05-25-2021, 19:12 | #61 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.4.1 [data] Product Build: 18T201 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00196d3a2032ef26 [info] Getting ApNonce in dfu mode... [data] BC62149D7FBB2E2961B95ED9072CF434E652001E5B87B357D3 79D3C11CDDF379 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 25F2B2B24FD4D493BF2291DAAB0C8F73C16E8FFC [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,1_7.4.1_18T201_n111sap_GPS_Cellular_Res tore_38mm/038-47881-239.dmg' [info] Found ECID 00196d3a2032ef26 [info] Getting ApNonce in dfu mode... [data] BC62149D7FBB2E2961B95ED9072CF434E652001E5B87B357D3 79D3C11CDDF379 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 25F2B2B24FD4D493BF2291DAAB0C8F73C16E8FFC [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (760868 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00196d3a2032ef26 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: bc 62 14 9d 7f bb 2e 29 61 b9 5e d9 07 2c f4 34 e6 52 00 1e 5b 87 b3 57 d3 79 d3 c1 1c dd f3 79 [info] Extracting iBEC.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Device ecid 00196d3a2032ef26 disconnect detected! [info] device serial number is FH7V9145J6DW [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.104.1 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8784 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-47945-254.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-47945-254.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78617442 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (33384 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13357179 bytes)... [info] Device ecid 00196d3a2032ef26 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device d56217938d7d1c3b724463008870b3f55fa87a8e has successfully entered restore mode [info] Hardware Information: [info] BoardID: 28 [info] ChipID: 32772 [info] UniqueChipID: 7156970833506086 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-47945-254.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-47881-239.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... |
The Following User Says Thank You to oljack For This Useful Post: |
05-25-2021, 19:35 | #62 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] Using LOCAL IPSW C:\MFC_Watch3,1_7.4.1_18T201_n111sap_GPS_Cellular_ Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [erro] Connecting to host instance 0 using TCP problem port 9421!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9421!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9421!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9421!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Could not establish conenction with server! Aborting! Firmware file might be corrupt. Unable to extract BuildManifest from C:\MFC_Watch3,1_7.4.1_18T201_n111sap_GPS_Cellular_ Restore_38mm.ipsw. [done] Operation finished! [info] Using LOCAL IPSW C:\MFC_Watch3,1_7.4.1_18T201_n111sap_GPS_Cellular_ Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.4.1 [data] Product Build: 18T201 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00076d9a14320026 [info] Getting ApNonce in dfu mode... [data] 7145C95DFFC8CA571A4F82941DB35C276ECBAAB50CA8E0B886 1C7773F476CF7C [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 09819FD298A8D05ABC49F6F8491785303AF99F83 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,1_7.4.1_18T201_n111sap_GPS_Cellular_Res tore_38mm/038-47881-239.dmg' [info] Found ECID 00076d9a14320026 [info] Getting ApNonce in dfu mode... [data] 7145C95DFFC8CA571A4F82941DB35C276ECBAAB50CA8E0B886 1C7773F476CF7C [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 09819FD298A8D05ABC49F6F8491785303AF99F83 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (760868 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00076d9a14320026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 71 45 c9 5d ff c8 ca 57 1a 4f 82 94 1d b3 5c 27 6e cb aa b5 0c a8 e0 b8 86 1c 77 73 f4 76 cf 7c [info] Extracting iBEC.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Device ecid 00076d9a14320026 disconnect detected! [info] device serial number is G99YG3ACJ6DV [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.104.1 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8784 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-47945-254.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-47945-254.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78617442 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (33384 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13357179 bytes)... [info] Device ecid 00076d9a14320026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 77e3fe38377711a734155454ae717e396787d96d has successfully entered restore mode [info] Hardware Information: [info] BoardID: 28 [info] ChipID: 32772 [info] UniqueChipID: 2090833368186918 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-47945-254.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-47881-239.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... |
The Following 2 Users Say Thank You to oljack For This Useful Post: |
06-04-2021, 14:17 | #63 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | How to Restore Apple Watch Series 1/2/3/4/5 using iBUS MFC tools(38mm,40mm,42mm,44mm) by iTouch |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
07-02-2021, 01:54 | #65 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Planet Earth
