07-28-2018, 05:38 | #6 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2516243 Status: Offline Thanks Meter: 0 | [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\phu\Desktop\MFC_Watch3,4_15T567_4.3.1_n12 1bAP_GPS_Restore_42mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.1 [data] Product Build: 15T567 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 8458379878301862 [info] Getting ApNonce in dfu mode... [data] 2C40970D58BB87883F61EA98723CA71ADF78C58523C9300E0F D8593C31FEBAD5 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 1D1A27BBD906CE018B8CCCC7A577EB24234C9D2C [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_15T567_4.3.1_n121bAP_GPS_Restore_42mm/048-11192-070.dmg' [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Sending iBSS (727438 bytes)... [info] Noce: 2c 40 97 0d 58 bb 87 88 3f 61 ea 98 72 3c a7 1a df 78 c5 85 23 c9 30 0e 0f d8 59 3c 31 fe ba d5 [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Sending iBEC (727438 bytes)... [info] device serial number is FHLVLRDRJ5X4 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.60.11 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8651 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-11278-070.dmg... [info] Sending RestoreRamDisk (83318476 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Sending RestoreDeviceTree (103646 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Sending RestoreKernelCache (13971372 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 4cc144af1539265b3fba466ba094bced32de7bc5 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 8458379878301862 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n121b.release.im4p... [info] Extracting DeviceTree.n121bap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 08EB8E98 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05D4D9E8 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [erro] Unable to receive message from FDR 08EB8E98 (-4). 0/2 bytes [info] Apple device disconnected! [info] Apple device arrival ... searching USBMux for device after 100ms |
07-28-2018, 15:43 | #8 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | [erro] Unable to receive message from FDR 08EB8E98 (-4). 0/2 bytes this not done ! suggest you update iTunes to new version and do full battery charge then try again. |
