03-05-2018, 11:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: viet nam
Member: 1067406 Status: Offline Thanks Meter: 5 | S2 ver NIKE restore error [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH7SQDENHHYL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 2630427229136166 [info] Getting ApNonce in recovery mode... [data] C1F037B202F393A5229BD9E1673F10DBD8947FB7941EDC73C8 7029281955A616 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 341743201C8E8EB683BFE47D02C0814019C687CC [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [data] UniqueDeviceID:e26db37df52937c181f715f264d1c891ec4 fb00f [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e26db37df52937c181f715f264d1c891ec4fb00f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 2630427229136166 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E5E50 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [warn] Lockdown error: -3 [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76BCA8 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76BBD0 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E65D0 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E66F0 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E6648 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E6648 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E6570 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E64B0 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A1E64C8 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C548 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C470 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C380 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C770 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C878 got proxy message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C6B0 got plist message [warn] FDR 0A1E5EC8 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0E76C770 got proxy message [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! [info] Starting ... [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [info] Failed [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH7SQDENHHYL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 2630427229136166 [info] Getting ApNonce in recovery mode... [data] 2F03A9E18DD7D5A3C73C03B71035E45B62E6674B0451D55374 7327AA23BBB505 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 7C8C675BA3ED19FDADCF39197D6E39DA763ECD5A [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm/058-86830-108.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e26db37df52937c181f715f264d1c891ec4fb00f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 2630427229136166 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 03979378 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [warn] Lockdown error: -3 [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 039799D8 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 039798D0 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 03979C18 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 03979C00 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 03979F60 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 03979FC0 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A020 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A4B8 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A338 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A380 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A428 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A1D0 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A308 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A338 got proxy message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A1E8 got plist message [warn] FDR 0DDE51F0 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0397A320 got proxy message [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! [info] Apple device arrival ... searching USBMux for device after 100ms [warn] Lockdown error: -8 [info] Apple device disconnected! [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH7SQDENHHYL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 2630427229136166 [info] Getting ApNonce in recovery mode... [data] B79AF1382DF73C9DF70EEC280CC7EE5751CD36B8397FD0015A E8870F6F42361F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 374C9484167DB4B23E7529417D5F1FC7FF9354A1 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm/058-86830-108.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e26db37df52937c181f715f264d1c891ec4fb00f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 2630427229136166 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137828 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [warn] Lockdown error: -3 [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137AF8 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137AC8 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137B88 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137B40 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137B88 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137A50 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137C48 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137C30 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137CF0 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137AF8 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137B58 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137C60 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137BD0 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137C78 got proxy message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137A68 got plist message [warn] FDR 0CEA9958 got sync message [info] Connecting to FDR client at port 49158 [warn] FDR 0A137BE8 got proxy message [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device i need help,thanks admin |
03-05-2018, 13:06 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Send this file ErrorLog.plist to email [email protected] |
03-09-2018, 09:22 | #3 (permalink) | |
Member: 1067406 Status: Offline Thanks Meter: 5 | Quote:
