Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 11-14-2022, 15:08   #1 (permalink)
Member: 2382052
Thanks Meter: 1,511
restoring s3 big problem
sunday work fine noe bad again
and main server not work
Waiting for program to exit ...
Could not stop operation ! No current device selected!
iPOWER X - Searching ...
Latest version 4.0.1_B1 available, Test version v918 (Contact [email protected]) [2022-09-18]
Server: Hello maxpatri9, Welcome to our iMFC server
Successfully connected to server!
Parsing devices ... please wait
Refresh devices step 1 ...
Another refresh operation pending ... please wait
Refresh devices step 2 ...
Refresh devices step 3 ...
Refresh devices step 4 ...
Refresh devices step 5 ...
Refresh devices step 6 ...
Parsing devices completed!
device arrival... new
UniqueDeviceID:7191ab39db7951e0670e3e7744b1d1e7139 50055
device disconnect...
Starting ...
Using LATEST available file.
using cached version data
Waiting for device arrival (timeout 10.000000 seconds)
Unable to discover device mode. Please make sure a device is attached.
Failed
Operation finished!
device arrival... found
Starting ...
Using local file E:\MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42 mm-001.ipsw
Found device in Normal mode
Gettting normal mode device ...
Identified device as Apple Watch S3, n121bap, Watch3,4
Extracting BuildManifest from ipsw
Product Version: 8.7.1
Product Build: 19U67 Major: 19
Device supports Image4: true
Variant: Customer Erase Install (IPSW)
This restore will erase your device data.
Checking IPSW for required components...
All required components found in IPSW
Found ECID 000065e610b9ef26
Getting ApNonce in normal mode... 3D62C364E2202DF093B3B72EA0C402D88A3A24CA82770419B8 0FD848DDCE658A
tts>Trying to fetch new SHSH blob
Getting SepNonce in normal mode... D32C711FA0FE4ACA733AAF2BAE12A50F504C777E
Unable to find BbChipID node
Unable to find BbProvisioningManifestKeyHash node
Unable to find BbActivationManifestKeyHash node
Unable to find BbCalibrationManifestKeyHash node
Unable to find BbFactoryActivationManifestKeyHash node
Unable to find BbFDRSecurityKeyHash node
Unable to find BbSkeyId node
Sending TSS request...
Unable to get FirmwarePreflightInfo. It might be possible to continue...
Request URL set to https://gs.apple.com/TSS/controller?action=2
Sending TSS request attempt 1...
response successfully received
tts>Received SHSH blobs
Filesystem file not found!
We will extract the filesystem to file iDeviceTools/MFC_Watch3,4_19U67_8.7.1_n121/078-33421-074.dmg
Extracting filesystem
Getting SepNonce in normal mode... 663CA7125AF671F5498F75F03BC3A39A3899AE11
Entering recovery mode...
device serial number is FHLV99VRJ5X3
No path for component iBEC in TSS, will fetch from build_identity
Extracting iBEC.n121b.RELEASE.im4p...
Personalizing IMG4 component iBEC...
Tag not processed for iBEC!
Sending iBEC (773156 bytes)...
Unable to send iBEC component: Unable to upload data to device
Unable to send iBEC to device.
Device ecid 000065e610b9ef26 disconnect detected!
Recovery Mode Environment:
iBoot build-version=iBoot-7459.140.15
iBoot build-style=RELEASE
Sending AppleLogo...
No path for component AppleLogo in TSS, will fetch from build_identity
Extracting applelogo@132~watch.im4p...
Personalizing IMG4 component AppleLogo...
Tag not processed for AppleLogo!
Sending AppleLogo (9312 bytes)...
No path for component RestoreTrustCache in TSS, will fetch from build_identity
Extracting 078-33379-076.dmg.trustcache...
Personalizing IMG4 component RestoreTrustCache...
Sending RestoreTrustCache (15623 bytes)...
No path for component RestoreRamDisk in TSS, will fetch from build_identity
Extracting 078-33379-076.dmg...
Personalizing IMG4 component RestoreRamDisk...
Tag not processed for RestoreRamDisk!
Sending RestoreRamDisk (84828513 bytes)...
No path for component RestoreDeviceTree in TSS, will fetch from build_identity
Extracting DeviceTree.n121bap.im4p...
Personalizing IMG4 component RestoreDeviceTree...
Sending RestoreDeviceTree (32393 bytes)...
No path for component RestoreSEP in TSS, will fetch from build_identity
Extracting sep-firmware.n121b.RELEASE.im4p...
