10-24-2017, 03:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | S1 can't be restore with v3.2 [info] Starting ... [info] Using LOCAL IPSW F:\MFC\Iwatch s1\MFC_Watch2,6_3.2_14V249_n27dap_restore_38mm.ips w [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch, n28aap, Watch1,2 [info] Extracting BuildManifest from IPSW [erro] Could not make sure this firmware is suitable for the current device. Refusing to continue. [info] Failed |
10-24-2017, 07:15 | #2 (permalink) | ||
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Watch is n28aap--->This is Watch Series 0 (1st Generation) 42 mm (A1554 N28aAP) that must use this firmware: http://forum.gsmhosting.com/vbb/12422860-post1.html | ||
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
10-24-2017, 12:04 | #3 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
Now done 1000000000000000000000% | |
The Following User Says Thank You to 089999945 For This Useful Post: |
10-24-2017, 16:49 | #4 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Next time you can post at here : ★★★★★★ Post here all successfully story by iBUS S1 & S2 Tool ★★★★★★ - GSM-Forum |