Member: 79937 Status: Offline Sonork: 100.84313 Thanks Meter: 4,718 | ★★★★★★ Post here all successfully story by iBUS S1 & S2 & S4/5 Tool ★★★★★★ Done flashing with latest MFC firmware. Here is the log: [warn] Operation aborted by user! [done] Operation finished! [info] Using LOCAL IPSW C:\Users\Rizwan\Downloads\MFC_Watch4,2_7.5_18T567_ n131bap_GPS_Restore_44mm.ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00111d020a11002e [info] Getting ApNonce in dfu mode... [data] E3C9A82FA63BF366AE4A1A379FEB0F7C5A0407A4AC5EDD1453 264BA9573A244F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] C818FF93695EF01F6A8A193989FA5C07B720C330 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44mm/018-19609-077.dmg [info] Extracting filesystem [info] Found ECID 00111d020a11002e [info] Getting ApNonce in dfu mode... [data] E3C9A82FA63BF366AE4A1A379FEB0F7C5A0407A4AC5EDD1453 264BA9573A244F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] C818FF93695EF01F6A8A193989FA5C07B720C330 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1129125 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00111d020a11002e disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: e3 c9 a8 2f a6 3b f3 66 ae 4a 1a 37 9f eb 0f 7c 5a 04 07 a4 ac 5e dd 14 53 26 4b a9 57 3a 24 4f [info] Extracting iBEC.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1129125 bytes)... [info] Device ecid 00111d020a11002e disconnect detected! [info] device serial number is G99Y83C8KDH0 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10948 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1786649 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1861453 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1735829 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16358 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20341 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31700 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (82714264 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39639 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5283198 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11752306 bytes)... [info] Device ecid 00111d020a11002e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-00111D020A11002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 10 [info] ChipID: 32774 [info] UniqueChipID: 4816969200107566 [info] ProductionMode: true [sett] Previous restore exit status: 256 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A600 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A600 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 13B5C138 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 13B62390 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 13B622A0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA0FE8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA11C8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA11E0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA1180 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA12E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA12E8 Proxy connect request to xp.apple.com:443 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N131B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N131b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 018-19609-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm5.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! |
The Following User Says Thank You to .::iRizwan::. For This Useful Post: |
07-02-2021, 14:46 | #66 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] Using LOCAL IPSW C:\MFC_Watch3,4_7.5_18T567_n121bAP_GPS_Restore_42m m(1).ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000a45a10ab88026 [info] Getting ApNonce in dfu mode... [data] 3308FC213EC538CF5FC0FFA42A282726B4168B55AE06AE7DE8 0B1A0B780EDFD0 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 362141152AE57A960A07A30473C08953411C2653 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_7.5_18T567_n121bAP_GPS_Restore_42mm(1 )/018-19590-077.dmg [info] Extracting filesystem [info] Found ECID 000a45a10ab88026 [info] Getting ApNonce in dfu mode... [data] 3308FC213EC538CF5FC0FFA42A282726B4168B55AE06AE7DE8 0B1A0B780EDFD0 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 362141152AE57A960A07A30473C08953411C2653 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773157 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000a45a10ab88026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 33 08 fc 21 3e c5 38 cf 5f c0 ff a4 2a 28 27 26 b4 16 8b 55 ae 06 ae 7d e8 0b 1a 0b 78 0e df d0 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773157 bytes)... [info] Device ecid 000a45a10ab88026 disconnect detected! [info] device serial number is GJ9C90G0J5X4 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19204-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19204-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78786402 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32223 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13381771 bytes)... [info] Device ecid 000a45a10ab88026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e416e7d9fb3e0434331e4bf4aa1512e2fa1bcaf0 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 2891307739021350 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19204-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-19590-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... |
07-03-2021, 15:37 | #67 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | ★★★★★★ Post here all successfully story by iBUS S1 & S2 & S4/5 Tool ★★★★★★ Apple watch Series 5 Restore done with software version 7.5 Firmware used : MFC_Watch5,1_7.5_18T567_n144sap_GPS_Restore_40mm.i psw News: Welcome to our Online Server Server init state success Arrival USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:000104601147002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] Starting ... Using LOCAL IPSW C:\Users\gsmanees\Downloads\MFC_Watch5,1_7.5_18T567_n144sap_GPS_Restore_40mm.i psw using cached version data Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S5, n144sap, Watch5,1 Extracting BuildManifest from ipsw Product Version: 7.5 Product Build: 18T567 Major: 18 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 000104601147002e Getting ApNonce in dfu mode... 521F1BB4864109C07CF0B28D0C0D6E0A5FE08F107B1117BFDC 1E059EC9EF39B5 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 6754F3DA333B2846DF54D07FC7ED962BA0F5EF99 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch5,1_7.5_18T567_n144sap_GPS_Restore_40mm/018-19571-077.dmg' Found ECID 000104601147002e Getting ApNonce in dfu mode... 521F1BB4864109C07CF0B28D0C0D6E0A5FE08F107B1117BFDC 1E059EC9EF39B5 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... 6754F3DA333B2846DF54D07FC7ED962BA0F5EF99 Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Extracting iBSS.n144s.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (1134773 bytes)... Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:10_ECID:000104601147002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 000104601147002e disconnect detected! Waiting for device arrival (timeout 20.000000 seconds) Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:000104601147002E_IBFL:3 C_SRNM:[FHLZND1DMLTJ] Found device in Recovery mode Noce: 52 1f 1b b4 86 41 09 c0 7c f0 b2 8d 0c 0d 6e 0a 5f e0 8f 10 7b 11 17 bf dc 1e 05 9e c9 ef 39 b5 Extracting iBEC.n144s.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (1134773 bytes)... Device ecid 000104601147002e disconnect detected! Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:000104601147002E_IBFL:3 C_SRNM:[FHLZND1DMLTJ] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:000104601147002E_IBFL:3 C_SRNM:[FHLZND1DMLTJ] device serial number is FHLZND1DMLTJ Recovery Mode Environment: iBoot build-version=iBoot-6723.120.36 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@394~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (10137 bytes)... No path for component ACIBT in TSS, will fetch from build_identity Extracting BT_FW_m9.im4p... Personalizing IMG4 component ACIBT... Sending ACIBT (1786649 bytes)... No path for component ACIWIFI in TSS, will fetch from build_identity Extracting wifi_armv7r_m9_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending ACIWIFI (1861453 bytes)... No path for component ANE in TSS, will fetch from build_identity Extracting h11_ane_fw_mercury.im4p... Personalizing IMG4 component ANE... Sending ANE (1730909 bytes)... No path for component AOP in TSS, will fetch from build_identity Extracting aopfw-watch5aop.im4p... Personalizing IMG4 component AOP... Sending AOP (1870997 bytes)... No path for component GFX in TSS, will fetch from build_identity Extracting armfw_g11m.im4p... Personalizing IMG4 component GFX... Sending GFX (848101 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 018-19158-077.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (16358 bytes)... No path for component SCE in TSS, will fetch from build_identity Extracting scefw.im4p... Personalizing IMG4 component SCE... Sending SCE (20341 bytes)... No path for component SIO in TSS, will fetch from build_identity Extracting SmartIOFirmware_ASCv2.im4p... Personalizing IMG4 component SIO... Sending SIO (1160145 bytes)... No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Sending WCHFirmwareUpdater (31700 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 018-19158-077.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (82714264 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n144sap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (42516 bytes)... No path for component RestoreSEP in TSS, will fetch from build_identity Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Sending RestoreSEP (5283198 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch5... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (12122888 bytes)... Device ecid 000104601147002e disconnect detected! Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:000104601147002E_IBFL:3 C_SRNM:[FHLZND1DMLTJ] silent Arrival USB\VID_05AC&PID_12AF\00008006-000104601147002E silent About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device 00008006-000104601147002E has successfully entered restore mode Hardware Information: BoardID: 16 ChipID: 32774 UniqueChipID: 286285629947950 ProductionMode: true Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49159) Requesting NOT TO Update Baseband Sending RootTicket... sending RootTicket Waiting for NAND (28) Updating NAND Firmware (58) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n144s.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@394~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n144s.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n144sap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@394~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Extracting iBoot.n144s.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Unmounting filesystems (29) About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Checking for uncollected logs (44) Connecting to FDR client at port 49159 Unmounting filesystems (29) Creating partition map (11) Creating filesystem (12) About to send filesystem... Connected to ASR Validating the filesystem Filesystem validated Sending filesystem now... sending filesystem Operation: Verifying restore (14) Unmounting filesystems (29) Checking filesystems (15) Mounting filesystems (16) Operation: Unknown operation (80) Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Flashing firmware (18) Operation: Unknown operation (80) Sending IsEarlyAccessFirmware image list Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component ANE Found IsFUDFirmware component AOP Found IsFUDFirmware component GFX Found IsFUDFirmware component LeapHaptics Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component SCE Found IsFUDFirmware component SIO Found IsFUDFirmware component StaticTrustCache Sending IsFUDFirmware image list Extracting BT_FW_m9.im4p... Personalizing IMG4 component ACIBT... Sending IsFUDFirmware for ACIBT... Extracting wifi_armv7r_m9_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending IsFUDFirmware for ACIWIFI... Extracting h11_ane_fw_mercury.im4p... Personalizing IMG4 component ANE... Sending IsFUDFirmware for ANE... Extracting aopfw-watch5aop.im4p... Personalizing IMG4 component AOP... Sending IsFUDFirmware for AOP... Extracting armfw_g11m.im4p... Personalizing IMG4 component GFX... Sending IsFUDFirmware for GFX... Extracting N144S_LeapHapticsFirmware.im4p... Personalizing IMG4 component LeapHaptics... Sending IsFUDFirmware for LeapHaptics... Extracting N144s_Multitouch.im4p... Personalizing IMG4 component Multitouch... Sending IsFUDFirmware for Multitouch... Extracting rtpfw.im4p... Personalizing IMG4 component RTP... Sending IsFUDFirmware for RTP... Extracting 018-19158-077.