Personalizing IMG4 component RestoreSEP...
Sending RestoreSEP (2337345 bytes)...
No path for component RestoreKernelCache in TSS, will fetch from build_identity
Extracting kernelcache.release.watch3...
Personalizing IMG4 component RestoreKernelCache...
Sending RestoreKernelCache (14632855 bytes)...
About to restore device...
Waiting for device...
Device is now connected in restore mode...
Connecting now...
Connected to com.apple.mobile.restored, version 15
Device 7191ab39db7951e0670e3e7744b1d1e713950055 has successfully entered restore mode
Hardware Information:
BoardID: 26
ChipID: 32772
UniqueChipID: 112038797504294
ProductionMode: true
Starting FDR listener thread
Connecting to FDR client at port 1082
About to do ctrl handshake
Ctrl handshake done (ConnPort = 49172)
Requesting NOT TO Update Baseband
Checkpoint 1621 complete with code 0
Checkpoint 1540 complete with code 0
Checkpoint 1679 complete with code 0
About to send RootTicket...
Sending RootTicket now...
Done sending RootTicket
Checkpoint 1547 complete with code 0
Waiting for NAND (28)
Checkpoint 1549 complete with code 0
Checkpoint 1550 complete with code 0
Checkpoint 1551 complete with code 0
Checkpoint 1628 complete with code 0
Checkpoint 1552 complete with code 0
Checkpoint 1555 complete with code 0
Checkpoint 1662 complete with code 0
Sending NORData...
Found firmware path Firmware/all_flash
zip_name_locate: Firmware/all_flash/manifest
Getting firmware manifest from build identity
Extracting LLB.n121b.RELEASE.im4p...
Personalizing IMG4 component LLB...
Tag not processed for LLB!
Extracting dali-ui.n121b.release.im4p...
Personalizing IMG4 component Dali...
Tag not processed for Dali!
Personalizing IMG4 component DeviceTree...
Tag not processed for DeviceTree!
Extracting recoverymode@132~watch.im4p...
Personalizing IMG4 component RecoveryMode...
Tag not processed for RecoveryMode!
Extracting iBoot.n121b.RELEASE.im4p...
Personalizing IMG4 component iBoot...
Tag not processed for iBoot!
Personalizing IMG4 component SEP...
Tag not processed for SEP!
Sending NORData now...
Done sending NORData
Checkpoint 1545 complete with code 0
Checkpoint 1683 complete with code 0
Unmounting filesystems (29)
Checkpoint 1637 complete with code 0
Checkpoint 1556 complete with code 0
Checkpoint 1686 complete with code 0
Checkpoint 1699 complete with code 0
Checkpoint 1695 complete with code 0
Checkpoint 1620 complete with code 0
Checkpoint 1687 complete with code 0
Checkpoint 1557 complete with code 0
About to send FDR Trust data...
Sending FDR Trust data now...
sending FDR Trust Data
Checkpoint 1558 complete with code 0
Checkpoint 1559 complete with code 0
Checkpoint 1560 complete with code 0
Checking for uncollected logs (44)
Checkpoint 1561 complete with code 0
Checkpoint 1562 complete with code 0
Connecting to FDR client at port 49172
Checkpoint 1563 complete with code 0
Checkpoint 1633 complete with code 0
Checkpoint 1565 complete with code 0
Checkpoint 1614 complete with code 0
Checkpoint 1567 complete with code 0
Checkpoint 1674 complete with code 0
Creating partition map (11)
Checkpoint 1569 complete with code 0
Checkpoint 1632 complete with code 0
Checkpoint 1570 complete with code 0
Checkpoint 1629 complete with code 0
Checkpoint 5645 complete with code 0
Creating filesystem (12)
Checkpoint 1624 complete with code 0
Checkpoint 1625 complete with code 0
Checkpoint 1626 complete with code 0
About to send filesystem...
