03-12-2021, 15:22 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Planet Earth
Member: 79937 Status: Offline Sonork: 100.84313 Thanks Meter: 4,715 | (LOG) Apple Watch S3 42mm LTE Flash Success ProductType:Apple Watch S3 Starting ... Using LOCAL IPSW C:\MFC_Watch3,2_7.3_18S801_n111bAP_GPS_Cellular_Re store_42mm.ipsw using cached version data Found device in Recovery mode Gettting dfu mode device ... Identified device as Apple Watch S3, n111bap, Watch3,2 Extracting BuildManifest from ipsw Product Version: 7.3 Product Build: 18S801 Major: 18 device serial number is FH7XXXXXJ6J1 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 000a328114000026 Getting ApNonce in recovery mode... CE5FA503BE97B8CAF6840582E9DFDA88C4F2F1828640B447FE 5DE7D1599CF6E9 tts>Trying to fetch new SHSH blob Getting SepNonce in recovery mode... 126D1DC19654D3DD98DE900D1DEC5C42EFEC8D49 Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_7.3_18S801_n111bAP_GPS_Cellular_Resto re_42mm/038-95954-059.dmg' Found ECID 000a328114000026 Getting ApNonce in recovery mode... CE5FA503BE97B8CAF6840582E9DFDA88C4F2F1828640B447FE 5DE7D1599CF6E9 tts>Trying to fetch new SHSH blob Getting SepNonce in recovery mode... 126D1DC19654D3DD98DE900D1DEC5C42EFEC8D49 Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs No path for component iBEC in TSS, will fetch from build_identity Extracting iBEC.n111b.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (760868 bytes)... Device ecid 000a328114000026 disconnect detected! Recovery Mode Environment: iBoot build-version=iBoot-6723.80.19 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (9311 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 038-95880-059.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (15184 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 038-95880-059.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (77575522 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n111bap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (33392 bytes)... No path for component RestoreSEP in TSS, will fetch from build_identity Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Sending RestoreSEP (2304542 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch3... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (13255286 bytes)... Device ecid 000a328114000026 disconnect detected! About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device 6c0686bd06b3b2caf19b6f608332d7676fba18d3 has successfully entered restore mode Hardware Information: BoardID: 30 ChipID: 32772 UniqueChipID: 2870279734820902 ProductionMode: true Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49158) Requesting NOT TO Update Baseband Sending RootTicket... sending RootTicket Waiting for NAND (28) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n111b.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n111b.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n111bap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@132~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting iBoot.n111b.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Unmounting filesystems (29) About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Checking for uncollected logs (44) Connecting to FDR client at port 49158 Unmounting filesystems (29) Creating partition map (11) Creating filesystem (12) About to send filesystem... Connected to ASR Validating the filesystem Filesystem validated Sending filesystem now... sending filesystem Operation: Verifying restore (14) Unmounting filesystems (29) Checking filesystems (15) Mounting filesystems (16) Operation: Unknown operation (80) Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Flashing firmware (18) Operation: Unknown operation (80) Sending IsEarlyAccessFirmware image list Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component AOP Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component StaticTrustCache Sending IsFUDFirmware image list Extracting BT_FW.im4p... Personalizing IMG4 component ACIBT... Sending IsFUDFirmware for ACIBT... Extracting wifi_armv7r_m8p_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending IsFUDFirmware for ACIWIFI... Extracting aopfw-m8paop.im4p... Personalizing IMG4 component AOP... Sending IsFUDFirmware for AOP... Extracting N111b_Multitouch.im4p... Personalizing IMG4 component Multitouch... Sending IsFUDFirmware for Multitouch... Extracting rtpfw.im4p... Personalizing IMG4 component RTP... Sending IsFUDFirmware for RTP... Extracting 038-95880-059.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending IsFUDFirmware for RestoreTrustCache... Extracting 038-95954-059.dmg.trustcache... Personalizing IMG4 component StaticTrustCache... Sending IsFUDFirmware for StaticTrustCache... Updating gas gauge software (47) Updating Stockholm (55) Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component AOP Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component StaticTrustCache Sending IsFUDFirmware image list Updating baseband (19) About to send BasebandData... Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending Baseband TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received Received Baseband SHSH blobs Sending BasebandData now... sending BasebandData Updating Baseband in progress... About to send BasebandData... Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending Baseband TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received Received Baseband SHSH blobs Sending BasebandData now... sending BasebandData Updating Baseband completed. Updating SE Firmware (59) Extracting Stockholm4.RELEASE.sefw... Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending SE TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received Received SE ticket Sending FirmwareResponse data now... Done sending FirmwareUpdater data Unknown operation (81) Creating Protected Volume (67) About to send KernelCache... No path for component KernelCache in TSS, will fetch from build identity Extracting kernelcache.release.watch3... Personalizing IMG4 component KernelCache... Sending KernelCache ... Done sending KernelCacheInstalling kernelcache (27) About to send DeviceTree... No path for component DeviceTree in TSS, will fetch from build identity Extracting DeviceTree.n111bap.im4p... Personalizing IMG4 component DeviceTree... Sending DeviceTree ... Done sending DeviceTreeInstalling DeviceTree (61) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n111b.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n111b.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n111bap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@132~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting iBoot.n111b.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Fixing up /var (17) Creating system key bag (50) Connecting to FDR client at port 49158 Modifying persistent boot-args (25) Requesting EAN Data (74) Unmounting filesystems (29) Status message: Restore Finished Restore Finished Cleaning up... Done Operation finished! device disconnect... |
The Following User Says Thank You to .::iRizwan::. For This Useful Post: |
