AA4A9FC0EBD14B tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... E1FE541E7FEBC6D5F37C704D8553324A90331B4D Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Extracting iBSS.n65.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (747975 bytes)... Removing USB\VID_05AC&PID_1227\CPID:8002_CPRV:10_CPFM:03_SC EP:01_BDID:0E_ECID:000509D91099A526_IBFL:3C_SRTG:[IBOOT-2651.0.0.1.31] Device ecid (278504742) removed! If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 1418202774611238 disconnect detected! Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:000509D91099A526_IBFL:3 C_SRNM:[FHLSF570HDXX] Found device in Recovery mode Noce: cc d2 22 03 03 a9 16 02 09 52 9b ff 0c c0 c5 8e 76 d4 92 e2 4f fa 9b 09 44 aa 4a 9f c0 eb d1 4b Extracting iBEC.n65.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (747975 bytes)... Device ecid (278504742) added! Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:000509D91099A526_IBFL:3 C_SRNM:[FHLSF570HDXX] Device ecid 1418202774611238 disconnect detected! Device ecid (278504742) removed! Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:000509D91099A526_IBFL:3 C_SRNM:[FHLSF570HDXX] device serial number is FHLSF570HDXX Recovery Mode Environment: iBoot build-version=iBoot-5540.144.2 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (8706 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 038-87586-010.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (13743 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 038-87586-010.dmg... Device ecid (278504742) added! Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (67956485 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n75ap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (110731 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch2... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (11149214 bytes)... Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:000509D91099A526_IBFL:3 C_SRNM:[FHLSF570HDXX] Device ecid 1418202774611238 disconnect detected! Device ecid (278504742) removed! Adding USB\VID_05AC&PID_12AF\D4331F773FE0DAB0472298345788 3C25CA0E9EAF About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device d4331f773fe0dab04722983457883c25ca0e9eaf has successfully entered restore mode Hardware Information: BoardID: 14 ChipID: 32770 UniqueChipID: 1418202774611238 ProductionMode: true Previous restore exit status: 0x100 Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49159) Requesting NOT TO Update Baseband Sending RootTicket... sending RootTicket Waiting for NAND (28) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n65.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n75.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n75ap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@132~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting iBoot.n65.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n75.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n75.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Unmounting filesystems (29) Checking filesystems (15) About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Connecting to FDR client at port 49159 FDR 0C589840 Unable to receive message (-4). 0/2 bytes Unmounting filesystems (29) Creating partition map (11) Creating filesystem (12) About to send filesystem... Connected to ASR Validating the filesystem Filesystem validated Sending filesystem now... UniqueDeviceID:d4331f773fe0dab04722983457883c25ca0 e9eaf device arrival... found. [ERROR] received partial data 0/2 (Resource temporarily unavailable) sending filesystem Operation: Verifying restore (14) Checking filesystems (15) Creating Protected Volume (67) Unmounting filesystems (29) Checking filesystems (15) Mounting filesystems (16) About to send KernelCache... No path for component KernelCache in TSS, will fetch from build identity Extracting kernelcache.release.watch2... Personalizing IMG4 component KernelCache... Sending KernelCache ... Done sending KernelCacheInstalling kernelcache (27) About to send DeviceTree... No path for component DeviceTree in TSS, will fetch from build identity Extracting DeviceTree.n75ap.im4p... Personalizing IMG4 component DeviceTree... Sending DeviceTree ... Done sending DeviceTreeInstalling DeviceTree (61) Connecting to FDR client at port 49159 FDR 0C5897B0 Unable to receive message (-4). 0/2 bytes [ERROR] received partial data 0/2 (Resource temporarily unavailable) Connecting to FDR client at port 49159 FDR 0C4B1B20 Proxy connect request to gg.apple.com:443 Status message: Failed to recover FDR data. Failed to recover FDR data. Log is available in ErrorLog.plist Unable to successfully restore device Unable to restore device Failed Operation finished! Removing USB\VID_05AC&PID_12AF\D4331F773FE0DAB0472298345788 3C25CA0E9EAF device disconnect... Adding USB\VID_05AC&PID_1227\CPID:8002_CPRV:10_CPFM:03_SC EP:01_BDID:0E_ECID:000509D91099A526_IBFL:3C_SRTG:[IBOOT-2651.0.0.1.31] Waiting for program to exit ... |
01-30-2021, 17:38 | #3 (permalink) |