Connected to ASR
Validating the filesystem
Filesystem validated
Sending filesystem now...
sending filesystem
Operation: Verifying restore (14)
Checkpoint 1627 complete with code 0
Checkpoint 1664 complete with code 0
Checkpoint 1653 complete with code 0
Checkpoint 1676 complete with code 0
Checking filesystems (15)
Mounting filesystems (16)
Checkpoint 1574 complete with code 0
Checkpoint 1634 complete with code 0
Checkpoint 1655 complete with code 0
Checkpoint 1658 complete with code 0
Checkpoint 1575 complete with code 0
Checkpoint 1690 complete with code 0
Checkpoint 1691 complete with code 0
Checkpoint 1618 complete with code 0
Checkpoint 1588 complete with code 0
Checkpoint 1661 complete with code 0
Operation: Unknown operation (80)
Sending IsiBootEANFirmware image list
Sending IsiBootNonEssentialFirmware image list
Flashing firmware (18)
Checkpoint 4864 complete with code 0
Sending IsEarlyAccessFirmware image list
Checkpoint 4882 complete with code 0
Operation: Requesting FUD data (36)
Found IsFUDFirmware component ACIBT
Found IsFUDFirmware component ACIWIFI
Found IsFUDFirmware component AOP
Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
Found IsFUDFirmware component Multitouch
Found IsFUDFirmware component RTP
Found IsFUDFirmware component RestoreTrustCache
Found IsFUDFirmware component StaticTrustCache
Found IsFUDFirmware component SystemVolume
Sending IsFUDFirmware image list
Extracting BT_FW.im4p...
Personalizing IMG4 component ACIBT...
Tag not processed for ACIBT!
Sending IsFUDFirmware for ACIBT...
Extracting wifi_armv7r_m8p_rtkit_image.im4p...
Personalizing IMG4 component ACIWIFI...
Tag not processed for ACIWIFI!
Sending IsFUDFirmware for ACIWIFI...
Extracting aopfw-m8paop.im4p...
Personalizing IMG4 component AOP...
Tag not processed for AOP!
Sending IsFUDFirmware for AOP...
Extracting 078-33421-074.dmg.mtree...
Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
Tag not processed for Ap,SystemVolumeCanonicalMetadata!
Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
Extracting N121b_Multitouch.im4p...
Personalizing IMG4 component Multitouch...
Tag not processed for Multitouch!
Sending IsFUDFirmware for Multitouch...
Extracting rtpfw.im4p...
Personalizing IMG4 component RTP...
Tag not processed for RTP!
Sending IsFUDFirmware for RTP...
Sending IsFUDFirmware for RestoreTrustCache...
Extracting 078-33421-074.dmg.trustcache...
Personalizing IMG4 component StaticTrustCache...
Tag not processed for StaticTrustCache!
Sending IsFUDFirmware for StaticTrustCache...
Extracting 078-33421-074.dmg.root_hash...
Personalizing IMG4 component SystemVolume...
Tag not processed for SystemVolume!
Sending IsFUDFirmware for SystemVolume...
Checkpoint 4874 complete with code 0
Updating gas gauge software (47)
Checkpoint 4865 complete with code 0
Checkpoint 4866 complete with code 0
Updating Stockholm (55)
Checkpoint 4868 complete with code 0
Checkpoint 4868 complete with code 18446744073709551615
Checkpoint 1589 complete with code 56
Checkpoint 1659 complete with code 56
Checkpoint 1660 complete with code 0
Checkpoint 5651 complete with code 0
Checkpoint 1607 complete with code 0
Status message: Ramrod firmware update failed.
Hint: The display of this model is not compatible, or you can replace the NFC module
Log is available in ErrorLog.plist
Unable to successfully restore device
Checkpoint 1608 complete with code 0
Unable to restore device
Failed
Operation finished!
Starting ...
Found device in Recovery mode
Gettting dfu mode device ...
Getting ApNonce in recovery mode... 37249516C1DC0B6DB2D73458BD70FE0B50FF527D5E8E11B099 0F88F58989431B
Getting SepNonce in recovery mode... 10B22D5AECAFE5601C10C4DD6F1A667BBBBB06D9
Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_19U67_8.7.1_n121/078-33421-074.dmg'
Connecting now...
BoardID: 26
ChipID: 32772
Previous restore exit status: 0x100
Ctrl handshake done (ConnPort = 49161)
Sending NORData...
Connected to ASR
sending filesystem
Failed
Operation finished!
Loading version data from Apple Server
Updated version data.
Server: Please check your IP address! Login not allowed! Please wait and retry!
Error: Server init state canceled
Starting ...
Incorrect driver detected! Please wait to update the drivers!
File E:\MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42 mm-001.ipsw not recognized by server!
File size: 2780952569
Please check if the file you downloaded is complete! Aborting operation!
Firmware file might be corrupt.
Unable to extract BuildManifest from E:\MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42 mm-001.ipsw.
Failed
Operation
Old 11-14-2022, 19:13   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,027
try software V4.x or you can also check the beta V919
Page generated in 0.21267 seconds with 8 queries