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending IsFUDFirmware for RestoreTrustCache... Extracting scefw.im4p... Personalizing IMG4 component SCE... Sending IsFUDFirmware for SCE... Extracting SmartIOFirmware_ASCv2.im4p... Personalizing IMG4 component SIO... Sending IsFUDFirmware for SIO... Extracting 018-19571-077.dmg.trustcache... Personalizing IMG4 component StaticTrustCache... Sending IsFUDFirmware for StaticTrustCache... Updating gas gauge software (47) Updating Stockholm (55) Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component ANE Found IsFUDFirmware component AOP Found IsFUDFirmware component GFX Found IsFUDFirmware component LeapHaptics Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component SCE Found IsFUDFirmware component SIO Found IsFUDFirmware component StaticTrustCache Sending IsFUDFirmware image list Updating SE Firmware (59) Extracting Stockholm5.RELEASE.sefw... Unable to find BbChipID node Unable to find BbProvisioningManifestKeyHash node Unable to find BbActivationManifestKeyHash node Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbFDRSecurityKeyHash node Unable to find BbSkeyId node Sending SE TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received Received SE ticket Sending FirmwareResponse data now... Done sending FirmwareUpdater data Unknown operation (81) Creating Protected Volume (67) About to send KernelCache... No path for component KernelCache in TSS, will fetch from build identity Extracting kernelcache.release.watch5... Personalizing IMG4 component KernelCache... Sending KernelCache ... Done sending KernelCacheInstalling kernelcache (27) About to send DeviceTree... No path for component DeviceTree in TSS, will fetch from build identity Extracting DeviceTree.n144sap.im4p... Personalizing IMG4 component DeviceTree... Sending DeviceTree ... Done sending DeviceTreeInstalling DeviceTree (61) Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n144s.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@394~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n144s.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n144sap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@394~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting WirelessPower.watch4.im4p... Personalizing IMG4 component WCHFirmwareUpdater... Extracting iBoot.n144s.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n144s.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Fixing up /var (17) Creating system key bag (50) Connecting to FDR client at port 49159 Modifying persistent boot-args (25) Requesting EAN Data (74) Unmounting filesystems (29) Status message: Restore Finished Restore Finished Cleaning up... Done Operation finished! Removing USB\VID_05AC&PID_12AF\00008006-000104601147002E Arrival USB\VID_05AC&PID_12AF\00008006000104601147002E device arrival... Removing USB\VID_05AC&PID_12AF\00008006000104601147002E device disconnect... Waiting for program to exit ... |
The Following 2 Users Say Thank You to technomak For This Useful Post: |
07-13-2021, 15:44 | #68 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | After change SN and MAC WiFi & BT: [info] Using LOCAL IPSW C:\MFC_Watch3,3_7.5_18T567_n121sAP_GPS_Restore_38m m.ipsw [info] using cached version data [warn] Incorrect driver detected! Please wait to update the drivers! [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001c55a01e928026 [info] Getting ApNonce in dfu mode... [data] B16A19E4DA760112DB544B794ECD57CD2A30B11C191BB37ABB 5BCE55C4CE038B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 6B59DBF79656DFF5B00BEF046A18D18DC7041E27 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,3_7.5_18T567_n121sAP_GPS_Restore_38mm/018-19606-077.dmg' [info] Found ECID 001c55a01e928026 [info] Getting ApNonce in dfu mode... [data] B16A19E4DA760112DB544B794ECD57CD2A30B11C191BB37ABB 5BCE55C4CE038B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 6B59DBF79656DFF5B00BEF046A18D18DC7041E27 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773157 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001c55a01e928026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: b1 6a 19 e4 da 76 01 12 db 54 4b 79 4e cd 57 cd 2a 30 b1 1c 19 1b b3 7a bb 5b ce 55 c4 ce 03 8b [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773157 bytes)... [info] Device ecid 001c55a01e928026 disconnect detected! [info] device serial number is DMVJV0FGF185 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8784 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19204-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19204-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78786402 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32221 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13381771 bytes)... [info] Device ecid 001c55a01e928026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 8dbb21af172f0541d3b0f73b28ec655f572b0c34 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 24 [info] ChipID: 32772 [info] UniqueChipID: 7975445543944230 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19204-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-19606-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... |
07-19-2021, 18:19 | #69 (permalink) |
Junior Member Join Date: May 2020 Location: USA