Member: 2390454 Status: Offline Thanks Meter: 0 | UPGRADED TO 3.4. ITUNES LAST VERSION, BUT SAME ERROR: Using LOCAL IPSW D:\ipsw iWatch\MFC_Watch2,7_n28dap_42mm_Watch2,4_n75ap_42m m_6.3_17U208_restore.ipsw using cached version data Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S2, n75ap, Watch2,4 Extracting BuildManifest from ipsw Product Version: 6.3 Product Build: 17U208 Major: 17 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 001309dc38320d26 Getting ApNonce in dfu mode... 1808E3C1680AEB4E5410437763CDD7810F3E9207C3E6EEB982 C93B084C0FEBBD tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 1AFE9E158E01DCED9AA87D5D1EE4605BEF011522 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_1 7U208_restore/038-87845-009.dmg' Found ECID 001309dc38320d26 Getting ApNonce in dfu mode... 1808E3C1680AEB4E5410437763CDD7810F3E9207C3E6EEB982 C93B084C0FEBBD tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 1AFE9E158E01DCED9AA87D5D1EE4605BEF011522 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Extracting iBSS.n65.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (747975 bytes)... Removing USB\VID_05AC&PID_1227\CPID:8002_CPRV:10_CPFM:03_SC EP:01_BDID:0E_ECID:001309DC38320D26_IBFL:3C_SRTG:[IBOOT-2651.0.0.1.31] If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 001309dc38320d26 disconnect detected! Waiting for device arrival (timeout 20.000000 seconds) Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:001309DC38320D26_IBFL:3 C_SRNM:[FH7T73H5HDY3] Found device in Recovery mode Noce: 18 08 e3 c1 68 0a eb 4e 54 10 43 77 63 cd d7 81 0f 3e 92 07 c3 e6 ee b9 82 c9 3b 08 4c 0f eb bd Extracting iBEC.n65.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (747975 bytes)... Device ecid 001309dc38320d26 disconnect detected! Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:001309DC38320D26_IBFL:3 C_SRNM:[FH7T73H5HDY3] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:001309DC38320D26_IBFL:3 C_SRNM:[FH7T73H5HDY3] device serial number is FH7T73H5HDY3 Recovery Mode Environment: iBoot build-version=iBoot-5540.144.2 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (8706 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 038-87586-010.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (13743 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 038-87586-010.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (67956485 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n75ap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (110731 bytes)... No path for component RestoreSEP in TSS, will fetch from build_identity Extracting sep-firmware.n75.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Sending RestoreSEP (2103233 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch2... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (11149214 bytes)... Device ecid 001309dc38320d26 disconnect detected! Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:0E_ECID:001309DC38320D26_IBFL:3 C_SRNM:[FH7T73H5HDY3] silent Arrival USB\VID_05AC&PID_12AF\7EDB479D824D88B961B17340A44C A8240AD252ED silent About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device 7edb479d824d88b961b17340a44ca8240ad252ed has successfully entered restore mode Hardware Information: BoardID: 14 ChipID: 32770 UniqueChipID: 5358865997761830 ProductionMode: true Previous restore exit status: 0x100 Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49158) Requesting NOT TO Update Baseband Sending RootTicket... sending RootTicket Waiting for NAND (28) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n65.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n75.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n75ap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@132~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting iBoot.n65.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n75.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n75.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Unmounting filesystems (29) Checking filesystems (15) About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Connecting to FDR client at port 49158 Unmounting filesystems (29) Creating partition map (11) Creating filesystem (12) About to send filesystem... Connected to ASR Validating the filesystem Filesystem validated Sending filesystem now... sending filesystem Operation: Verifying restore (14) Checking filesystems (15) Creating Protected Volume (67) Unmounting filesystems (29) Checking filesystems (15) Mounting filesystems (16) About to send KernelCache... No path for component KernelCache in TSS, will fetch from build identity Extracting kernelcache.release.watch2... Personalizing IMG4 component KernelCache... Sending KernelCache ... Done sending KernelCacheInstalling kernelcache (27) About to send DeviceTree... No path for component DeviceTree in TSS, will fetch from build identity Extracting DeviceTree.n75ap.im4p... Personalizing IMG4 component DeviceTree... Sending DeviceTree ... Done sending DeviceTreeInstalling DeviceTree (61) Connecting to FDR client at port 49158 FDR 0C568F70 Proxy connect request to gg.apple.com:443 Status message: Failed to recover FDR data. Failed to recover FDR data. Log is available in ErrorLog.plist Unable to successfully restore device Unable to restore device Failed Operation finished! Removing USB\VID_05AC&PID_12AF\7EDB479D824D88B961B17340A44C A8240AD252ED device disconnect... |
01-31-2021, 07:33 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Send this file ErrorLog.plist to [email protected] |
02-11-2021, 11:51 | #7 (permalink) | |
Member: 2390454 Status: Offline Thanks Meter: 0 | Quote:
