![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2013 Location: Ukraine
Member: 1964660 Status: Offline Sonork: No Thanks Meter: 56 | S3 won't boot to diag [info] If the serial device is Diags CDC Serial the reccomended speed selection is 9600bps [info] New define added to database! [info] Removing USB rules! [info] Device present in DFU mode. Updating drivers if required ... [info] Installing libusbK driver for USB WINUSB device: "Apple Mobile Device (DFU Mode)". [info] Removed (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:001C3DA11E010026_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Arrival (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:001C3DA11E010026_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Detected USB driver reset! [info] Loading required files ... [info] Finished loading required files ... [info] Using checkm8 v2 (default) [info] Stage: RESET (1) [info] SPRAY (0, 5) [info] Stage: SPRAY (1) [info] Stage: SETUP (1) [info] Removed (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:001C3DA11E010026_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Arrival (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:001C3DA11E010026_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Stage: PATCH (1) [info] Removed (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:001C3DA11E010026_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [done] Operation finished! [info] Selected port: COM1 [info] If the serial device is Diags CDC Serial the reccomended speed selection is 9600bps [info] Selected port: COM1 [info] If the serial device is Diags CDC Serial the reccomended speed selection is 9600bps [info] Selected port: COM54 [info] If the serial device is Diags CDC Serial the reccomended speed selection is 9600bps [info] Opening \\.\COM54 with baudrate 115200 [erro] Opening aborted, no response from device! Device just boot to normal mode, try many times!!! |
![]() | #4 (permalink) | |
Member: 1964660 Status: Offline Sonork: No Thanks Meter: 56 | Quote:
nfo] Device present in DFU mode. Updating drivers if required ... [info] Installing libusbK driver for USB WINUSB device: "Apple Mobile Device (DFU Mode)". [info] Removed (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:0018A4E6386840A6_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Arrival (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:0018A4E6386840A6_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Detected USB driver reset! [info] Loading required files ... [info] Finished loading required files ... [info] Using checkm8 v2 [info] Stage: RESET (1) [info] SPRAY (0, 5) [info] Stage: SPRAY (1) [info] Stage: SETUP (1) [info] Removed (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:0018A4E6386840A6_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Arrival (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:0018A4E6386840A6_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) [info] Stage: PATCH (1) [info] Removed (MFC, Inc.,USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM: 03_SCEP:01_BDID:1A_ECID:0018A4E6386840A6_IBFL:3C_S RTG:[IBOOT-2651.0.0.3.3]) | |