Member: 2957415 Status: Offline Thanks Meter: 1 | I had a problem with restoring Apple Watch that I documented in this thread and denis helped me by suggesting to replace the display flex cable. I soldered a new cable and successfully restored just now. Thanks! |
The Following User Says Thank You to thisispanthrax For This Useful Post: |
07-21-2021, 14:34 | #70 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] Device present connection uses normal backend [info] Installing USB driver for device: "Diags CDC Serial" (05AC:1222) ... [warn] Failed to install usb driver! Error:Other error [info] Device is allready in Diag Mode on COM10 [done] Operation finished! [info] Opening \\.\COM10 with baudrate 115200 [info] Opening successfull! [info] Reading Model Read: Model Result: MTF32 [info] Reading Serial Number Read: Serial Number Result: GJCDLBHPJ5X4 [info] Reading Area/Region Read: Area/Region Result: LL/A [info] Reading Bluetooth Address [info] Key: BMac Value: 0x24962BE0 -------------------------- [info] Reading Ethernet Address [info] Key: EMac Value: 0x19962BE0 -------------------------- [info] Reading Wifi Address [info] Key: WMac Value: 0x27962BE0 -------------------------- [info] Reading Logicboard SN. Read: Logicboard SN. Result: GJP0-------------------------- [info] Reading 'A' Number Read: 'A' Number Result: A1859 [info] Reading Time (RTC) [info] RTC Time: 19700101000404 [info] Done! [info] Writing Serial Number Key SrNm Finished key SrNm! [info] Writing Bluetooth Address Key BMac Finished key BMac! [info] Writing Wifi Address Key WMac Finished key WMac! [info] Done! [info] Reading Read: Result: Resetting... [info] Done! [warn] Closing communication port! [info] device arrival... found [info] device disconnect... [info] device arrival... found [info] device disconnect... [info] device arrival... new [info] device disconnect... [info] device arrival... found [info] device disconnect... [info] device arrival... found [info] device disconnect... [info] device arrival... found [info] device disconnect... [info] Using LOCAL IPSW C:\MFC_Watch3,4_7.5_18T567_n121bAP_GPS_Restore_42m m.ipsw [info] Updated version data. [warn] Incorrect driver detected! Please wait to update the drivers! [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000d105e3efb8026 [info] Getting ApNonce in dfu mode... [data] 950CDFC60A417A701275E2388EA5060F928C5686C31E84797D 074777975F6A23 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 42C5B8FEB6E2886B550A316168CB84B6B14908C9 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_7.5_18T567_n121bAP_GPS_Restore_42mm/018-19590-077.dmg [info] Extracting filesystem [info] Found ECID 000d105e3efb8026 [info] Getting ApNonce in dfu mode... [data] 950CDFC60A417A701275E2388EA5060F928C5686C31E84797D 074777975F6A23 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 42C5B8FEB6E2886B550A316168CB84B6B14908C9 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773157 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000d105e3efb8026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 95 0c df c6 0a 41 7a 70 12 75 e2 38 8e a5 06 0f 92 8c 56 86 c3 1e 84 79 7d 07 47 77 97 5f 6a 23 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773157 bytes)... [info] Device ecid 000d105e3efb8026 disconnect detected! [info] device serial number is DLXNR0L9G5V3 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19204-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19204-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78786402 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32223 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13381771 bytes)... [info] Device ecid 000d105e3efb8026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device b1c25930486515abcfe5533089cdcaf926e9b27f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 3677171666878502 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19204-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-19590-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [info] device arrival... found [info] device disconnect... Last edited by .::Gsmdenis::.; 07-21-2021 at 15:43. Reason: Physical address edited |
The Following User Says Thank You to oljack For This Useful Post: |
08-22-2021, 16:22 | #71 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] Using LOCAL IPSW C:\MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42 mm.ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000714c1180610a6 [info] Getting ApNonce in dfu mode... [data] C883BF582E2C32F1D4B99D8C695F5FEA8B385B396C9B56E3F4 D7E54792437675 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 1A58F2F38E62326A9D2C1A5FB56E881D7FB5D0CC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42mm/018-33222-073.dmg [info] Extracting filesystem [info] Found ECID 000714c1180610a6 [info] Getting ApNonce in dfu mode... [data] C883BF582E2C32F1D4B99D8C695F5FEA8B385B396C9B56E3F4 D7E54792437675 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 1A58F2F38E62326A9D2C1A5FB56E881D7FB5D0CC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000714c1180610a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [info] device serial number is DLXNQ0QGG5V3 [data] 1A58F2F38E62326A9D2C1A5FB56E881D7FB5D0CC [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773121 bytes)... [erro] Unable to send iBEC component: Unable to upload data to device [erro] Unable to send iBEC to device [erro] Unable to place device into recovery mode from Recovery mode [done] Operation finished! [info] device arrival... found [info] device disconnect... [info] Using LOCAL IPSW C:\MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42 mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000714c1180610a6 [info] Getting ApNonce in dfu mode... [data] 166F9B46C701F84C72F20876C319C4709C21B998A8760293EA 72D08E0C032F09 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] A3ED36C1CEDE8E6252060506F750C99AEFF37D6F [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_7.6.1_18U70_n121bAP_GPS_Restore_42mm/018-33222-073.dmg' [info] Found ECID 000714c1180610a6 [info] Getting ApNonce in dfu mode... [data] 166F9B46C701F84C72F20876C319C4709C21B998A8760293EA 72D08E0C032F09 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] A3ED36C1CEDE8E6252060506F750C99AEFF37D6F [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000714c1180610a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 16 6f 9b 46 c7 01 f8 4c 72 f2 08 76 c3 19 c4 70 9c 21 b9 98 a8 76 02 93 ea 72 d0 8e 0c 03 2f 09 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 000714c1180610a6 disconnect detected! [info] device serial number is DLXNQ0QGG5V3 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9312 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32229 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 000714c1180610a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 07ea73eddde65bf71d5563b9a2813aeeaa4697a4 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 1993144401268902 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] FDR 0965E028 Proxy connect request to xp.apple.com:443 [erro] FDR 0965E028 Unable to receive proxy payload (-3) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-33222-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... |
08-22-2021, 16:47 | #72 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] Using LOCAL IPSW C:\MFC_Watch3,2_7.6.1_18U70_n111bAP_GPS_Cellular_R estore_42mm(1).ipsw [info] using cached version data [warn] Incorrect driver detected! Please wait to update the drivers! [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111bap, Watch3,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0000646924d2ef26 [info] Getting ApNonce in dfu mode... [data] 0F9900E17C8616D9AD6F5DA7E02A5EB7A36E99D48B1E065EF1 A2637A9FAA211E [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 2A4E87226D068352F5651587EAAC64739561D2EC [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_7.6.1_18U70_n111bAP_GPS_Cellular_Rest ore_42mm(1)/018-33243-073.dmg' [info] Found ECID 0000646924d2ef26 [info] Getting ApNonce in dfu mode... [data] 0F9900E17C8616D9AD6F5DA7E02A5EB7A36E99D48B1E065EF1 A2637A9FAA211E [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 2A4E87226D068352F5651587EAAC64739561D2EC [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773155 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 0000646924d2ef26 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 0f 99 00 e1 7c 86 16 d9 ad 6f 5d a7 e0 2a 5e b7 a3 6e 99 d4 8b 1e 06 5e f1 a2 63 7a 9f aa 21 1e [info] Extracting iBEC.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773155 bytes)... [info] Device ecid 0000646924d2ef26 disconnect detected! [info] device serial number is FH7V71L0J6GF [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15227 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807905 bytes)... [erro] Unable to send RestoreRamDisk component: Unable to find device [erro] Unable to send RestoreRamDisk to device. [erro] Unable to send Ramdisk [erro] Unable to place device into restore mode [done] Operation finished! [info] Using LOCAL IPSW C:\MFC_Watch3,2_7.6.1_18U70_n111bAP_GPS_Cellular_R estore_42mm(1).ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111bap, Watch3,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0000646924d2ef26 [info] Getting ApNonce in dfu mode... [data] 1064C41E0D3D8104ACADC4893B2527CC3FD55902B06C0B21B8 A52560EAA43182 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 5D2A6CB13E93E65A790CB2497EC0517726CDC279 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_7.6.1_18U70_n111bAP_GPS_Cellular_Rest ore_42mm(1)/018-33243-073.dmg' [info] Found ECID 0000646924d2ef26 [info] Getting ApNonce in dfu mode... [data] 1064C41E0D3D8104ACADC4893B2527CC3FD55902B06C0B21B8 A52560EAA43182 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 5D2A6CB13E93E65A790CB2497EC0517726CDC279 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773155 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 0000646924d2ef26 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 10 64 c4 1e 0d 3d 81 04 ac ad c4 89 3b 25 27 cc 3f d5 59 02 b0 6c 0b 21 b8 a5 25 60 ea a4 31 82 [info] Extracting iBEC.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773155 bytes)... [info] Device ecid 0000646924d2ef26 disconnect detected! [info] device serial number is FH7V71L0J6GF [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15227 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807905 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (33386 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361885 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383719 bytes)... [info] Device ecid 0000646924d2ef26 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 024785a3f68cae8d23ec2142b2e815bdf41cc77c has successfully entered restore mode [info] Hardware Information: [info] BoardID: 30 [info] ChipID: 32772 [info] UniqueChipID: 110402752147238 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-33243-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n111bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... |
09-08-2021, 08:38 | #73 (permalink) |
