Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 10-16-2023, 18:35   #1 (permalink)
Member: 2974716
[info] Status message: Ramrod firmware update failed.
Does the problem because of NFC? Will it goes through if I will disconnect NFC?
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:28_ECID:000E79923C8B402E_I BFL:3D_SRNM:[G9CGR806Q07T])
[info] Using local file C:\MFC\MFC_Watch5,9_21R360_10.0.1_n140sap_GPS_Rest ore_40mm.ipsw
[erro] We don't know firmware locations for device OS type!
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[warn] Phone model not found, please send email to [email protected], Thank you!
[info] Extracting BuildManifest from ipsw
[data] Product Version: 10.0.1
[data] Product Build: 21R360 Major: 21
[info] device serial number is G9CGR806Q0**
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] Checking for required components...
[info] Using ECID 000e79923c8b402e
[info] Getting ApNonce in recovery mode... [data] ED3E5C767C97BB66F7694A40078CE18F3B045DB4FBB1B8A955 75E4F92A0D700F
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 0FC79E2E357ED565C0B4132AED6354CEC28984AD
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[warn] Unable to find component node for Cryptex1,SystemOS
[info] Using cached file 'iDeviceTools\MFC_Watch5,9_21R360_10.0.1_n140sap_G PS_Restore_40mm\078-27448-506.dmg'
[info] Found ECID 000e79923c8b402e
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (1189285 bytes)...
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:28_ECID:000E79923C8B402E_I BFL:3D_SRNM:[G9CGR806Q07T])
[info] Device ecid 000e79923c8b402e disconnect detected!
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:28_ECID:000E79923C8B402E_I BFL:3C_SRNM:[G9CGR806Q07T])
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-10151.4.5
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (10157 bytes)...
[warn] No path for component ACIBT in TSS, will fetch from build_identity
[info] Personalizing IMG4 component ACIBT...
[info] Sending ACIBT (1985151 bytes)...
[warn] No path for component ACIWIFI in TSS, will fetch from build_identity
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending ACIWIFI (2092327 bytes)...
[warn] No path for component ANE in TSS, will fetch from build_identity
[info] Personalizing IMG4 component ANE...
[info] Sending ANE (1744039 bytes)...
[warn] No path for component AOP in TSS, will fetch from build_identity
[info] Personalizing IMG4 component AOP...
[info] Sending AOP (1604775 bytes)...
[warn] No path for component GFX in TSS, will fetch from build_identity
[info] Personalizing IMG4 component GFX...
[info] Sending GFX (881287 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (18136 bytes)...
[warn] No path for component SCE in TSS, will fetch from build_identity
[info] Personalizing IMG4 component SCE...
[info] Sending SCE (46883 bytes)...
[warn] No path for component SIO in TSS, will fetch from build_identity
[info] Personalizing IMG4 component SIO...
[info] Sending SIO (1160723 bytes)...
[warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity
[info] Personalizing IMG4 component WCHFirmwareUpdater...
[info] Sending WCHFirmwareUpdater (33222 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (100670634 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (43319 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (3399056 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (15148908 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 00008006-000E79923C8B402E has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 40
[info] ChipID: 32774
[info] UniqueChipID: 4074318661894190
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] Checkpoint 1679 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[done] sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Updating NAND Firmware (58)
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[info] Getting firmware manifest from build identity
[info] Personalizing IMG4 component LLB...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Personalizing IMG4 component RecoveryMode...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[done] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Checkpoint 1683 complete with code 0
[info] Checkpoint 1637 complete with code 0
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1686 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 1699 complete with code 0
[info] Checkpoint 1695 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1687 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checking for uncollected logs (44)
[info] Checkpoint 1561 complete with code 0
[info] Checkpoint 1562 complete with code 0
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Checkpoint 1674 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1715 complete with code 0
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Checkpoint 1676 complete with code 0
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] Checkpoint 1690 complete with code 0
[info] Checkpoint 1691 complete with code 0
[info] Checkpoint 1618 complete with code 0
[info] Checkpoint 1588 complete with code 0
[info] Checkpoint 1661 complete with code 0
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Checkpoint 4864 complete with code 0
[info] Sending IsEarlyAccessFirmware image list
[info] Checkpoint 4882 complete with code 0
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component ANE
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
[info] Found IsFUDFirmware component GFX
[info] Found IsFUDFirmware component LeapHaptics
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component SCE
[info] Found IsFUDFirmware component SIO
[info] Found IsFUDFirmware component StaticTrustCache
[info] Found IsFUDFirmware component SystemVolume
[info] Sending IsFUDFirmware image list
[info] Sending IsFUDFirmware for ACIBT...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Sending IsFUDFirmware for ANE...
[info] Sending IsFUDFirmware for AOP...
[info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
[info] Sending IsFUDFirmware for GFX...
[info] Personalizing IMG4 component LeapHaptics...
[info] Sending IsFUDFirmware for LeapHaptics...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Sending IsFUDFirmware for SCE...
[info] Sending IsFUDFirmware for SIO...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Personalizing IMG4 component SystemVolume...
[info] Sending IsFUDFirmware for SystemVolume...
[info] Checkpoint 4874 complete with code 0
[info] Updating gas gauge software (47)
[info] Checkpoint 4865 complete with code 0
[info] Checkpoint 4866 complete with code 0
[info] Updating Stockholm (55)
[info] Checkpoint 4868 complete with code 0
[info] Checkpoint 4868 complete with code 18446744073709551615
[info] Checkpoint 1589 complete with code 56
[info] Checkpoint 1659 complete with code 56
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5651 complete with code 0
[info] Checkpoint 1607 complete with code 0
Hint: The display of this model is not compatible, or you can replace the NFC module
[sett] Log is available in ErrorLog.plist
[erro] Unable to successfully restore device
[info] Checkpoint 1608 complete with code 0
[erro] Unable to restore device
[done] Operation finished!
Old 10-17-2023, 03:56   #2 (permalink)
Member: 2277861
Thanks Meter: 210
this is the issue
Page generated in 0.15771 seconds with 8 queries
