iWatch 4/5 40mm and 44mm help Hi i was talking to Gsmdenis before about my s4/5 watches not charging after firmware update and was asked for my logs but the threat has been closed so any help will be apricated, will list logs below thanks |
i closed that topic , becoz i explain all already ! A, Make complete video by MFC, let's check B, MFC Full logs C, Watch situations D, iTunes detect logs All of this ! |
I do apologise im just trying to show you my logs for Help that is all, but getting the message "An error has occurred SithLT! You must have 10 posts in order to post links. Your current post count is 5." let me just work this one out. |
any help how i can post these logs to you without having this error message as i cant see what its saying is a URL as there are non in the logs im sending thanks otherwise i will just have to post here 10 times with 10 minutes in between untill i can so sorry for the delay is that is the case. |
even if i remove all the links it still asks me to post 10 times first sorry about this |
the log will hopfuly help in the matter both ways GSMdenis seems to be trying to help, iv used there files before and its work |
i should be able to post the log in the next 10 mins so with anyluck that will help |
[info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10947 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1722669 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1857125 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1535125 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-82285-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16314 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20257 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31956 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-82285-072.dmg... [info] Device ecid (293797934) added! [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (81531544 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (41197 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11730704 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0E_ECID:00031A2E1183002E_IBFL:3 C_SRNM:[FHLYN002KDTQ] [info] Device ecid 873210094747694 disconnect detected! [info] Device ecid (293797934) removed! [info] Adding USB\VID_05AC&PID_12AF\00008006-00031A2E1183002E [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-00031A2E1183002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32774 [info] UniqueChipID: 873210094747694 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n141b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n141b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n141b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [erro] FDR 08E50E98 Unable to receive message (-4). 0/2 bytes [info] Connecting to FDR client at port 49158 [erro] FDR 0D7D9AE8 Unable to receive message (-4). 0/2 bytes [info] Connecting to FDR client at port 49158 [erro] FDR 0D7D9B18 Unable to receive message (-4). 0/2 bytes [info] Connecting to FDR client at port 49158 [erro] FDR 08E518E8 Unable to receive message (-4). 0/2 bytes [info] Unmounting filesystems (29) [info] [ERROR] received partial data 0/2 (Resource temporarily unavailable)[ERROR] received partial data 0/2 (Resource temporarily unavailable)[ERROR] received partial data 0/2 (Resource temporarily unavailable)[ERROR] received partial data 0/2 (Resource temporarily unavailable) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N141B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N141b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-82285-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 038-82313-072.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [warn] size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [warn] size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm5.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n141b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n141b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n141b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [erro] FDR 08E516A8 Unable to receive message (-4). 0/2 bytes [info] Modifying persistent boot-args (25) [info] Unknown operation (74) [info] [ERROR] received partial data 0/2 (Resource temporarily unavailable) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [info] [ERROR] received partial data 0/4 (Resource temporarily unavailable) [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\00008006-00031A2E1183002E [info] Adding USB\VID_05AC&PID_12AF\0000800600031A2E1183002E [info] device arrival... [info] Removing USB\VID_05AC&PID_12AF\0000800600031A2E1183002E [info] device disconnect... [info] Adding USB\VID_05AC&PID_12AF\0000800600031A2E1183002E [info] device arrival... |
any replay would be apricated, thanks in advanced |
i did not what i requested data, so i can not guess ! From our side , we tested and don't have such problem ! |
