Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 07-15-2020, 06:36   #1 (permalink)
Member: 1912761
Sonork: 100.1650678
Thanks Meter: 105
Apple iWatch S2 Demo remove Solution Required
Hello Sir,
I have MFC Dongle and iBus Tool which i purchased from my nearby shop in Dubai.
I just want to make sure is it possible to remove demo and make it work as Normal iWatch by restoring firmware through MFC and iBus tool?
If so, Please can you refer me a post of guide or manual? Or firmware?
Thanks
Old 07-15-2020, 18:55   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Confirm , can be done
Old 07-15-2020, 19:23   #3 (permalink)
SCORPION-1's Avatar
Member: 179938
Thanks Meter: 57
what about Apple iWatch S1 & s3 Demo ?
Old 07-16-2020, 07:18   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
This already supported when iBUS Tool launched on the market
Old 07-16-2020, 16:51   #5 (permalink)
Member: 1912761
Sonork: 100.1650678
Thanks Meter: 105
Hello Denis Sir i sent you a private message on whatsapp and skype but no reply i thought may be disconnected from social networks, and i also posted on skype group but there are alot of adverts.
So can you provide me any guidence and files?
Old 07-17-2020, 04:01   #6 (permalink)
Member: 79315
Thanks Meter: 6,024
i did not use such app about 1 year +
Email is the best !
Old 07-21-2020, 17:55   #7 (permalink)
Member: 2252444
Thanks Meter: 11
SUCCESS FINALLY FOR DEMO
[info] Using LOCAL IPSW C:\Users\user\Desktop\Series 1\MFC_Watch2,6_17T530_6.2.1_n27dap_restore_38mm.IP SW.ipsw
[info] using cached version data
[info] Found device in Recovery mode
[info] Identified device as Unknown, n27dap, Watch2,6
[info] Extracting BuildManifest from ipsw
[data] Product Version: 6.2.1
[data] Product Build: 17T530 Major: 17
[info] device serial number is FHLS7XXXXXX
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 5741142996526374
[info] Getting ApNonce in recovery mode... [data] EB827E5CAB84FB3F3B3154EAFEA3EBFC00885E60590FB56E2A E8341D691AB4E2
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 0749FF25BE0F711FE36D1608C7EEA52F2B8F9E31
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Extracting filesystem
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n27d.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (747977 bytes)...
[info] Removing USB\VID_05AC&PID_1281\CPID:8002_CPRV:10_CPFM:03_SC EP:01_BDID:02_ECID:0014658A04E9A526_IBFL:3D_SRNM:[FHLS7AK9HF1C]
[info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:02_ECID:0014658A04E9A526_IBFL:3 C_SRNM:[FHLS7AK9HF1C]
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-5540.100.194
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@115~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (8178 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 048-63605-329.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (13743 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 048-63605-329.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (68001029 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n27dap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (98335 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch2d...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (11109897 bytes)...
[info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CP FM:03_SCEP:01_BDID:02_ECID:0014658A04E9A526_IBFL:3 C_SRNM:[FHLS7AK9HF1C]
[info] Waiting for device to enter restore mode...
[info] Adding USB\VID_05AC&PID_12AF\821977927139C952F79FF744E34C D76B9D677060
[info] Apple device arrival ... searching USBMux for device after 1s
[data] UniqueDeviceID:821977927139c952f79ff744e34cd76b9d6 77060
[info] About to restore device...
[info] Waiting for device...
[info] some event ...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 821977927139c952f79ff744e34cd76b9d677060 has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 2
[info] ChipID: 32770
[info] UniqueChipID: 5741142996526374
[info] ProductionMode: true
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] Sending RootTicket...
[done] sending RootTicket
[info] Waiting for NAND (28)
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n27d.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n27d.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting recoverymode@115~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n27d.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Extracting sep-firmware.n27d.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Unmounting filesystems (29)
[info] Checking filesystems (15)
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[erro] Unable to receive message from FDR 0E377E30 (-7). 0/2 bytes
[info] Creating partition map (11)
[info] Creating filesystem (12)
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Sending OOB offset 1700915762, length 1276
[info] Sending OOB offset 0, length 72
[info] Sending OOB offset 1700916526, length 512
[info] Sending OOB offset 0, length 64
[info] Sending OOB offset 1700740413, length 176113
[info] Sending OOB offset 0, length 53
[info] Sending OOB offset 161, length 295
[info] Sending OOB offset 53, length 108
[info] Sending OOB offset 456, length 973
[info] Sending OOB offset 152516, length 280816
[info] Sending OOB offset 17656339, length 65241
[info] Sending OOB offset 1581331, length 189609
[info] Sending OOB offset 17729170, length 105158
[info] Filesystem validated
[info] Sending filesystem now...
[warn] Lockdown error: -3
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Creating Protected Volume (67)
Old 07-21-2020, 18:00   #8 (permalink)
Member: 2252444
Thanks Meter: 11
Old 07-21-2020, 18:02   #9 (permalink)
Member: 2252444
Thanks Meter: 11
[info] Mounting filesystems (16)
[warn] No path for component KernelCache in TSS, will fetch from build identity
[info] Personalizing IMG4 component KernelCache...
[info] Sending KernelCache ...
[info] Done[info] Installing kernelcache (27)
[warn] No path for component DeviceTree in TSS, will fetch from build identity
[info] Sending DeviceTree ...
[info] Done[info] Installing DeviceTree (61)
[info] Flashing firmware (18)
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component StaticTrustCache
[info] Sending IsFUDFirmware image list
[info] Extracting aopfw-n27daop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending IsFUDFirmware for AOP...
[info] Extracting N27d_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Extracting 048-63942-310.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Updating gas gauge software (47)
[info] Updating Stockholm (55)
[info] Updating SE Firmware (59)
[info] Fixing up /var (17)
[info] Creating system key bag (50)
[info] Modifying persistent boot-args (25)
[info] Status message: Restore Finished
[info] Cleaning up...
[done] Done
[done] Operation finished!
The Following User Says Thank You to IvanGtech For This Useful Post:
Old 07-21-2020, 18:04   #10 (permalink)
Member: 2252444
Thanks Meter: 11
https://ibb.co/jGBtmDw
Page generated in 0.21884 seconds with 8 queries
