Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 02-28-2023, 19:30   #1 (permalink)
Member: 2442957
Thanks Meter: 5
iBus Diag error (again) - [fixed]
Dear Support!
I used iBus successfully until new update (4.1). Now drivers not working, if i can select the correct driver, i get this:
[info] Use DCSD cable selected
[info] Identified device as n121sap, Watch3,3
[info] Connecting using DFU ...
[info] Loading required files ...
[info] Finished loading required files ...
[info] Thread priority before boost is 0x0
[info] Current thread priority is 0xf
[info] Payload size: 676 overwrite offset: 05C0
[info] stage 0, reset ...
[info] stage 1, heap grooming ...
[info] Reset result: Success
[info] stage 2, aquired
[info] stage 3, exploit
[info] Uploading payload
[erro] libusb_claim_interface error -5 Entity not found
[erro] Could not find device with ECID:74C4834380026 in DFU mode!
[erro] Exploit failed! end
[done] Operation finished!
Watch status is Checkm8 after restart program, start the load diag again:
[info] Device is allready expoited!
[info] Sending FirstStage
[note] ARM reset vector detected
[warn] if device not reconnect automatically press and hold power button for 1~2 seconds and release
[info] Removed (USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_S CEP:01_BDID:18_ECID:00074C4834380026_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3]_PWND:[CHECKM8])
[info] Arrival (USB\VID_05AC&PID_1281\CPID:8004_CPRV:10_CPFM:03_S CEP:01_BDID:18_ECID:00074C4834380026_IBFL:3C_SRNM:[FHLX44Z3J5WY])
[info] Installing WINUSB driver for USBAAPL64 device: "Apple Mobile Device (Recovery Mode)" !
[warn] Failed to install driver! Error:Requested resource not found
[erro] Device does not respond after first stage! Aborting ...
When i try install the winusb driver, it say check the driver is compatible with x64 system...
Driver pack latest downloaded from site, system is Win7 x64 (was hard, but we solved the problems before), Watch updated to latest OS
No matter i use DCSD or original Lightning Cable, same result!
Please help
Thanks
Old 03-01-2023, 07:45   #2 (permalink)
Member: 2277861
Thanks Meter: 210
you can try with v3.9
Old 03-01-2023, 08:54   #3 (permalink)
Member: 2442957
Thanks Meter: 5
Thanks. This version working, but no have 9600 port speed. Now its worked relative smoothly with 115200, at backup no got communication error, at write got aborting Qsize 7, but if i write datas one by one, that was successfull. Problem solved, i think.
Thanks for support, keep it up!
Old 03-02-2023, 04:07   #4 (permalink)
Member: 2277861
Thanks Meter: 210
9600 only used while do full backup or restore backup under diag
Page generated in 0.11490 seconds with 8 queries
