![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2008 Location: kutch, gujarat, india
Member: 852566 Status: Offline Thanks Meter: 464 | s0 restore Error [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S0 - 1st generation, n28aap, Watch1,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.2 [data] Product Build: 15U70 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0000058dc86fe488 [info] Getting ApNonce in dfu mode... [data] 9DAE9D9C918D247D1E9CB34A236218839A5A199B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [warn] Unable to find required ApSepNonce in parameters, maybe possible to continue... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'D:\Apple\apple watch firmware/MFC_Watch1,2_4.3.2_15U70_n28aap_Restore_42mm/048-18423-071.dmg' [info] Found ECID 0000058dc86fe488 [info] Getting ApNonce in dfu mode... [data] 9DAE9D9C918D247D1E9CB34A236218839A5A199B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [warn] Unable to find required ApSepNonce in parameters, maybe possible to continue... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n28a.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [warn] Tag not processed for iBSS! [info] Sending iBSS (132461 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 0000058dc86fe488 disconnect detected! [info] Found device in DFU mode [info] Noce: 9d ae 9d 9c 91 8d 24 7d 1e 9c b3 4a 23 62 18 83 9a 5a 19 9b [info] Extracting iBEC.n28a.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [warn] Tag not processed for iBEC! [info] Sending iBEC (639981 bytes)... [info] Device ecid 0000058dc86fe488 disconnect detected! [erro] II [info] device serial number is FHLQ48ANG9J6 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.70.15 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [warn] Tag not processed for AppleLogo! [info] Sending AppleLogo (7210 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-18231-071.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [warn] Tag not processed for RestoreRamDisk! [info] Sending RestoreRamDisk (84455723 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n28aap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (74965 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch1... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (10778211 bytes)... [info] Device ecid 0000058dc86fe488 disconnect detected! [info] About to restore device... [info] Waiting for device... [erro] can't open device with UDID 00008110-001809DA3C22801E [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device c0d51614c33bcabb699dbfb59a6de2a49075b9e6 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 4 [info] ChipID: 28674 [info] UniqueChipID: 6106511303816 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49157) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1545 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1553 complete with code 0 [info] Checkpoint 1554 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checking filesystems (15) [info] Checkpoint 1637 complete with code 0 [info] Checking filesystems (15) [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checkpoint 1561 complete with code 0 [info] Connecting to FDR client at port 49157 [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49157 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1619 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1631 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch1... [info] Personalizing IMG4 component KernelCache... [warn] Tag not processed for KernelCache! [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] Checkpoint 3584 complete with code 0 [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n28aap.im4p... [info] Personalizing IMG4 component DeviceTree... [warn] Tag not processed for DeviceTree! [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Checkpoint 3585 complete with code 0 [info] Checkpoint 3586 complete with code 0 [info] Checkpoint 3587 complete with code 0 [info] Checkpoint 1576 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n28a.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [warn] Tag not processed for LLB! [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [warn] Tag not processed for AppleLogo! [info] Extracting dali-ui.n28a.release.im4p... [info] Personalizing IMG4 component Dali... [warn] Tag not processed for Dali! [info] Extracting DeviceTree.n28aap.im4p... [info] Personalizing IMG4 component DeviceTree... [warn] Tag not processed for DeviceTree! [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [warn] Tag not processed for RecoveryMode! [info] Extracting iBoot.n28a.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [warn] Tag not processed for iBoot! [info] Sending NORData now... [info] Done sending NORData [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 18446744073709551615 [info] Checkpoint 1589 complete with code 56 [info] Checkpoint 1607 complete with code 0 [info] Status message: Ramrod firmware update failed. Hint: The display of this model is not compatible, or you can replace the NFC module [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [info] Checkpoint 1608 complete with code 0 [erro] Unable to restore device [done] Operation finished! [info] device disconnect... |