Member: 1144374 Status: Offline Thanks Meter: 64 | [info] Using LOCAL IPSW C:\MFC_Watch3,3_7.6.1_18U70_n121sAP_GPS_Restore_38 mm.ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00070dc63a9a8026 [info] Getting ApNonce in dfu mode... [data] F4FFB58927F86E34DC682FAE5A97D70518F090F911055536F6 D5982B80B5F62D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 62D9D3FBDE885D42BEAC5BB62BFF9F0AEA7844B9 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,3_7.6.1_18U70_n121sAP_GPS_Restore_38mm/018-33342-073.dmg' [info] Found ECID 00070dc63a9a8026 [info] Getting ApNonce in dfu mode... [data] F4FFB58927F86E34DC682FAE5A97D70518F090F911055536F6 D5982B80B5F62D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 62D9D3FBDE885D42BEAC5BB62BFF9F0AEA7844B9 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00070dc63a9a8026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: f4 ff b5 89 27 f8 6e 34 dc 68 2f ae 5a 97 d7 05 18 f0 90 f9 11 05 55 36 f6 d5 98 2b 80 b5 f6 2d [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 00070dc63a9a8026 disconnect detected! [info] device serial number is GJ9CJ4Y3J5X0 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8784 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [erro] Unable to send RestoreRamDisk component: Unable to find device [erro] Unable to send RestoreRamDisk to device. [erro] Unable to send Ramdisk [erro] Unable to place device into restore mode [done] Operation finished! [info] Using LOCAL IPSW C:\MFC_Watch3,3_7.6.1_18U70_n121sAP_GPS_Restore_38 mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.1 [data] Product Build: 18U70 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00070dc63a9a8026 [info] Getting ApNonce in dfu mode... [data] CF57A932EB94D37913664EF14E221EBE384A90F3EAE226EF32 EFAD9D420A62F7 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 3E5A7A27B1705BB781A5CAE98647DC0C1F105E2F [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,3_7.6.1_18U70_n121sAP_GPS_Restore_38mm/018-33342-073.dmg' [info] Found ECID 00070dc63a9a8026 [info] Getting ApNonce in dfu mode... [data] CF57A932EB94D37913664EF14E221EBE384A90F3EAE226EF32 EFAD9D420A62F7 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 3E5A7A27B1705BB781A5CAE98647DC0C1F105E2F [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (773156 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00070dc63a9a8026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: cf 57 a9 32 eb 94 d3 79 13 66 4e f1 4e 22 1e be 38 4a 90 f3 ea e2 26 ef 32 ef ad 9d 42 0a 62 f7 [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (773156 bytes)... [info] Device ecid 00070dc63a9a8026 disconnect detected! [info] device serial number is GJ9CJ4Y3J5X0 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.140.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8784 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15228 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-33332-074.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (78807906 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32224 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2361886 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13383720 bytes)... [info] Device ecid 00070dc63a9a8026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 1b5f6eeada9ca75b88da34549e3411f669021f69 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 24 [info] ChipID: 32772 [info] UniqueChipID: 1985469874864166 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking for uncollected logs (44) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking for uncollected logs (44) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49158 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating partition map (11) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating filesystem (12) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N121s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-33332-074.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-33342-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating gas gauge software (47) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating Stockholm (55) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unknown operation (81) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating Protected Volume (67) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Fixing up /var (17) [info] Creating system key bag (50) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Connecting to FDR client at port 49158 [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Modifying persistent boot-args (25) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Requesting EAN Data (74) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [info] device arrival... found |
11-16-2021, 12:38 | #75 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | Watch OS 8.1 [info] Using LOCAL IPSW C:\MFC_Watch3,3_8.1_19R570_n121sAP_GPS_Restore_38m m.ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.1 [data] Product Build: 19R570 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001c2d121e928026 [info] Getting ApNonce in dfu mode... [data] 1748EB265C49BA853E4A727026549D90E45FD47DF7FCA6B89F 10927646EDA1DF [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] DAC437EBA33CF86B287E1E304BDA6510233C150D [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,3_8.1_19R570_n121sAP_GPS_Restore_38mm/018-59029-081.dmg [info] Extracting filesystem [info] Found ECID 001c2d121e928026 [info] Getting ApNonce in dfu mode... [data] 1748EB265C49BA853E4A727026549D90E45FD47DF7FCA6B89F 10927646EDA1DF [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] DAC437EBA33CF86B287E1E304BDA6510233C150D [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (769060 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001c2d121e928026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 17 48 eb 26 5c 49 ba 85 3e 4a 72 70 26 54 9d 90 e4 5f d4 7d f7 fc a6 b8 9f 10 92 76 46 ed a1 df [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (769060 bytes)... [info] Device ecid 001c2d121e928026 disconnect detected! [info] device serial number is GJ9CFAJTJ5WY [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7429.40.94 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8783 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-59001-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15580 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-59001-088.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (84181346 bytes)... [erro] Unable to send RestoreRamDisk component: Unable to find device [erro] Unable to send RestoreRamDisk to device. [erro] Unable to send Ramdisk [erro] Unable to place device into restore mode [done] Operation finished! [info] Using LOCAL IPSW C:\MFC_Watch3,3_8.1_19R570_n121sAP_GPS_Restore_38m m.