Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 06-29-2022, 01:39   #1 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 953
iWatch 3 42 GPS -- Not Pairing after SN change
As title says, I've successfully changed SN for this iWatch 3
After that I did reset the watch as mentioned by support
Even though, Watch doesn't want to pair with iPhone.
It's the same problem as HERE
But I couldn't get how he managed to solve the problem and I hope you can explain the solution for me.
Thanks in Advance
Old 06-29-2022, 05:23   #2 (permalink)
Member: 2277861
Thanks Meter: 210
You need a valid sn . bt . wifi data
Old 06-30-2022, 07:35   #3 (permalink)
Member: 2962418
Thanks Meter: 7
True - had the same issue few times and always it was problem with faulty SN
The Following User Says Thank You to JackOS78 For This Useful Post:
Old 06-30-2022, 17:30   #4 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 953
Requested a new SN,BT,WF and still the same probelm.
Can't Pair
I did also write the original SN again in order to check the problem and it asked me for the iCloud means, it can be activated but again with the new SN it can't.
[info] Device present connection uses normal backend
[info] Connecting...
[info] Device present in DFU mode using normal backend
[info] Device is allready expoited!
[info] Allready installed usb driver.
[info] Sending FirstStage
[info] Sending commands ...
[info] Sending DiagsStage
[info] Selected port: COM37
[info] Allready installed usb driver...
[info] Device is allready in Diag Mode on COM42
[done] Operation finished!
[info] Opening \\.\COM42 with baudrate 115200
[info] Opening successfull!
[info] Reading Model
Read: Model Result: MTF32
[info] Reading Serial Number
Read: Serial Number Result: -------------
[info] Reading Area/Region
Read: Area/Region Result: AE/A
[info] Reading Bluetooth Address
[info] Key: BMac Value: 0x57962BE0 0x000027CE 0x00000000 0x00000000
[info] Reading Ethernet Address
[info] Key: EMac Value: 0x44962BE0 0x0000EC86 0x00000000 0x00000000
[info] Reading Wifi Address
[info] Key: WMac Value: 0x52962BE0 0x00009DF6 0x00000000 0x00000000
[info] Reading Logicboard SN.
Read: Logicboard SN. Result: GJP04944ZDSJ0Y345
[info] Reading 'A' Number
Read: 'A' Number Result: A1859
[info] Reading LCD SN.
Read: LCD SN. Result: Not Found!
[info] Reading Battery SN.
Read: Battery SN. Result: Not Found!
[info] Reading Multitouch SN.
Read: Multitouch SN. Result: Not Found!
[info] Reading WatchFace
Read: WatchFace Result: Not Found!
[info] Reading Color
[info] Key: DClr Value: Not Found!
[info] Reading Time (RTC)
[info] RTC Time: 20220630160947
[info] Done!
[info] Writing Serial Number Key SrNm
 Finished key SrNm!
[info] Writing Bluetooth Address Key BMac
 Finished key BMac!
[info] Writing Wifi Address Key WMac
 Finished key WMac!
[info] Done!
Old 06-30-2022, 18:08   #5 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 953
Also, I want to mention that the OS version of the watch is 8.6.
I don't know if this the cause of the problem but thought it'd help mentioning.
Old 07-02-2022, 13:34   #6 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 953
Don't bother,
Problem solved with the 3rd SN from another supplier.
It's all about SN.
Thanks for help.
Page generated in 0.15171 seconds with 8 queries
