02-06-2018, 12:07 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: viet nam
Member: 1067406 Status: Offline Thanks Meter: 5 | [info] Starting ... [info] Using LATEST available IPSW. [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 2630427229136166 [info] Getting ApNonce in normal mode... [data] C83ED379E8DE0689A1DE68ED82487383B981208094187C89ED 7B5DA4BF190A20 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 3D5E8EEB8029C23320DD44C3521D8867792E2223 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [info] Entering recovery mode... [info] Apple device disconnected! [info] Apple device arrival ... searching USBMux for device after 100ms [info] Apple device disconnected! [data] UniqueChipID:278504742 [data] ProductType:Apple Watch S2 [info] device serial number is FH7SQDENHHYL [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e26db37df52937c181f715f264d1c891ec4fb00f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 2630427229136166 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0906D318 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 0937B518 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! s2 flash with mfc error text end and reecovery Last edited by .::Gsmdenis::.; 02-06-2018 at 12:22. |
02-06-2018, 12:20 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Do full charge and try again , you can also send this file ( ErrorLog.plist ) to [email protected] |
02-06-2018, 12:22 | #3 (permalink) | |
Member: 1067406 Status: Offline Thanks Meter: 5 | Quote:
02-06-2018, 12:51 | #4 (permalink) |
Member: 1067406 Status: Offline Thanks Meter: 5 | [info] [info] Starting ... [info] Using LATEST available IPSW. [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LOCAL IPSW C:\Users\Administrator\Desktop\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 1531268129465638 [info] Getting ApNonce in normal mode... [data] FFBF2780E8C66C8A503B6A59DC46E433A36CD334D7FEAFB5EC BBB6AC34F8702E [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] BC233194C7ADBA25278B606292853AD9783F78F0 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [info] Entering recovery mode... [info] Apple device disconnected! [data] UniqueChipID:619291942 [data] ProductType:Apple Watch S2 [info] device serial number is FH8SFANWHJLJ [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 866235a5ac415a776932aaa547c46659c32a34be has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 1531268129465638 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0414ACD8 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 063A6000 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! STILL EROR WITH 2 DEVICE |
02-06-2018, 16:33 | #9 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | send this file ( ErrorLog.plist ) to [email protected] |
02-06-2018, 16:43 | #10 (permalink) | |
02-06-2018, 16:46 | #11 (permalink) | |
02-06-2018, 18:04 | #13 (permalink) | |
[info] Starting ... [info] Using LOCAL IPSW C:\Users\Administrator\Desktop\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH7SQDENHHYL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 2630427229136166 [info] Getting ApNonce in recovery mode... [data] [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [erro] Unable to find required ApNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [info] Failed | |
02-06-2018, 18:19 | #14 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
02-06-2018, 19:55 | #15 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2808391 Status: Offline Thanks Meter: 2 | Hi Denis, Same problem here: [info] Sending TSS request... [erro] Unable to find required ApNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [info] Failed |