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.1 [data] Product Build: 19R570 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001c2d121e928026 [info] Getting ApNonce in dfu mode... [data] B9893114BB4D6780473E6AEE021E9E8FCAE2CEC998BD978A53 71817EEB811BBD [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 29499A94EA1439AE3C707897A49ADC0419B84AA3 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,3_8.1_19R570_n121sAP_GPS_Restore_38mm/018-59029-081.dmg' [info] Found ECID 001c2d121e928026 [info] Getting ApNonce in dfu mode... [data] B9893114BB4D6780473E6AEE021E9E8FCAE2CEC998BD978A53 71817EEB811BBD [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 29499A94EA1439AE3C707897A49ADC0419B84AA3 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (769060 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001c2d121e928026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: b9 89 31 14 bb 4d 67 80 47 3e 6a ee 02 1e 9e 8f ca e2 ce c9 98 bd 97 8a 53 71 81 7e eb 81 1b bd [info] Extracting iBEC.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (769060 bytes)... [info] Device ecid 001c2d121e928026 disconnect detected! [info] device serial number is GJ9CFAJTJ5WY [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7429.40.94 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8783 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-59001-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15580 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-59001-088.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (84181346 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32385 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2480706 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (14362922 bytes)... [info] Device ecid 001c2d121e928026 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 718fe8b021c22e5cac93845f98922558dbb7ff1d has successfully entered restore mode [info] Hardware Information: [info] BoardID: 24 [info] ChipID: 32772 [info] UniqueChipID: 7930855193477158 [info] ProductionMode: true [sett] Previous restore exit status: 256 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49159) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1697 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49159 [info] FDR 12C23FB0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49159 [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49159 [info] FDR 0CF978F0 Proxy connect request to xp.apple.com:443 [info] Checkpoint 1563 complete with code 0 [erro] FDR 0CF978F0 Unable to receive proxy payload (-3) [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Updating AppleTCON (81) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Updating AppleTCON (81) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting 018-59029-081.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting N121s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-59001-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-59029-081.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Extracting 018-59029-081.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting 018-59029-081.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting 018-59001-088.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 018-59029-081.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Checkpoint 4870 complete with code 0 [info] Checkpoint 4871 complete with code 0 [info] Checkpoint 4872 complete with code 0 [info] Checkpoint 4878 complete with code 0 [info] Checkpoint 4879 complete with code 0 [info] Checkpoint 4875 complete with code 0 [info] Checkpoint 4867 complete with code 0 [info] Checkpoint 4880 complete with code 0 [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Checkpoint 4873 complete with code 0 [info] Unknown operation (80) [info] Checkpoint 4886 complete with code 0 [info] Checkpoint 1589 complete with code 0 [info] Checkpoint 1596 complete with code 0 [info] Checkpoint 5379 complete with code 0 [info] Unknown operation (75) [info] Checkpoint 5380 complete with code 0 [info] Checkpoint 4884 complete with code 0 [info] Checkpoint 1640 complete with code 0 [info] Checkpoint 1597 complete with code 0 [info] Checkpoint 1647 complete with code 0 [info] Resizing Main Filesystem Partition (68) [info] Checkpoint 1652 complete with code 0 [info] Checkpoint 1631 complete with code 0 [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] Checkpoint 3584 complete with code 0 [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Checkpoint 3585 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 3588 complete with code 0 [info] Checkpoint 3589 complete with code 0 [info] Checkpoint 3587 complete with code 0 [info] Checkpoint 1576 complete with code 0 [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Checkpoint 3840 complete with code 0 [info] Checkpoint 3841 complete with code 0 [info] Checkpoint 3844 complete with code 0 [info] Connecting to FDR client at port 49159 [info] Checkpoint 3849 complete with code 0 [info] Checkpoint 1613 complete with code 0 [info] Checkpoint 1694 complete with code 0 [info] Checkpoint 1595 complete with code 0 [info] Modifying persistent boot-args (25) [info] Checkpoint 1593 complete with code 0 [info] Checkpoint 1630 complete with code 0 [info] Checkpoint 1672 complete with code 0 [info] Checkpoint 1659 complete with code 0 [info] Checkpoint 5632 complete with code 0 [info] Checkpoint 1599 complete with code 0 [info] Checkpoint 1600 complete with code 0 [info] Checkpoint 1675 complete with code 0 [info] Checkpoint 1641 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1602 complete with code 0 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [warn] Lockdown error: -8 [info] device arrival... found [info] device disconnect... |
