04-26-2018, 12:39 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Azerbaijan,Baku Age: 39
Member: 520916 Status: Offline Sonork: 100.1605616 Thanks Meter: 53 | iWatch sign error problem how to fix Code: [info] Starting ... [info] Using LOCAL IPSW C:\Users\aze\Desktop\M F C DONGLE\MFC_Watch1,2_4.2_15S102_N28aAP_restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S0 - 1st generation, n28aap, Watch1,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH7PC2C5G9J8 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Found ECID 3253664230772 [info] Getting ApNonce in recovery mode... [data] 42B1171C86D1FF6FADF9EFFD213A45E34F30EC26 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [erro] Unable to find required ApSepNonce in parameters [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [erro] TSS server returned: STATUS=94&MESSAGE=This device isn't eligible for the requested build. [erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.) [erro] tts>Unable to send TSS request [erro] Unable to get SHSH blobs for this device [info] Failed |
The Following User Says Thank You to Elshad Ngage For This Useful Post: |
